Running dual receiver set-ups in your giant scale?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Rcexl Opto Gas Engine Kill Switch ***FREE SHIPPING***
Seller:  swgiantscalemodels
Details:   $13.29   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> Running dual receiver set-ups in your giant scale?
Page: [1]
Login
Running dual receiver set-ups in your giant scale? - 10/19/2009 4:54 AM
pgriffinifd@aol.com
Score: 100
Last Login: 2/27/2013
Status: offline
I've been very curious about this. I hear a lot, both pro and con. How many of you are running dual receivers in your giant scale airplanes? If so, why, and how do you have yours set up. If not, why not?. I personally think that if you have a multi-thousand dollar plane, it is good insurance, but some do not share this view. Their reasoning is failures are few & far between with modern radio gear. It complicates the set-up, adding more switches, batteries, and connections to fail, and other things. Well, Lets hear it, what do YOU think?
Phil Griffin....
Hide Signatures
       Post #: 1
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 6:18 AM
Gremlin Castle
Score: 110
Last Login: 5/17/2013
Status: offline
There is no easy answer to the question and I am sure that you will get all kinds of answers to your question.
Here is how I have done it for the last 19 years of giant scale flying.
1. Use two batteries and two switches feeding a common receiver. Check both switches before each flight
2. Use a battery isolator if the total servo current draw exceeds the listed buss capacity of the receiver.
3. Take care that the receiver is isolated from vibration and is securely mounted.
4. Watch the antenna routing keeping it as far as possible from servo wiring and ignition components.
5. Use a reliable battery monitoring device before each flight.
6. Check the batteries at least twice a year for drops in capacity.
7. Don't use bargain batteries to power the receiver.
8. Mechanically secure all battery and switch connections and avoid silver plated connectors if at all possible in favor of gold plated ones.
This has worked for me in all types and sizes of giant scale planes. If you go to my gallery pictures you can see the range of planes that share the above listed techniques.
_____________________________
Up elevator is not always your friend.
Hide Signatures
(in reply to pgriffinifd@aol.com)
       Post #: 2
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 7:17 AM
All Day Dan
Score: 151
Last Login: 5/21/2013
Status: offline
Hi Phil, This is a hot topic. Here’s a point to consider. The most likely part of your radio system to fail is the transmitter. It has the highest component count, most solder joints, connectors, etc. The components, especially in the RF section, are running at an elevated temperature. It all adds up to a very high failure rate, much higher than anything in the model. Maybe there’s a reliability engineer listening to this thread that can add some good engineering sense to what I am generalizing. The two large IMAC planes that I have seen go in were both caused by transmitter failures and they both had a completely dual setup in the plane. Dan.
Dan
Hide Signatures
       Post #: 3
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 7:28 AM
sfaust
Score: 100
Last Login: 2/23/2013
Status: offline
There is a lot of past history and topics that deal with this, and you might be best served to review those. Pros and cons on both sides, with lots of good information. FWIW, I used to run dual receivers, not so much for redundancy, but to reduce the high current demands on a single receiver. Now that there are receivers that are capable of handling the higher currents, I'm back to using a single receiver on my large airplanes. If you aren't using a receiver that has been crashed, the risk of a failure is very small. In fact, even in my turbine jet I ran a single receiver despite the high dollar value involved.
Stephen
Hide Signatures
(in reply to All Day Dan)
       Post #: 4
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 2:57 PM
krayzc-RCU
Score: 104
Status: offline
i have one 40% and one 46% one has dual one does not. I would do what u need to do to feel better while u r airborne.....
smooth as silk!
Hide Signatures
(in reply to sfaust)
       Post #: 5
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 7:55 PM
Steve Percifield
Score: 108
Status: offline
Like some one said above......many different answers. But I started using dual receivers for output ports rather than redundancy. When i started flying the larger birds that had 2/3 aileron servos, and 2/elevator servos, and 3 rudder servos, I ran out of ports on the receiver. Wyes weren't the answer because of voltage drop and amp draw, so we went with 2 receivers. One receiver would handle the left side, and one would handle the right side. You could now asign multiple outputs to the ailerons and evelator, etc and only have one servo in each output. Of course each receiver has it's own swtich and battery. I disagree with one above statement, the highest component failure rate goes to the switch and the battery in the airplane. Just remember, everything involved with flying RC can fail. Transmitter, receiver, battery, switch, servos, wires, etc. Even the 2.4 gig stuff is not fail proof. But, with the advent of power boxes, dual receivers are giving up to single receivers with the power box handling the additional ports and dual separate batteries, and they are capable of higher amp loads.
The least i would do is dual batteries as one gentleman discribed above. Just another battery and switch plugged into any unused receiver port. Then develope very good battery management habits. Also, I recommend using 5 cell/6 volt batteries. helps everything.
good luck
steve
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
(in reply to krayzc-RCU)
       Post #: 6
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 9:08 PM
hanko
Score: 300
Last Login: 5/19/2013
Status: offline
Im all for the dual reiever,switch, battery set up. Ive used it for years, and it did save an airplane for me once. ( Switch took a ****). I agree 100% that most failures are battery or switch related.
Hide Signatures
(in reply to Steve Percifield)
       Post #: 7
RE: Running dual receiver set-ups in your giant scale? - 10/19/2009 9:30 PM
Steve Percifield
Score: 108
Status: offline
I also had the dual set up save my 35% Edge 540, when 1 rudder servo failed: it ran to one end and stalled, which over amped the battery on that receiver and fried the wiring,switch, battery, etc. The other receiver, which had the other side of the airplane and the second rudder servo, saved the airplane. But because the second rudder servo was fighting the stalled servo on the other receicer, they were linked together, it too over amped, and was very hot when i finally landed and checked everything. But, no doubt, the dual receivers saved the plane.
