RE: The RCFW Hellcat Group Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: The RCFW Hellcat Group Build
Page: <<   < prev  19 20 21 22 23 24 25 [26] 27 28   next >   >>
Login
RE: The RCFW Hellcat Group Build - 9/25/2012 1:47 PM
ChinookRC
Score: 115
Last Login: 5/16/2013
Status: offline
Not meaning to hijack the thread but how did you do the panels Ram?  The variation in color looks great.  If there's a build thread I'd appreciate a pointer to it.
Hide Signatures
(in reply to mirce)
       Post #: 626
RE: The RCFW Hellcat Group Build - 9/28/2012 12:25 AM
Ram-bro
Score: 156
Last Login: 5/21/2013
Status: offline
Thanks for the compliments on the Hellcat. Itwas really an experiment. I used aluminum tape for each panel. Did nt have to do every panel....remember we are all about illusions. The hellcat is paiinte dwith model masters paint...intermediate blue. I would shoot the whole plane in one color and then go back and mask off individual panels and shoot another mixxed shade of intermediate blue, mixxed with white or grey...cant remember which. I never flew the plane, sold it some time ago. I then went back after clear coating it with lustre coat clear and then did the dirty weathering. What is great about that is if you dont like it, it wipes off and you try again. When you get it where you like it...clear it again. Gave it al little depth also. Hopefully this helps some. This is one of my 1st planes I tried all these methods...including some rivit detail so it was a good learning experience.
Hide Signatures
(in reply to ChinookRC)
       Post #: 627
RE: The RCFW Hellcat Group Build - 10/9/2012 12:53 AM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: ihaveahellcat
I was wondering if you have the vinyl surface details and rivets? On your website it says under development and I was wondering if that had changed.
Dan
For Dan and others who are interested in the vinyl surface details I have worked up a package that includes the hatches, inspection panels, dzus fasteners, rib tapes, and a few other odds and ends. These will be cut from chrome vinyl which will provide opportunity for realistic weathering effects for those who choose to do so. A printed guide for placement of the details as seen below will be provided at half size (1/16 scale) which can also be used as a guide for panel lines. I would be happy to provide this in digital format as well for those who would prefer to have it printed at model scale. While designed specifically for the RCFW Hellcat kit these, of course, could be used on any similar sized Hellcat such as the CMP/Nitroplanes or Brian Taylor models.
DISCLAIMER - I have tried to remain faithfull to the scale drawings I used for the model but I make no guarantees in regards to the scale fidelity of these items. As I have noted many times my prototype model was never intended to be anything other than a sport model and thus I have not spent the time to verify the accuracy of said drawings against the full size Hellcat. These details do a wonderful job of breaking up the surface of the model and giving the illusion of a metal structure which is all I demanded of them.
Please send me an email at cwveich@cwvmodels.com if you would like details on ordering.
Here are the vinyl details on the bottom of my Hellcat wing prior to paint. Notice these go on just prior to the final paint and are not primed. When using chrome it is only necessary to rough up the surface the vinyl with steel wool or fine sandpaper and then paint right over the top.
Here they are after a base coat of color. Some of the vinyl details have as many as four coats of paint on them and they still show up just fine.
The only surface details that were primed over were the tapes used to simulate the fabric covering on the control surfaces. To make these a bit more subtle and so that they appear more like doped fabric they were given a couple of coats of primer with some sanding in between.
I am still working on a rivet package. I have not determined at this point whether it will be economical to offer the rivets as they are extemely time consuming to produce on the laser. I need to run a few test strips and then I will be able to make a determination one way or the other. Stay tuned...
< Message edited by Chad Veich -- 10/9/2012 1:19 AM >
Hide Signatures
(in reply to ihaveahellcat)
       Post #: 628
RE: The RCFW Hellcat Group Build - 10/9/2012 1:20 AM
Chad Veich
Score: 265
Status: offline
Post updated with pics.
Hide Signatures
(in reply to Chad Veich)
       Post #: 629
RE: The RCFW Hellcat Group Build - 10/9/2012 4:55 AM
ihaveahellcat
Score: 100
Last Login: 3/17/2013
Status: offline
Wow Those look awesome. I'm going to use them on a Hangar 9 Hellcat I have been refinishing, but I got to ask do you have a rough price for the surface details.
Dan
Hide Signatures
       Post #: 630
RE: The RCFW Hellcat Group Build - 10/9/2012 5:13 AM
Chad Veich
Score: 265
Status: offline
Dan
Introductory price will be $25 + shipping for the first batch out the door. May have to bump the price up a bit after that if they take longer to produce than estimated.
