Problem with Lynx 3D TX
Tower Hobbies
Logged in as Guest
  Printable Version
JR PCM 10X Heli
Seller:  chritrinh
Details:   $500.00   |  11/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Problem with Lynx 3D TX
Page: [1]
Login
Problem with Lynx 3D TX - 7/3/2003 9:31:04 AM
jsmax
Status: offline
Hi, I am having a problem with my Lynx 3d Tx. Channel 1 (Steering) is glitching bad. If I am in edit mode watching the EPA for CH 1, it sits there and bounces back and forth from -125 to +125 really fast, without me touching the steering wheel. I have tried changing the EPA to -100 and +10, but still does the same thing. I pulled off the spectra module and reset it, and pulled the battery out and reset it, but still no change. It does not matter if I have the RX's powered on or not. It has gotten bad enough now that you can not even use the TX. Any help would be appreciated. Thanks.
_____________________________
JSmax
       Post #: 1
Problem with Lynx 3D TX - 7/4/2003 12:15:24 AM
MikeMayberry
Status: offline
Sorry to hear about the problem. It sounds like you are going to need to send it in for repair.
Here's the info: http://www.rcuniverse.com/forum/tm.asp?m=364127
Mike..
(in reply to jsmax)
       Post #: 2
Problem with Lynx 3D TX - 7/4/2003 9:04:04 AM
jsmax
Status: offline
Hi, Looks like I might have figured it out. The steering wheel tensions screw was pretty loose. I thightened it up quite a bit. I took it out and played for around 20 minutes with no more glitches. We will see how it goes.
JSmax
(in reply to jsmax)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU2
