RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle
Page: <<   < prev  5 6 7 8 [9] 10 11 12 13 14   next >   >>
Login
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/24/2010 4:36 AM
nano cup
Score: 100
Last Login: 3/16/2010
Status: offline
Vintage Guy,  I had to make my axle ,4mm rod drilled and taped.Working on rear disc now, and have GRD road tires f+r. Like the Vintage Guy ,as i race vintage moto/cross with AHRMA. This DX 450 to cool, I have two.
Hide Signatures
(in reply to microDan)
       Post #: 201
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/24/2010 5:26 PM
Vintage Guy
Score: 100
Last Login: 3/15/2010
Status: offline
I dont have access to a Lathe, so a buddy of mine is making about ten front axles for me.  Ten because by summer all of my RC buddies will have this bike!  We also race 1/18 scale xrays. http://www.harnoishobby.com/
Thanks for all the info guys
Vintage Guy
_____________________________
Vintage Guy
Hide Signatures
(in reply to nano cup)
       Post #: 202
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/25/2010 4:57 AM
Vintage Guy
Score: 100
Status: offline
Alright Micro,
Now that I have looked at it, My thunder tiger front tire is smaller than the duratrax.  SO how the hell did you just stretch the tire over the knobby?
VG
PS I have a buddy making some axles for the front so you can use the thunder tiger rim if you wanted.
Vintage Guy
Hide Signatures
       Post #: 203
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/25/2010 5:14 AM
microDan
Score: 100
Last Login: 3/20/2010
Status: offline
VG,Yep the TT front tire is smaller. I used a Nuova Faor soft compound slick. The tire was tight but stretchable over the stock knobby. The softer the compound the easier it is.
You cannot use a stock tire from a TT bike. The tires are so hard it's impossible to stretch, also that's why the tires are NG they have no traction. I also have GRP & PMT tires that could be used.
Using the TT wheel & tire IMO took away from the scale look of the bike with the smaller diameter wheel & drops the ride height.
Hide Signatures
(in reply to Vintage Guy)
       Post #: 204
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/25/2010 7:05 PM
MonsterMash15
Score: 100
Last Login: 3/14/2010
Status: offline
So resently I bought a DTX 450
Like a lot of people in the hobby I'm not one to let well enough alone. So I started to check out how the bike was put together and check to see if anything could use improvement.
After looking at the rear suspension I discovered a fair amount of play in mounting hole of the rear shock down by the swing arm.
Checking it further and on closer examination I discovered that the lower part of the shock was only part of the problem, as there is some flex in the rear sub frame where it is attached to the main frame. This also contributes in part to the play at the rear part of the bike.
My question is that I'm wondering if anyone else's bike does this and if so would I think that their should be a piece made to tie the the main frame and the sub frame for the sake of rigidity.
Hide Signatures
       Post #: 205
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/25/2010 7:24 PM
microDan
Score: 100
Status: offline
It seems all the bikes have or will develop the play at the lower shock hole. I don't really give this a concern at the moment. I tried a brand new shock and it was the same thing.
It would be nice to see a pic of the sub frame area you're talking about having flex and contributing to the play. My bike has the alloy swing arm, not that it matters. The bike is rigid as far as I can see.
Hide Signatures
(in reply to MonsterMash15)
       Post #: 206
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/25/2010 11:50 PM
buddman36
Score: 100
Last Login: 3/1/2010
Status: offline
I found that my bike has a lot of play in the front above the ESC where the inner frame is mounted to the lower outer frame ? but the rear is very nice and solid or rigid with really no play at all. All my problems with the bike is the poor steering and the little head shake that is present at high speed. If I could only get it to steer better I would love it !!?? Need to run it off-road for testing but the dead of winter is here and no good dirt to play in (loose dirt that is) everything is frozen or muddy no happy medium. This bike was designed for off-road so I will tune it to do that, it runs good and is fun in the BIG smooth parking lot I run in now but I'm throwing all the weights back in the Gyro and will concentrate on the off-road part of the bike. Wish in handled like my full size KTM 400 ??? lol. Really if you spend some time tuning this bike it will dial in for any of you who feel this bike is not of good quallity, if I can make it work pretty much any one can, have patience and you will be rewarded. Read all of Micro Dans and some other guys threads and it will all come together !!!
