Will a slanted elevator effect my flight
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld BAe Hawk - ARF
Seller:  rambat1
Details:   $17,500.00   |  10/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Will a slanted elevator effect my flight
Page: [1]
Login
Will a slanted elevator effect my flight - 7/3/2003 12:28:33 AM
flyingjake
Status: offline
When i fixed my Super Sport I noticed that the right side of the elevator is lower than the left. Would this effect the flight characteristics.
Jake
       Post #: 1
Will a slanted elevator effect my flight - 7/3/2003 12:41:13 AM
C_Watkins
Status: offline
Depends on how bad it is, really. All you can do is fly it and see.
It "could" impart significant "rudder" action on elevator application,
and if it's bad enough, it "could" even require a lot of rudder to trim out,
even to attain "straight and level flight". If you're going to be practicing pattern,
tear it down and fix it right. If you're just sport flying, and one side isn't
more than about 3/8" below the other, you probably won't even notice it that much.
Truthfully, I've flown planes that were even worse off than that.
I repaired a swizzle stick once, in my early RC days, that had to be off by an inch.
I honestly couldn't tell much difference in flight, once I had retrimmed.
Fantastic plane, that one. It also had the covering ripped from both inside
rib bays, from me constantly folding my gear up. After the second time, I sealed
the pieces to the inside, and flew with the inside bays "open" because I was lazy
Well, that, and I just pretty much sucked at landing, back then.
(in reply to flyingjake)
       Post #: 2
Will a slanted elevator effect my flight - 7/3/2003 12:42:00 AM
bearmech
Status: offline
How much lower? It will effect the way it flys.
_____________________________
It's only a flesh wound!!
       Post #: 3
Will a slanted elevator effect my flight - 7/3/2003 12:47:28 AM
flyingjake
Status: offline
look at this pic of it
Click to see fullsize image.
Click for fullsize
       Post #: 4
Will a slanted elevator effect my flight - 7/3/2003 1:04:59 AM
tiggerinmk
Status: offline
My Sturdy Birdy looks a bit like that from the back. I've tried twisting the aluminium channel but it just springs back. Last time I got it back in the air after some 'adjustments' it required a bit of aileron trim, you'd never notice it in flight...
You should be ok unless you want to do precision aerobatics...
If you can remain calm, while all around you is chaos...
then you probably haven't completely understood the seriousnes
       Post #: 5
Will a slanted elevator effect my flight - 7/3/2003 2:03:00 AM
MinnFlyer
Status: offline
Fly it. It won't cause you to crash.
If you feel that it was way better before, break it off and reglue it.
If you think it's ok as is, then just leave it.
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
       Post #: 6
Will a slanted elevator effect my flight - 7/3/2003 2:12:18 AM
Giant Scale
Status: offline
Your best bet is to remove and reglue it.
       Post #: 7
Will a slanted elevator effect my flight - 7/3/2003 7:24:33 AM
DBCherry
Status: offline
[QUOTE]Your best bet is to remove and reglue it.[/QUOTE] If it's really easy to do. Otherwise, don't bother.
You may have to put in some aileron trim to straighten out the flying characteristics, but it's not a pattern plane.
Dennis-
He who dies with the most toys is, none the less, still dead.
       Post #: 8
Will a slanted elevator effect my flight - 7/3/2003 11:54:41 PM
Giant Scale
Status: offline
If any of my planes were that crooked it would drive me crazy...I just like to build straight planes.
       Post #: 9
Will a slanted elevator effect my flight - 7/4/2003 12:15:42 AM
rcflier_gi
Status: offline
My nephews Avistar is worse than that and it flies fine. I wouldn't worry about it.
Current airworthy planes :
SIG Mayhem 3D w/OS 1.20FS pump
       Post #: 10
Will a slanted elevator effect my flight - 7/4/2003 2:10:40 AM
Geistware
Status: offline
I twill not make a big difference.
Enjoy yourself!
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 11
Will a slanted elevator effect my flight - 7/4/2003 2:17:21 AM
_kearney_
Status: offline
I had a similar problem but never noticed and problems flying.
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
