RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/14/2009 1:17 PM
muck76
Score: 100
Last Login: 1/27/2010
Status: offline
well hopfully he reads this and responds... I may have to hop on RCGroups if that is where he is posting more info..
Hide Signatures
(in reply to aluminum crusher)
       Post #: 26
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/14/2009 1:24 PM
aluminum crusher
Score: 100
Last Login: 3/21/2010
Status: offline
Yeah that's the more info place on the bikes shoot him a pm.
_____________________________
YOUR'S TRULY....YOUR FRIENDLY NEIGHBORHOOD ALUMINUM CRUSHER!
Hide Signatures
(in reply to muck76)
       Post #: 27
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/14/2009 3:42 PM
microDan
Score: 100
Last Login: 3/22/2010
Status: offline
Thanks AC,
The gyro is extremely heavy and powerful. For a beginner it works great. For someone with a little more experience all the added weight is not needed.
Thr gyro remains intact other than removing all the added 5 weights and retaining rings and screws.
This takes off almost 1/4 lb of weight and the bike bike actually becomes easier to handle and more responsive and a bit faster and the brakes work better.
The gyro is still there doing a great job but just less powerful.
I also think doing this mod is better for the whole drive train too not having to heave all that weight.
< Message edited by microDan -- 12/14/2009 6:00 PM >
Hide Signatures
       Post #: 28
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/14/2009 9:47 PM
monsterbrad
Score: 100
Last Login: 3/3/2010
Status: offline
so you are saying that taking the a few of the weights out helps this bike?
still waiting for some video
Hide Signatures
(in reply to microDan)
       Post #: 29
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/14/2009 10:22 PM
muck76
Score: 100
Status: offline
the manual states that removing the weights helps also but you have to do it in an equal format to remain balanced..
Man i want to see one of these!
Hide Signatures
(in reply to monsterbrad)
       Post #: 30
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/15/2009 12:09 AM
monsterbrad
Score: 100
Status: offline
check youtube there are a few vids up now that are new nothing real great yet
Hide Signatures
       Post #: 31
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/17/2009 3:44 AM
Goomba_7
Score: 100
Last Login: 12/27/2009
Status: offline
Microdan- So I just want to get this straight you removed the weights in rear wheel and left everything else?? I ask because the changing of direction with the stock setup is a little slower then I'd like.
Now I know! Knowing is half the battle, Go Joe!!!
Hide Signatures
       Post #: 32
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/17/2009 6:57 AM
microDan
Score: 100
Status: offline
Goomba7,
Yes, I opened the rear wheel, have the manual near by :-) remove the retaining rings and screws and weights. Leave all those parts out, weights, rings and screws. Reassemble.
Now go for a ride.
I did this for the head shake (tank slapper)
A TTN steering damper installed and now it's rock solid.
Hide Signatures
(in reply to Goomba_7)
       Post #: 33
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/17/2009 12:40 PM
muck76
Score: 100
Status: offline
so do you think this bike will do well off road? From the vids i have seen so far it seems bouncy..
Hide Signatures
       Post #: 34
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/17/2009 4:06 PM
microDan
Score: 100
Status: offline
I ran it pure stock on a grassy field & baseball field. It was bouncy as you say the rear spring needs heavy oil and more spring preload. And the head shake as it hit little divots of grass and such made it look like a wheel wobble machine. On the dirt infield it just cuts a groove in the dirt for the whole length with the rear tire
I used 1000 wt diff oil, stretched the spring about 1/4" used a TT spring spacer and moved the shock to the first hole in the frame.
It's much better now but not perfect. The suspension is just too soft from the start. On road it goes good no matter how the suspension is.
I have not ridden off road since installing the steering damper. I'm sure it's going to make a big improvement as it did on road.
Hide Signatures
       Post #: 35
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/17/2009 6:33 PM
muck76
Score: 100
Status: offline
is that damper a parts used for on-road bikes?
Hide Signatures
       Post #: 36
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/17/2009 9:48 PM
microDan
Score: 100
Status: offline
Yes the damper is from a stock Thunder Tiger Nitro 1/5 Ducati. You can buy them for about 6 or 7 bucks. You can use oil in them for more or less dampening, I think I left mine empty and just using the springs.
