Tank foaming
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Tank foaming Page: [1]
Login
Tank foaming - 10/19/2009 2:04 AM
WRM
Score: 100
Last Login: 3/13/2010
Status: offline
I have a new OMP Edge 540 V3 and the tank is foaming. I have changed the tank to a Hayes and it is still foaming. I put a 1/2 thick high density foam between the fuselage. The old tank , I used a Dubro filtered clunk. Looks like the same as the OS Max bubbleless clunk but it only cost $2.50 versus OS's $16.95 What can I do to stop the foaming.
_____________________________
Old Myths Die Hard
Hide Signatures
       Post #: 1
RE: Tank foaming - 10/19/2009 9:00 PM
AFSalmon
Score: 100
Last Login: 3/20/2010
Status: offline
I see this was also posted in the main forum.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to WRM)
       Post #: 2
RE: Tank foaming - 10/19/2009 11:54 PM
Constrictor
Score: 100
Last Login: 3/3/2010
Status: offline
quote:
ORIGINAL: AFSalmon
And on other sites
OMP Distributor
Hide Signatures
(in reply to AFSalmon)
       Post #: 3
RE: Tank foaming - 11/16/2009 1:30 AM
Ernie Misner
Score: 105
Last Login: 3/21/2010
Status: offline
Put a fuel filter in the line right before the engine somewhere. That helps to absorb any bubbles that do make it that far.
Ernie
Hide Signatures
(in reply to Constrictor)
       Post #: 4
RE: Tank foaming - 1/3/2010 1:50 PM
WRM
Score: 100
Status: offline
Think you for the HELP OMP.
Old Myths Die Hard
Hide Signatures
(in reply to Ernie Misner)
       Post #: 5
RE: Tank foaming - 1/5/2010 1:14 PM
AFSalmon
Score: 100
Status: offline
WRM,
Not sure of your posting but fuel foaming is an old problem that modelers have fought for years but with new fuel formulas the foaming is greatly reduced. Obviously vibrration is what kicks off the foaming but the type of fuel you use, the pickup, good lines, how the tank is mounted, and if your engine vibrates too much are all factors that can excite the fuel foaming. From your previous post I would say check your engine and prop for excessive vibrations and maybe try a different brand fuel. Another old trick is to put a few drops of armour-all into your fuel as this acts as an anti-foaming agent. However I've never personally had a need to try this so please do some basic research on fuel foaming and remedies first before trying the additives. Also please post a picture of your tank mounting setup.
Ohio Model Planes
Hide Signatures
(in reply to WRM)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.777RCU1