Hide Signatures
       Post #: 631
RE: The RCFW Hellcat Group Build - 10/9/2012 5:19 AM
ihaveahellcat
Score: 100
Status: offline
That sounds very reasonable, I will buy a set if they are available, I will e-mail you my information.
Dan
Hide Signatures
       Post #: 632
RE: The RCFW Hellcat Group Build - 10/19/2012 3:38 PM
HellcatFlyboy
Score: 100
Last Login: 1/2/2013
Status: offline
Hi All! I just ordered my plans & parts from Chad- can't wait to get started building. Much appreciate this forum for building tips, issues and sharing ideas! I'm sure I'll be accessing these pages once I get going.
Hide Signatures
       Post #: 633
RE: The RCFW Hellcat Group Build - 10/29/2012 9:59 PM
Chad Veich
Score: 265
Status: offline
Progress has been made on the surface detail kits which are now available. The basic kit includes the laser cut vinyl hatches, inspection panels, fasteners, and rib tapes as well as printed plans showing placement. As noted previously the plans are at 1/16 scale, half that of the model, and can be used as a guide for panel line placement as well. I will also include an instruction sheet on applying the vinyl.
Not included in the kit above, but also available, are rivet sheets. These will be sold by the sheet, each of which contains just over 750 rivets. I have not had time to figure out just how many rivets are needed but I'm working on it. Actually, there are a couple of different options depending on the builder's preferences. The full size Hellcat uses both raised and flush rivets and on my prototype I used the vinyl on the fuselage and tail to represent the former, and then burned in the rivets on the flying surfaces to represent the latter. Obviously that requires a lot less vinyl rivets then if you were to rivet the entire airframe with vinyl. Also, I only riveted along the panel lines and did not do the intermediate rows of rivets. Last, but not least, please be aware that the rivets as provided are both larger than scale in diameter and further apart. I did this for two reasons. One, so that less rivets were necessary to get a satisfactory result and, second, to match the diameter of the burned in flush rivets. Sport scale, remember! So, there are many variables that come into play in regards to the rivets which is why they are not included in the surface detail kit. Each builder can decide how they want to proceed and then purchase however many sheets of rivets are necessary.
PS - If you just have to have the scale diameter/spaced rivets I would be happy to discuss it. It's not a problem but will, obviously, be more expensive to produce.
Hide Signatures
(in reply to HellcatFlyboy)
       Post #: 634
RE: The RCFW Hellcat Group Build - 10/29/2012 10:00 PM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: HellcatFlyboy
Thanks for checking in! I'm looking forward to your build and hope you will share it with the group here.
Hide Signatures
       Post #: 635
RE: The RCFW Hellcat Group Build - 10/30/2012 2:16 PM
HellcatFlyboy
Score: 100
Status: offline
I'll definitely be posting and sharing here Chad, once I begin. I'm going to send you an outside email on this- I think I now should get the exhaust outlets now that I think about it. Since you haven't sent all the other vacuum formed parts and cowl yet- maybe you can add the exhaust outlets/waste gate belly pan to the order and i'll send you a cheque to cover that extra cost? I'm pondering the surface detail kit now (but it'll be ordered in the future, not ready to yet) - I see it's $25 plus shipping. Did I miss how much you're going to charge per sheet, for the rivets?
Hide Signatures
       Post #: 636
RE: The RCFW Hellcat Group Build - 10/30/2012 10:30 PM
Chad Veich
Score: 265
Status: offline
Looks like I can produce the rivets at $5 per sheet plus shipping. That will be the introductory price at least. If necessity demands the price may have to go up a bit on orders of just a sheet or two. On larger orders the $5 per sheet should suffice. As noted above each sheet contains just over 750 rivets.
For those who may be interested I can also produce rivets of any size and spacing for your other scale projects as well. As soon as time permits I will do a quick post on how I apply the rivets with some pictures and explanation of the process.
Hide Signatures
       Post #: 637
RE: The RCFW Hellcat Group Build - 10/31/2012 12:00 AM
tdstaf
Score: 103
Status: offline
Chad,
Are you doing the cutting of the hatches and would you be willing to to cut some for my German projects?
If so how large are the sheets and what format would you need?
Thanks Tim
_____________________________
Who says scale warbirds have to be GIANT.
