Mini Boy
Joined: 2/4/2003 From: Webster, MA, USA Status: offline
Hi Z! In general, receivers are really not very heavy devices. Assuming that the receiver is compatible with your transmitter, and judging by your pic of the receiver and the gyro, I would guess that it won't make much of a difference ... AND the slightly larger size won't make much of a difference for location or mounting either. My best guess is that the extra weight of the metal gear servos that most folks use would be considerably greater than the extra receiver weight, and nobody seems to worry about the extra servo weight. Plus, you'll have extra channels to run a rescue winch, drop sky divers and water balloons, take videos and the whole works!!! For what it's worth, Russ
_____________________________
Enjoy The Weather, It's The ONLY Weather You Have!
