Just got me a Nitro pede
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Just got me a Nitro pede Page: [1]
Login
Just got me a Nitro pede - 10/16/2009 3:29 AM
monsterpede360
Score: 100
Last Login: 3/7/2010
Status: offline
Well just got me a nitro pede today brand new . Its been awhile since i bought a brand new nitro. But what are some good upgrades for a nitro pede
_____________________________
Team Associated SC10
Traxxas Revo 2.5R
Hide Signatures
       Post #: 1
RE: Just got me a Nitro pede - 10/16/2009 5:28 AM
andybenton
Score: 100
Last Login: 3/20/2010
Status: offline
chasis and drive line ?
for mine, ive got a harder set of springs, mine are actually off of a axial ax10 but any upgraded stiffer springs, 25 wt team losi shock oil, adjust your toe in a little over one degree, and new tires, you could play with the spur and clutchbell gears, but i find the stock set to be great for around the yard. however a metal spur gear would really help alot, and also a set of aluminum "axels" will really help out, i blew two plastic sets in about 40 minuets, so i definatly recomend those.
motor?
i think the two best things i ever did to my motor were the tuned pipe, and switching to 30% nitro, other than that, take your time to set your carb, tune it really well, take your time, make sure the motor is to full operating temp before tuning, (im sure you allready knew that).
uh, lets see, what else,
im working on learning to port my engines, i havent ever done it to a nitro motor, allthough i had a yamaha banshee two stroke quad that i ported and polished, thats a lot less finiky of a motor lol...
steering?
definatly spend the extra 15 bucks and get a good metal gear servo and a servo saver, scince almost every servo that claims allmetal gears the generally have at least one plastic gear, so the servo saver will help to save that one little gear, also you could go ahead and get a high torqu servo, wich will also help with steering
and finally bearings?
now personally i dont care what any one tells you, a full ball bearing or even better a full ceramic bearing rig will allways roll more efficiantly and require less force to move it as compared to an oil lite chasis. so i befinatly recomend all ball bearing, or at least ball bearing the front set,
Hide Signatures
(in reply to monsterpede360)
       Post #: 2
RE: Just got me a Nitro pede - 10/16/2009 5:31 AM
cummins driver
Score: 110
Status: offline
Wheelies are fun, but you may find that you want to lower it some to keep the front end on the ground at least 50% of the time It will also help with handling.
I think they are really a pretty strong truck right from the factory though, so pretty much, just go have fun with it
HPI Savage(axial .28) - Traxxas Stampede(14.4 volts/HPI GT550 motor) - XL-5 Stampede(Electrifly S-600) - Electric Monster GT
Hide Signatures
(in reply to andybenton)
       Post #: 3
RE: Just got me a Nitro pede - 11/21/2009 5:51 AM
jermainezey
Score: 100
Last Login: 3/15/2010
Status: offline
do u have to change a lot to use a pull starter or is it just a drop it in and go kinda thing
jermaine dawkins
Hide Signatures
(in reply to cummins driver)
       Post #: 4
RE: Just got me a Nitro pede - 11/21/2009 6:47 AM
cummins driver
Score: 110
Status: offline
Just buy the pullstart unit, and replace the ez-start with it. Shouldnt take long at all to do.
Hide Signatures
(in reply to jermainezey)
       Post #: 5
RE: Just got me a Nitro pede - 11/21/2009 2:33 PM
jermainezey
Score: 100
Status: offline
am just make sure it will work with out do any mods to the truck
jermaine dawkins
Hide Signatures
       Post #: 6
RE: Just got me a Nitro pede - 11/21/2009 5:36 PM
cummins driver
Score: 110
Status: offline
Nope, no other mods are required.
Hide Signatures
       Post #: 7
RE: Just got me a Nitro pede - 11/21/2009 6:02 PM
jermainezey
Score: 100
Status: offline
what spur gear do u use in your truck
jermaine dawkins
Hide Signatures
       Post #: 8
RE: Just got me a Nitro pede - 11/21/2009 6:09 PM
cummins driver
Score: 110
Status: offline
I dont own one, I just know the pull start will swap right onto it.