Hide Signatures
       Post #: 207
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/26/2010 7:18 PM
MonsterMash15
Score: 100
Status: offline
I know what you mean. Now if I can just get it to handle like my KTM 950 Supermoto R .
Hide Signatures
(in reply to buddman36)
       Post #: 208
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/26/2010 7:26 PM
MonsterMash15
Score: 100
Status: offline
quote:
ORIGINAL: microDan
I'll try to get a pic , but in the meantime maybe I can discribe it better. It would be better called the back half of the main frame but I call it the sub frame only because thats what its called on my 1 to 1. But till I do, I think I'd got away to at least get a little of the play out at the lower shock mount. I'll keep you posted.
Hide Signatures
       Post #: 209
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/31/2010 6:19 AM
nano cup
Score: 100
Status: offline
Got to spend some time in a smooth parking lot today. motard set up,no weight in the gyro and F+R brakes. Boy does it stop.As for the gyro I think some where in the middle between 0 and the 5 thats stock. There's not many combos for less weight, .none /4/5. I'm goingto try lightining a set. Hey Micro Dan hows your trick light weight gyro comming??.And I know the weather is horrible every where but wait til you run on some dirt ,my face hurts from smiling.
Hide Signatures
       Post #: 210
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/31/2010 6:27 AM
microDan
Score: 100
Status: offline
I got the sample aluminum gyro the other day. Lookin good. It's just been so cold here..... I'm waiting for a few parts to complete my complete gyro build. The modified gyro will be tested as a complete wheel so I can just remove the axle bolts and go from a stock bike to a modified bike to feel & see the differences.
The alum gyro shaves off another 1/4 lb when no weights are used. I heard it is still very stable. But I think the bike will be quicker, respond to inputs better and reduce the beating the clutch and one way bearing take.
Hide Signatures
       Post #: 211
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/31/2010 12:35 PM
ace955
Score: 100
Status: offline
quote:
ORIGINAL: nano cup
Nano could you give us some info on the brake setup you have?I am waiting on delivery of a dx450 and i have been reading as much as i can about the bike.The more i read the more i like my decision to buy.
Hide Signatures
       Post #: 212
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 1/31/2010 6:48 PM
buddman36
Score: 100
Status: offline
Why is my thottle control pulsating on and off , on and off ?? It got pretty hot !! Seems that it is back to normal, was using a 2600 3S Lipo at the time ?? balance showed that the cells were at 3.69 V ? Thermal shutdown or maybe LVC ?? Just wondering why it would do that ?
Hide Signatures
(in reply to ace955)
       Post #: 213
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 6:46 AM
microDan
Score: 100
Status: offline
My bike hit the LVC on 2 & 3s, it cuts at about 3.1-3.2v per cell. It will go dead and then allow a low voltage throttle flow and then go dead and repeat the cycle.
At first sign of this just shut it down to keep things safe.
My stock ESC got very hot on 3s but never thermaled. Maybe if the battery lasted longer it would have.
Hide Signatures
       Post #: 214
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 3:46 PM
glk420247
Score: 100
Last Login: 3/19/2010
Status: offline
Hi guys. I have never herd of or seen this untill today. I Have a lst2 and some other rc planes and such. Just looking for some other fun. My ? is what do you all think fo this product, over all. Looking to buy one of these. Or might spend the money and go with the ARx 540 dirt bike.
Thanks.
Greg
Team Losi Lst2 (Kick azz truck)
Hide Signatures
       Post #: 215
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 10:59 PM
Vintage Guy
Score: 100
Status: offline
Hey GLK
You can spend the money on the ARX if you want, I dont have one, but I dont think it will be that much better to warrant the price.  My opinion on the DX450 is it is by far the Greatest R/C Model ever, FACT!!!!!   Your initial investment is about $350, although one of my local shops is selling it for $300.  You will need to put some more money in it to get it to handle better, but some minor adjustments on the stock one will improve it too.