Hide Signatures
       Post #: 37
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 1:15 AM
monsterbrad
Score: 100
Status: offline
this is good to see that the bike is ok
alot of people are worried that it is a junky duratrax item
those are some nice modd ideas already guys I hope to have 1 of these eventually
Hide Signatures
       Post #: 38
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 1:16 AM
muck76
Score: 100
Status: offline
i am one of those worried, mainly because the area i run is not smooth like a field or street.
Hide Signatures
       Post #: 39
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 1:30 AM
srt10
Score: 107
Status: offline
I saw one of these today and they look very cool!
maybe something next to get
first to own the Mini Slash!
Amsoil Dealer.. UL-1, 6XL Revo, Baja 5B, Detta ST, SportWerks Recoil, Losi 8T, Gas KOS, Ru
Hide Signatures
       Post #: 40
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 1:36 AM
microDan
Score: 100
Status: offline
monsterbrad & muck76,
This bike is very impressive overall. It is well built, engineered and does what it's supposed to extremely well.
I don't know if you're aware of the STRESS TECH parts warranty. Certain ST plastic parts are covered for one year.
You break a ST part, return it and it gets replaced for free. They are standing behind the bike.
The plastic / polymer parts are extremely strong I can't believe how strong the plastic is.
Just my opinion but this is one of the best RTR's I've seen and run. Other than the few mods I've done it is RTR and only gets better with a few simple mods.
You have to remember you're getting a (basically) re-badged Anderson M5 and the M5 has a proven reputation.
Have no fear in this model, I know DuraTrax has had a few lemons and got known for DuraTrash.
But they have redeemed themselves with the DX450. I'm not to easy to please, I'm ecstatic about what they've done here.
I haven't had this much fun in a looooooong time. Get one and I'm sure you'll be more than happy
Hide Signatures
       Post #: 41
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 2:01 AM
srt10
Score: 107
Status: offline
do they stay up well?
Hide Signatures
       Post #: 42
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 3:27 AM
microDan
Score: 100
Status: offline
YES, they stand up due to the gyro and can go very slow and still stand up. They are very stable check the video at DuraTrax.
DuraTrax DX 450 video
< Message edited by microDan -- 12/18/2009 5:22 AM >
Hide Signatures
(in reply to srt10)
       Post #: 43
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 2:57 PM
urs856
Score: 100
Status: offline
hi! does 1/10 th motor 5700kv works on this bike?
Hide Signatures
       Post #: 44
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 4:56 PM
microDan
Score: 100
Status: offline
Yes the 5700kv would work perfectly DuraTrax has an optional 5900kv made for the bike and a 4800kv.
Hide Signatures
(in reply to urs856)
       Post #: 45
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 5:22 PM
muck76
Score: 100
Status: offline
Is the ESC a water resistant like the EZRuns?
Hide Signatures
       Post #: 46
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 5:28 PM
microDan
Score: 100
Status: offline
Good question. I guess you could contact DuraTrax and find out.
Hide Signatures
       Post #: 47
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 5:51 PM
muck76
Score: 100
Status: offline
Does it have a name on the ESC? The pics i have seen, it looked like an EZRun.
Hide Signatures
       Post #: 48
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/18/2009 7:54 PM
srt10
Score: 107
Status: offline
quote:
ORIGINAL: microDan
those power slides are awesome!
Hide Signatures
       Post #: 49
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 12/20/2009 12:36 AM
microDan
Score: 100
Status: offline
Speed Report with stock 3800kv motor.
I ran the bike today to see what a 16T pinion would do. 13T pinion is stock.
With a 2s lipo the speed went from 28.9 stock pinion to 33.0 mph on the 16T.
With 3s lipo the bike went from 33.8 stock to 40 mph on the 16T.
I thought this would also tame the wheelies down..... NOT!!! It still takes trigger control to keep the front wheel on the ground. The 16T pinion is going to stay in there
Hide Signatures
(in reply to srt10)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.859RCU1
