elevator setup
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Jet Legend L39 Albatross - ARF
Seller:  Malcolm Kay
Details:   $2,550.00   |  11/18/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> elevator setup
Page: [1]
Login
elevator setup - 10/20/2009 11:43 PM  1 votes
makaveli956
Score: 120
Last Login: 11/22/2009
Status: offline
when I set up my planes should I set my elevators with little up elevator as my setting or should I leave them in a neutral state for takeoff
Hide Signatures
       Post #: 1
RE: elevator setup - 10/20/2009 11:50 PM
Mr67Stang
Score: 125
Status: online
I will genrally set it with a very slight up angle for a maiden flight. Really I set tit neutral but use the radio trim up slightly. I do this because I would rather fight a climbing aircraft on a maiden than one that wants to dive.
_____________________________
He who dies with the most toys wins!
Hide Signatures
(in reply to makaveli956)
       Post #: 2
RE: elevator setup - 10/20/2009 11:53 PM
daveopam
Score: 109
Last Login: 11/21/2009
Status: offline
I always start level and then trim it in flight. If you start with up and the plane needs down, it just take longer to get right. Besides, if a plane needs quit a bit of up to fly straight and level I am going to change the CG or the thrust to fix it anyway.
david
"Never use a big word when a little filthy one will do"
Johnny Carson
Hide Signatures
(in reply to Mr67Stang)
       Post #: 3
RE: elevator setup - 10/21/2009 12:42 AM
Villa
Score: 100
Status: offline
Set it neutral.
Hide Signatures
(in reply to daveopam)
       Post #: 4
RE: elevator setup - 10/21/2009 1:58 AM
beau0090_99
Score: 110
Last Login: 11/20/2009
Status: offline
Neutral and neutrally balanced. You won't be sorry with this setup.
Curtis
Hide Signatures
(in reply to Villa)
       Post #: 5
RE: elevator setup - 10/21/2009 2:49 AM
beachbrada
Score: 165
Status: offline
quote:
ORIGINAL: beau0090_99
Curtis
Ditto.
There''s no such thing as a cheap mistake in this hobby.
Hide Signatures
(in reply to beau0090_99)
       Post #: 6
RE: elevator setup - 10/21/2009 3:42 AM
Moms Mistake
Score: 110
Status: offline
Usually I set the elevator trim to neutral and the cg very SLIGHTLY in the positive angle. Like Mr67Stand says, it's much better to have a climbing plane than one that wants to dive. I say set the elevator neutral and cg slightly up beacuse from my experience ( 22 years ) 9 out of 10 times the plane will want to dive if the cg is spot on. Once you gain experience this topic won't be all too important.
Good Luck...
Show me a hero and I''ll prove he is a bumb, Gregory (Pappy) Boyington.
Hide Signatures
(in reply to beachbrada)
       Post #: 7
RE: elevator setup - 10/21/2009 4:22 AM
gaRCfield
Score: 111
Status: offline
I keep everything neutral. Smooth and steady take-off, gradual climb to lots of altitude, then start trimming. I'm holding up elevator during the whole climb out, so holding a little extra elevator, if need-be, isn't a big deal.
Never try trimming a plane on maiden until you're at an altitude high enough that you can be relaxed and have fun with your new plane.
Joe Marri
Venus II/YS FZ110s; Venus 40/OS 55AX; 69"Yak/OS 120AX; Airtronics RDS-8000
Hide Signatures
(in reply to Moms Mistake)
       Post #: 8
RE: elevator setup - 10/21/2009 11:57 AM
CGRetired
Score: 110
Status: offline
Maiden flights are always the most challenging. Not because they are hard, but because of the anticipation of a hopeful first flight, and because of the butterflys in your stomach. So, no matter what you do, neutral, a little up, doesn't matter. The butterflys will still be there, at least until you get it up and trimmed for straight and level flight.
With that said, I set my trim for that maiden flight to as close to neutral as I possibly can.
This is how I do it:
Before I hook up the linkage, neutralize the transmitter sticks, and set the servos to neutral. Make sure that your servos are where you want them to be with the stick and trim centered, in other words. This is very important because you do not want to induce artificial trim by forgetting to neutralize both the transmitter and the servo(s) in use. I also leave the transmitter on so that the servos are "locked" in that position.
For the ailerons, I use two pieces of thin ply, about 5 inches long by three inches wide, and clamp them to the wing so that they sandwich the control surface. This places the control surface right in the center and pretty much neutral with the wing surface. If you have a flat bottom wing, it will tend to keep the bottom of the aileron, for instance, straight with the bottom of the wing.
For the elevator, I also use the two pieces of ply as I stated above. And, it doesn't matter if you have a wing-foil type of horizontal stab, or a flat horizontal stab, this works just fine. After this is done, and you are sure the control surface is straight with the wing or stab, connect up the linkage, adjusting the linkage so that it neither pulls nor pushes on the ailerons or elevator, in other words, they remains neutral.
Remove the clamps and the ply, and test the ailerons and elevator.
For your first flight, gradually but quickly add power during the take off roll to full throttle and carefully pull in elevator till the plane climbs and hold this until you are high enough to comfortably remove some throttle and elevator and then turn to pass by in front of you then trim out the elevator. You may be doing several things at the same time, adjusting roll rate to zero, and elevator trim. Do this with no change in throttle, keeping it between half and 3/4 setting so nothing changes and you can set for straight and level flight.
Once done, just fly it to get used to your new plane.
This is probably more than you asked for, but others may be interested in the information.
CGr.
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
(in reply to gaRCfield)
       Post #: 9
RE: elevator setup - 10/23/2009 12:41 AM
TedMo
Score: 100
Status: online
From the replies you already have I believe you found what you asked. Would just like to mention something I feel is very important. Once you have decent altitude straight and level go to high throttle and give sudden up elevator. This will result in a nice tight loop, OR a snap to left. If it snaps you have too much up elevator for that plane. Some planes are very touchy that way, most are not but this is good to find out. Not likely on trainer types.
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