Hide Signatures
       Post #: 9
RE: Just got me a Nitro pede - 11/21/2009 6:16 PM
jermainezey
Score: 100
Status: offline
sound good cuz i just got one thats a roller off ebay last nite and i got a.15 traxxas engine a few days ago off there not sure how good the engine will run so am going to rebuild it once it come in
jermaine dawkins
Hide Signatures
       Post #: 10
RE: Just got me a Nitro pede - 11/21/2009 6:20 PM
cummins driver
Score: 110
Status: offline
I had good luck out of my Pro .15 on my nitro rustler I got it used, took it apart, and cleaned it up because it was gummed up some. After that, it fired right up and i ran it until i sold it. It ran great, and had a lot more power than i thought it would:
http://www.youtube.com/watch?v=TTv_QldDRUE
Hide Signatures
       Post #: 11
RE: Just got me a Nitro pede - 11/21/2009 6:36 PM
jermainezey
Score: 100
Status: offline
nice the the engine am going be using came out of a nitro rustle the guy said it have compresstion just not sure how good it run, i just sold as os 18 tz engine when it came in it ran but it had no power all i did was took it apart clean it real good put it back to gather it ran fine and had so much power it blew the cutch spring and shoes right off my mmgt 3.0 parts just went flying every where
jermaine dawkins
Hide Signatures
       Post #: 12
RE: Just got me a Nitro pede - 11/21/2009 7:26 PM
The_Collector
Score: 100
Last Login: 3/6/2010
Status: offline
I shoved an O.S. in my Pede, and put on some Revolver wheels. My truck is from 2000, so it has the 2.2's with the chevron tires. It can take some hard knocks. The only bad thing is that they steer like a bus.
There are only two sides...and the time has come. Choose.
Hide Signatures
       Post #: 13
RE: Just got me a Nitro pede - 11/21/2009 8:25 PM
jermainezey
Score: 100
Status: offline
the pede is a single speed two wheel drive truck
jermaine dawkins
Hide Signatures
(in reply to The_Collector)
       Post #: 14
RE: Just got me a Nitro pede - 11/21/2009 8:26 PM
jermainezey
Score: 100
Status: offline
why is the steering so bad is there any thing that can be done to fix it
jermaine dawkins
Hide Signatures
       Post #: 15
RE: Just got me a Nitro pede - 11/22/2009 6:02 AM
cummins driver
Score: 110
Status: offline
I think the steering is kind of bad because most of the weight is in the back, and with the chassis being high, it rolls kind of easy turning at speed, and under acceleration, the front end is even lighter making it ever harder to steer. Im sure you could lower it some and move the reciever battery pack to the front and make the handling much better, but it just depends on how well you want it to handle.
Eric
Hide Signatures
       Post #: 16
RE: Just got me a Nitro pede - 11/22/2009 6:45 AM
jermainezey
Score: 100
Status: offline
i see part for the truck is pretty cheap will this truck stand up to beatings are is it sum that break easy
jermaine dawkins
Hide Signatures
       Post #: 17
RE: Just got me a Nitro pede - 11/22/2009 7:17 AM
jermainezey
Score: 100
Status: offline
is it ok to just replace the piston and sleeve in a engine and reused the other parts
jermaine dawkins
Hide Signatures
       Post #: 18
RE: Just got me a Nitro pede - 11/22/2009 3:12 PM
cummins driver
Score: 110
Status: offline
It depends.... If the bearings are still good, and the connecting rod looks ok and the hole that slips over the crank pin isnt oblong and doesent have excessive play, then you might be alright. If it is kind of loose from being wore and it doesent fit real tight, then you will want to replace that too.
Honestly, what I would do on a motor like that, is send the piston and sleeve off to have it repinched. Its only about $20 which is probably $30 sheaper than a new piston and sleeve, and it will probably last until the used bearings in the motor are worn out anyways.
Or if nothing else, join up at traxxas.com and use their classifieds. I see 2.5r engines go for $30-50 in good used shape over there pretty often. I bought one for $30 or 35 shipped from a guy over there and it was in great shape and ran good till i sold it.
Hide Signatures
       Post #: 19
RE: Just got me a Nitro pede - 11/22/2009 7:32 PM
jermainezey
Score: 100
Status: offline
thank for the info i will let u know which way i will go with the engine once it comes in and i get it tore down
jermaine dawkins
Hide Signatures
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