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
(in reply to hanko)
       Post #: 8
RE: Running dual receiver set-ups in your giant scale? - 10/20/2009 2:24 AM
sfaust
Score: 100
Status: offline
I also agree with the dual battery and switch setup, which is far more important in my opinion than running dual receivers. Anything I fly that's large enough to handle dual batteries is running that setup.
Stephen
Hide Signatures
       Post #: 9
RE: Running dual receiver set-ups in your giant scale? - 11/26/2009 8:24 AM
daleflysrc
Score: 110
Status: offline
I fly both Giant Warbirds and Imacs and use both setups !! My warbirds use 2 switches and battery pacs into one RX. Non digital servos so I use 1800 to 2400 Mah. pacs Meister P-47, Scratch built P-63 King Kobra and a T.F. P-51. My 35% Aeroworks Extra 260 uses Two Rxs. Two 4500 Jr NiMihs. & two switches. I like the MPI charge switches. Allthough I have taken a couple appart and soldered the crimpped pins inside. I run digitals on my Imac and feel the dual Rx setup lowers the current demand on the Rx buss, also it gives me a redundancy as I cross wire the Airplane. I agree that the switch is the weakest link in our systems
&Gold plated connectors are a must !! The Connectors are also the weakest link as they cannot handle the higher amps I always use the same batterys and use a Sirrius charger !! both pacs peak about the same time and the voltages are almost identical when checked under a load. The only other thing I have thought about is a batt share just incase a cell was to short internally it would cut out that pack and keep the other pack from discharging. I dont like though that a batt share is constantly switching from one pac to another. I also use 22 gauge wires. I am old school and still like Nicads !! If it aint broke !! dont fix it !! Hope this helps Dale
Hide Signatures
       Post #: 10
RE: Running dual receiver set-ups in your giant scale? - 11/26/2009 10:34 AM
EloyM
Score: 100
Status: offline
I am not going to join the controversy, but I would like to provide a target for those that always like to have someone to blame:
Back in the days when we had magazines for real modelers, there was one called "Model Builder"! In 1983 I was Ass't Editor
there to Bill Northrop, not gone and not forgotten. At that time, I conceived the idea of dual receivers, installed same in
a large Telemaster and after extensive test flying including cutting off one side (one receiver) during a spin and recovering,
I published my findings in the MB April 1983 issue. First time puiblic, first time in print. Mea culpa - Eloy Marez
Oh yeah, the receivers were Orbit, AM, single conversion!
Hide Signatures
(in reply to daleflysrc)
       Post #: 11
RE: Running dual receiver set-ups in your giant scale? - 11/26/2009 5:46 PM
hanko
Score: 300
Status: offline
And what is a real modeler?
Hide Signatures
(in reply to EloyM)
       Post #: 12
RE: Running dual receiver set-ups in your giant scale? - 12/4/2009 7:47 AM
snuts
Score: 100
Status: offline
quote:
ORIGINAL: hanko
Now there is a hole new can of worms! Ha-Ha.
-Snuts-
I'm a dual Batt/Switch, one receiver guy.
Hide Signatures
(in reply to hanko)
       Post #: 13
RE: Running dual receiver set-ups in your giant scale? - 12/11/2012 10:40 PM
georch
Score: 100
Last Login: 5/12/2013
Status: offline
Hi guys,
I am thinking of installing dual receivers in my 2m de havilland vampire turbine.
I am not sure how to set it up. The radio would be a futaba T8FG super. The plane has dual rudders and the elevator split in two.
My plan si to connect as follows:
Rcv#1:
Left aileron
RH elevator half
RH rudder
Gas
Landing Gear
Rcv#2
Right aileron
LH elevator half
LH rudder
Flaps
Of course one battery per receiver.
How do I configure this in the radio? Is it possible?
Thanks!!!
Hide Signatures
(in reply to snuts)
       Post #: 14
RE: Running dual receiver set-ups in your giant scale? - 12/11/2012 11:17 PM
pappa2victor
Score: 100
Status: offline
Georch-
I agree with you, that is how my Ziroli Skyraider is set up on a 7 ch radio. There is nothing to change on the Tx, it will control both Rxs as if they are one. I wouldn't split something like throttles on a twin or flaps but you seem to have that figured out. It seems to me that two parallel devices are better than one that can fail both batteries.
Hide Signatures
(in reply to georch)
       Post #: 15
RE: Running dual receiver set-ups in your giant scale? - 12/12/2012 6:47 AM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
Georch;I also agree;I am using duals in my 1/4 scale Ziroli Skyraider and I would not change that set up for anything.George.
Hide Signatures
(in reply to pappa2victor)
       Post #: 16
RE: Running dual receiver set-ups in your giant scale? - 12/12/2012 11:44 AM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: EloyM
Back in the days when we had magazines for real modelers, there was one called ''Model Builder''! In 1983 I was Ass't Editor
Well I guess that makes you a real modeler as well as a bitter O/F...
Now that that is out of the way, if you want the redundancy then go ahead and run two receivers placing at least one elevator and aileron impute on each receiver because those are the two primary flight controls that with save your airplane, then for good measure split the rudder and engine. I did this vary thing for years, but to be honest I have been running a single receiver in all my stuff including 50% and larger for a long time now. So as somebody else already stated; do what you feel good about.
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to EloyM)
       Post #: 17
RE: Running dual receiver set-ups in your giant scale? - 12/13/2012 12:23 AM
dadragon
Score: 112
Status: offline
Georch;I forgot to mention I am using a weatronic 12-20R-72 mhz dual receiver and these guys cost about 4 times as much a futaba pcm.I bought mine when I was still working and not retired.
Hide Signatures
(in reply to sensei)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