Hide Signatures
       Post #: 638
RE: The RCFW Hellcat Group Build - 10/31/2012 1:21 AM
Ram-bro
Score: 156
Status: offline
Chad, thats the ultimate question are you offering your services?
Hide Signatures
(in reply to tdstaf)
       Post #: 639
RE: The RCFW Hellcat Group Build - 10/31/2012 5:20 AM
Chad Veich
Score: 265
Status: offline
Tim and Ram,
I'm just an email away! Always glad to discuss anything you guys might need.
Hide Signatures
(in reply to Ram-bro)
       Post #: 640
RE: The RCFW Hellcat Group Build - 10/31/2012 1:05 PM
HellcatFlyboy
Score: 100
Status: offline
Chad, ok thanks. i'll be placing my order next week I think.
I know you haven't come up with a total count of how many rivets would be needed assuming all were the raised vinyl ones, but how about a very rough estimate?
Hide Signatures
       Post #: 641
RE: The RCFW Hellcat Group Build - 10/31/2012 6:10 PM
Chad Veich
Score: 265
Status: offline
A rough estimate is about the best I can do as it would be an exercise in frustration to try and accurately count them! I did spend a half hour or so last night doing my best to come up with a relatively accurate estimate of what I used on my prototype. I've rounded up thinking it's better to have a few too many than not enough! Keep in mind this is what I used on my model and not anywhere near the number of rivets to be found on the actual airplane.
Fuselage & Vertical Fin - Approximately 2500 total rivets of which about 2000 are vinyl and the rest are burned. On the full size Hellcat basically everything forward of the cockpit is flush riveted while everything aft has raised rivets. This is a generalization of course and if you want to be really accurate some research will be in order.
Horizontal stabs - Approximately 900 total rivets, all of them flush.
Wings - Approximately 4500 total rivets, all of them flush. The reason the wings have so many more rivets than the fuse is because the skins are butt jointed which requires a row of rivets on either side of each panel line. The fuselage is primarily overlapped panels which only requires a single row of rivets along each panel line.
So there you have it! On my prototype I have approximately 2000 or so vinyl rivets with another 5000 or so done using the soldering gun/brass tube method. For those who would like to get a more accurate estimate you can figure out how many linear inches of rivets you need and then figure 5 rivets per inch. For those of you who wish to use the vinyl rivets on the entire airframe I'm sure I can get the price per sheet down a bit on large orders.
Hide Signatures
       Post #: 642
RE: The RCFW Hellcat Group Build - 11/6/2012 5:46 AM
Chad Veich
Score: 265
Status: offline
Guys I am absolutely swamped right now with an architectural model that has to be done a week from today. If you've contacted me about ordering anything, or if you have ordered something and have not heard from me in regards to payment or shipping, pleast sit tight. I will get to you ASAP but I've got to pay the bills first. Architectural models are usually a good source of revenue but they always seem to come with a rediculous deadline! Thanks for your patience.
Hide Signatures
       Post #: 643
RE: The RCFW Hellcat Group Build - 11/24/2012 1:04 AM
Chad Veich
Score: 265
Status: offline
While much of the country is settling in for their building season we here in Phoenix are just starting our flying season. Today was one of those rare days with perfect skies, absolutely zero wind, and temps around 80 degrees. Perfect flying weather and I got in two good flights to start off the season. First flying I had done in about 6 months. My good friend Joe Balabon met us at the field with his "cannon" and one of the results can be seen below. Joe says there are many more coming but just this one makes the whole day worth it. Looks like I may need to adjust the linkage on the tail wheel retract a bit though! I'll post more as I get them from Joe.
< Message edited by Chad Veich -- 11/24/2012 5:43 AM >
Hide Signatures
       Post #: 644
RE: The RCFW Hellcat Group Build - 11/24/2012 3:26 AM
JohnMcGowan
Score: 110
Status: offline
That is a GREAT shot Chad!!  Man your plane looks fantastic.
I hope you had a wonderful Thanksgiving too.  I havent spoken to you in a while , but I had major knee surgery on my left knee a few months back ( meniscus, ACL and tendon repair along with some nice screws in there to hold things together).  I went thru 6 weeks of rehab and Im still having problems with pain and  I still limp. . So now the Dr wants me to go back and do MORE rehab. Like when I am I going to have time for that???    I hope your new  knees are doing better than mine
Take care buddy,
John
Hide Signatures
       Post #: 645
RE: The RCFW Hellcat Group Build - 11/24/2012 3:33 AM
Ram-bro
Score: 156
Status: offline
Beautiful shot Chad, beautiful airplane....Now since this is your flying season, when is your building season? I thnk your just rubbing it in man.....