Even if you buy the DX and put every hop up available right now on it, you will still be well under the price of the ARX.  And I think the furure will bring many more hopups and tire choices for the DX.  Hands down I think the Dx is an excellent buy, go for it, you wont be disappointed!!
Vintage Guy
Hide Signatures
(in reply to glk420247)
       Post #: 216
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 11:46 PM
glk420247
Score: 100
Status: offline
Do you think these hop-ups would work on the Dx450?http://www.andersonmodel.com/products/products_show.php?language=_eng&pid=1991&cid=34&offset=0
Hide Signatures
       Post #: 217
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 11:49 PM
Vintage Guy
Score: 100
Status: offline
GLK
The DX is the Anderson M5, they are the same Machine.  So anything for the Anderson will work for the DX.  Anderson will have some dual sport tires available in march some time.
VG
Vintage Guy
Hide Signatures
       Post #: 218
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 11:51 PM
Vintage Guy
Score: 100
Status: offline
GLK
I looked at the link after I sent the message.  All of that stuf is already available on Tower.
VG
Vintage Guy
Hide Signatures
       Post #: 219
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/1/2010 11:54 PM
glk420247
Score: 100
Status: offline
Thanks bro. Looks like a good buy to me. I will post when I get mine. Looking forward to spend some time with you guys, discussing tips, tricks and self made mods.
Although I am completley happy with my Lst2. I just need something new.
Later Greg
Hide Signatures
       Post #: 220
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/2/2010 12:08 AM
Vintage Guy
Score: 100
Status: offline
GLK
Since you are in Ohio I know you are fighting the snow.  I have been running mine in the parking lots, tore up the stock tire in about 6 or 7 battery runs.  The Thunder Tiger rear tires fit right on the stock rim, not a perfect fit.  The Thunder tiger tire has an extra lip, but it doesnt seem to affect it any.  You can also use a Thunder Tiger front rim with a slick or steet tire on it.  The only issue with the TT Front rim is you need to get an axle made.  The Duratrax axle has a relief in the center and thats where the TT rim sits.  The axle is .236 inches and 43 mm long with m4 threads in both ends.  I have a buddy making me some right now.   I mainly want to run the bike on dirt and jump it, but during the winter I love the supermotard running in the parking lots.  You can power slide the bile around the turns, STOCK, with a NiMh battery in it.  Got my first LiPo for it today, will turn it into an instant wheelie machine, AWSOME!!!!!  Be carefule on the LiPo's they need to have the wires coming out right, the only big flaw in the bike is the Battery box.  The regular stick batteries are a **** to get in, If you have any matched packs you soldered yourself, they dont fit.  Its a small flaw in an awsome machine.  Keep up with this thread, there is already a dude with front and rear disk brakes on his.  I havent read it all but Ive been picking through it little by little.
VG
Vintage Guy
Hide Signatures
       Post #: 221
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/2/2010 10:00 PM
Vintage Guy
Score: 100
Status: offline
Since I am inept at posting pictures with these posts, check out my page on here for my new rear tire.
Vintage Guy
Hide Signatures
       Post #: 222
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/2/2010 10:06 PM
microDan
Score: 100
Status: offline
Here ya' go VG,
Nice job.
Hide Signatures
       Post #: 223
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/2/2010 10:32 PM
Vintage Guy
Score: 100
Status: offline
Had to do something with that worn out knobby!!!
Thanks Micro for posting them.
Vintage Guy
Hide Signatures
       Post #: 224
RE: DuraTrax 1/5 DX450 Brushless On/Off-Road Motorcycle - 2/3/2010 10:43 PM
MonsterMash15
Score: 100
Status: offline
quote:
ORIGINAL: Vintage Guy
I see you made it into an ice racer .
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.547RCU1
