please show me some pics of your tuned pipe tunnel!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Rcexl Opto Gas Engine Kill Switch ***FREE SHIPPING***
Seller:  swgiantscalemodels
Details:   $13.29   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> please show me some pics of your tuned pipe tunnel!
Page: [1]
Login
please show me some pics of your tuned pipe tunnel! - 10/11/2009 8:12 AM
mobilemenice80
Score: 100
Last Login: 3/22/2013
Status: offline
guys im getting ready to start building a 35% 330 mid-wing, and i am looking for a great way to build the pipe tunnel for a set of mtw re2 pipes. i have seen a few diffrent ways of doing this and am open to suggestions in how to make it
1.light
2.strong
3.clean
rudder servos willbe going in the tail.
space seems to be at a premium, as things are pretty tight with this combo so i am looking for set-ups that have proven to be reliable!..
thanks!
Hide Signatures
       Post #: 1
RE: please show me some pics of your tuned pipe tunnel! - 10/11/2009 6:45 PM
lazy eight
Score: 105
Last Login: 1/11/2013
Status: offline
Check out the Edge 540 and Yak build I started theres some pics of the pipe tunnels Eric builds out of 1oz glas cloth and west system epoxy. They are light and strong and look cool plus they flow air like a wind tunnel. pipes stay really cool!! Theres a thread also I posted pics of my 40% Extra 260 with MTW 1090 pipes the tunnel on that is the same as the Yak and the Edge. check them out. I think its the thread "260 on tuned pipes".
James
_____________________________
JDP
Hide Signatures
(in reply to mobilemenice80)
       Post #: 2
RE: please show me some pics of your tuned pipe tunnel! - 10/12/2009 3:22 AM
mobilemenice80
Score: 100
Status: offline
i know i am capable and have a little bit of glass experance however and ope of getting a little more info on the fiberglass tunnel.. what was the foam tool lined with to aid in the tunnels release? thanks..
see if eric can do a build thread on the tunnel.. or better yet see if he wants to do mine!.. lol
Brad
Hide Signatures
(in reply to lazy eight)
       Post #: 3
RE: please show me some pics of your tuned pipe tunnel! - 10/14/2009 7:06 AM
lazy eight
Score: 105
Status: offline
The foam plug was cut with a hot wire and then coated with epoxy then sanded smooth. Then coated with silicone mold release agent. There not hard to build just takes time. They really flow the air better than a boxed balsa set up. Plus they look COOL and add more strength to the fuse. It really takes the twisting out of the fuse and makes them really stiff.
JDP
Hide Signatures
       Post #: 4
RE: please show me some pics of your tuned pipe tunnel! - 10/14/2009 4:54 PM
mobilemenice80
Score: 100
Status: offline
thanks buddy! exactly what i needed to know!
Hide Signatures
       Post #: 5
RE: please show me some pics of your tuned pipe tunnel! - 10/15/2009 1:23 AM
lazy eight
Score: 105
Status: offline
Glad I could help. I will be doing a build thead this winter on my 43% Edge once I get it. Hopefuly it will be a better build thread than my last two. I will be doing the build this time around. Stay tuned. The kits are to ship this Nov. It will have the glass tunnel with RE 3 pipes and a DA 170 for power.
James
JDP
Hide Signatures
       Post #: 6
RE: please show me some pics of your tuned pipe tunnel! - 1/31/2010 5:11 AM
lazy eight
Score: 105
Status: offline
Heres a new one for ya to look at. 37.5% Yak 54 CARDEN!!!! Those are MTW RE3's tucked in there with 12.5 inch MTW headers.
Built By Watz Custom Aircraft Saginaw Michigan. Brand spankin new baby!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
JDP
Hide Signatures
       Post #: 7
RE: please show me some pics of your tuned pipe tunnel! - 2/2/2010 3:22 PM
BBW Walt
Score: 105
Last Login: 5/10/2013
Status: offline
Tunnels are pretty much a thing of the past. There not needed. I have tunneled in most of the installations on Cardens, MTW 110's, Greeve's and RE3's and have come to find its not necessary. There's some pretty interesting numbers on another site to support what I mention that have changed my mind. I believe I"m up to 4 builds without tunnels in various planes and no issues what so ever. Walt
Nothing is impossible for those not doing the work
Hide Signatures
       Post #: 8
RE: please show me some pics of your tuned pipe tunnel! - 2/3/2010 5:34 AM
lazy eight
Score: 105
Status: offline
Pipe tunnels may be a thing of the past as is building your own airplane and keeping it for more than a year. But for me I have had it both ways and believe there is a value to having them. Having proper airflow across the thin wall pipes is a great thing for many reason as well as the bonus cooling it adds to the engine. How many tuned pipe set do we all see for sale every year with the mount dents in them? I wonder how that happened? Heat burning the rubber mounts? Also I dont like my fuselage getting dirt,oil, heat, fuel blowback and other crime inside my plane. Also pressurizing the fuselage in my opion is a mistake. Ever watch the fuse sides ballon out on a ground run? I like the fuse closed off as much as possable. But look at most ARFs there wide open to everything and they work GREAT. My numbers are on the Carbon tunnels. Pipes so cool you can grab them after the flight. I'm just here sharing my planes for all to see and to show Erics great work. I'm not saying you should build a plane like mine just check it out, it works great.
< Message edited by lazy eight -- 2/4/2010 2:45 AM >
JDP
Hide Signatures
(in reply to BBW Walt)
       Post #: 9
RE: please show me some pics of your tuned pipe tunnel! - 2/7/2010 9:13 PM
BBW Walt
Score: 105
Status: offline
Here's a couple pictures of some that I have done and a couple without tunnels. All these are still flying. If memory serve's me correctly the tunnels in the Carden builds usually add 3oz's to the build. I use 1/32 balsa sheeting for the top's and polyurethane the inside to stiffin up and seal the tunnel. The Fabric/resin tops add more. Maybe this will offer ideas to your origional question..Walt
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by BBW Walt -- 2/9/2010 5:01 AM >
Hide Signatures
       Post #: 10
RE: please show me some pics of your tuned pipe tunnel! - 2/8/2010 9:52 PM
lazy eight
Score: 105
Status: offline
Nice work Walt
< Message edited by lazy eight -- 2/9/2010 7:45 AM >
JDP
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.596RCU1