Hide Signatures
(in reply to JohnMcGowan)
       Post #: 646
RE: The RCFW Hellcat Group Build - 11/24/2012 3:50 AM
grh_70
Score: 100
Last Login: 5/20/2013
Status: offline
Uh Oh, what's that pilot doing in a target drone? Hope his chute works!
Maybe he is just testing the avionics.
GeneH
Hide Signatures
       Post #: 647
RE: The RCFW Hellcat Group Build - 11/24/2012 6:02 AM
Chad Veich
Score: 265
Status: offline
Hi John, good to hear from you. Sorry to hear that your knee surgery is not getting the job done. Maybe you should just have them replace it entirely! That's what they did with both of mine and it has been nothing short of a minor miracle for me. Now the doc says it's time to replace the shoulders! I'm trying to hold off on that for at least another year but we'll see how that goes.
Building season is all year round Ram but only for those lucky enough to have access to an air conditioned space. I pretty much can't do anything in my garage from June through September due to the extreme heat. Luckily both my father and brother have shops with AC so I just "bum" off of them during the hot months! I do have a very small air conditioned space for the laser cutter so at least I can keep designing and cutting during the summer.
Gene, the Hellcat was out on a "maintenance flight" so the pilot was not in any immediate jeopardy. At least not of being shot down anyway! Actually if pictures are any indication the drones were flown by live pilots much more often than they were flown remotely.
Thanks guys for the all the kind comments and stay tuned for more pictures. Also stay tuned for the imminent return to construction on Hellcat number two. I've got the wing back down out of the rafters and I'm determined to get the flaps wrapped up before the end of the year. They have been a real learning experience and I'll be VERY happy to move on to other aspects of the build for sure.
Hide Signatures
(in reply to grh_70)
       Post #: 648
RE: The RCFW Hellcat Group Build - 11/24/2012 12:46 PM
HellcatFlyboy
Score: 100
Status: offline
 Beautiful shot of your hellcat, Chad! Before i go on about the photography, what's the colour scheme of the 2nd hellcat, by the way?
I can appreciate Joe's capture of your hellcat in flight- I'm a photographer myself, but i don't normally shoot action photography. I've found on the few attempts ive made at shooting RC flight, that it's difficult to get the plane in crisp sharp focus (the camera's autofocus has to be quick) and get the right shutter speed to have the prop come out blurred and not appear stationary. (By having too fast a shutter speed) Looking forward to joe's other shots to come.
Hide Signatures
       Post #: 649
RE: The RCFW Hellcat Group Build - 11/24/2012 5:02 PM
Chad Veich
Score: 265
Status: offline
Thanks HellcatFlyboy, much appreciated. In regards to the 2nd Hellcat I'm assuming you mean the one I'm currently building? It will most likely be finished in a post-war Naval Reserve scheme similar to the one seen here:
As far as Joe's photo technique for action shots I think it's primarily a numbers game combined with some very high end equipment. His camera rattles off frames like machine gun! Beyond that I can't really comment as I am completely photography illiterate. Joe visits this thread once in a while so maybe he will chime in with more info.
My first take off of the day was satisfactory but this one, number two, I let the left drift get the better of me which is why I'm out over the dirt as the Hellcat breaks ground. Like most tail draggers the Hellcat wants to hook left pretty hard as the tail starts to come up. That's about the same time the rudder really starts to become effective as well and over compensating with right rudder is easy to do. Then the tendency is to over-compensate the other way! It's a bit of a balancing act for a second or two but once the tail is up it's easy to keep straight. I think I will try increasing the expo on the rudder a bit more and see if that helps. Please note that despite what I've written above the Hellcat is much easier to manage on the ground than many other fighter types I've flown.
Gear coming up.
I really love this shot of the gear coming down but sharp eyes will note the missing cowl flap! The .91FX was running better yesterday than it ever has and the Hellcat was moving along at a pretty good clip. Apparently it was moving faster than the cowl flap wanted to go! An easy fix but I definitely recommend a solid glue joint and some glass cloth reinforcement should any of you builders choose to go with open cowl flaps. (Highly recommended for engine cooling.)
< Message edited by Chad Veich -- 11/24/2012 7:21 PM >
Hide Signatures
       Post #: 650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.016RCU1
