ceramic bearings and Jett engine
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
VooDoo Modified Engine Mod Service - RTR
Seller:  VooDooModified
Details:   $75.00   |  3/11/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> ceramic bearings and Jett engine
Page: [1]
Login
ceramic bearings and Jett engine - 10/29/2009 1:35 AM
jplavoie
Score: 100
Last Login: 1/20/2010
Status: offline
Hi Bob,
I would like to know your opinion about using ceramic bearings in Jett engine. In theory, they last longer but I wanted to know if they really worth extra $$.
Hide Signatures
       Post #: 1
RE: ceramic bearings and Jett engine - 10/29/2009 2:46 AM
bob27s
Score: 100
Last Login: 3/21/2010
Status: offline
In brief, in the Jett engines the answer is no.
But there is no reason you could not use them if you wish. Typically good products if you get the right one for the job. Ceramic bearings do help out in some engine applications where added durability is needed.
The stock jett bearings are very good, good lubrication paths within the engine, and if you take care of the engine, they last for ages. They are properly sized for the engines (usually the issue with other engines prone to bearing failure). So they wear very little, and very rarely mechanically fail.
My racing engines get new bearings at the end of each season. The sport engines .... last set I changed out was in my SJ50, and that was 3 years ago (that engine is 10 years old).
The only other times I have had to replace a bearing was after a crash or dirt otherwise got into the front bearing, or one time where I was careless and left a "wet" engine sit in my basement for a few months - rusted the crud out of the bearings and crankshaft. My bad there. When I have need to change one bearing, I will change both as a set.
If you do not take care of the engine, even ceramic bearings will fail.
Rust or other foreign matter on the races is the main failure mode for most model engine bearings. Caused by not running the engine dry, or proper used of occational after run oil. Even ceramic bearings will fail if they get pitted or rusted. Some bearings I ran across a few years ago in an import engine were made with poor quality steel races that will rust if you breath heavy on them (exageration).
I hope this is helpful
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
(in reply to jplavoie)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.215RCU1
