Futaba Fasst and servos from diffrent brands?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 ShowTime 4D 90 ARF - RTF
Seller:  ev-hobbies
Details:   $450.00   |  3/11/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> Futaba Fasst and servos from diffrent brands?
Page: [1]
Login
Futaba Fasst and servos from diffrent brands? - 11/1/2009 8:57 AM
Rune
Score: 100
Last Login: 3/20/2010
Status: online
Hi
I ouhr club peoples are talking about not using other brands for the Futaba fasst system , we also had a big Yak that went down and the reason was what I heard that the guy was using Hitec servos in it , ailron locked in the last turn into landing! He also was told that this could happend prior to the crash.
Has anybody some info on this, I was planning to use some JR servoes in my next plane ...but dont know if it is safe.
_____________________________
Rune Gjelsnes
email: rungjels@start.no
Hide Signatures
       Post #: 1
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 9:52 AM
wagen017
Score: 100
Last Login: 3/14/2010
Status: offline
All I can say I have been flying JRs (8411/9411) for a year now with FASST Futaba receivers without any issues. Before installing the R6008HS I checked all I could (also Futaba's site) and could not find any info against doing this.
What I did notice is that Futaba states multiple times that the receiver must NOT be padded or build in in a way that prevents adequate cooling. So I guess there is (or was) an issue there. This is something your friend might want to check.
Volkert
Club Saito member #371
Hide Signatures
(in reply to Rune)
       Post #: 2
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 10:35 AM
gene6029
Score: 100
Last Login: 3/18/2010
Status: offline
I have several 35% planes ALL with Futaba Fast gear. I only use JR servos, 8411s, 8611s 8711s. I have never had any issues to date. I fly with other pilots that use this same combination and am not aware of any problems useing fast gear with JR servos in their planes either. ......Gene
Hide Signatures
(in reply to wagen017)
       Post #: 3
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 12:52 PM
rcpattern
Score: 100
Status: offline
Rune,
If you are running one of the new HS receivers do not run it in high speed mode. This can cause some issues. Other than that, it should work fine.
Arch
Team Futaba, YS Parts and Service, Central Hobbies, Tarable Graphics, Team Black Magic, Morgan Fuels, Tech Aero Designs
Hide Signatures
(in reply to gene6029)
       Post #: 4
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 1:11 PM
cmoulder
Score: 105
Status: offline
I have been using FASST and Hitec servos together for a year with no problems.
Could have been a lot of things with the big Yak, especially with mulitple servos on one surface.
Bob
Hide Signatures
(in reply to Rune)
       Post #: 5
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 2:25 PM
oisf3a
Score: 100
Status: offline
Hello Rune
I have mixed Futaba, JR/Graupner, Hitec, Savox/Align, HG .... the two last years with no problems at all.
I am planning to use a mix og JR and Futaba servos for my new model for the 2010 season. Will use 6014 or 617 FASST receiver. I have never felt as confident with my RC equipment as after I switched to FASST.... :-)
Oistein
Hide Signatures
(in reply to Rune)
       Post #: 6
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 4:23 PM
najary
Score: 100
Status: offline
Hi Rune,
Take a look at this site
http://www.futaba-rc.com/faq/faq-receivers-q1060.html
Here attached a leter from Savox.
Best regards,
Isaac Najary
Click to see the file in new window.Attachment.pdf
Hide Signatures
(in reply to Rune)
       Post #: 7
RE: Futaba Fasst and servos from diffrent brands? - 11/1/2009 11:03 PM
Nickolas
Score: 100
Last Login: 3/19/2010
Status: offline
In my pattern planes I use Futaba 608 Rxs with a mix of Futaba and JR servos without any issues. On the Sebart Sukhoi 140 I use JR 8411 servos all around and one HiTec HS81 on throttle now issues at all with Futaba 6014. In foamies I use the 617 with a mix of Robbe, Graupner and Futaba no broblems here so far.
Najary I was so stressed when I saw this attachment from Savox, I just got 6 Savox 1256TG last week for my new 35% YAK and thought that I could not use them with FASST receivers. I was so relieved when I saw that was a confirmation letter from Savox...
Rgrds,
Nikos
Click to see fullsize image.
Click for fullsize
Please check my blog:
http://nikolas-3djunk.blogspot.com/
Hide Signatures
(in reply to najary)
       Post #: 8
RE: Futaba Fasst and servos from diffrent brands? - 11/2/2009 5:47 AM
Silent-AV8R
Score: 122
Status: online
quote:
ORIGINAL: rcpattern
Rune,
Arch
I ran a 6008HS in an Abbra with all JR digitals with no issues. Even when I tried out the high speed mode I had no issues, but I also did not see any advantage to it either so I just reset to normal mode.
I also fly 2 gliders with FASST RX (608FS and 6014FS) and JR digital servos, again with no issues.
Reality is Subjective. At least that's what I think.
Hide Signatures
(in reply to rcpattern)
       Post #: 9
RE: Futaba Fasst and servos from diffrent brands? - 11/2/2009 8:07 AM
Rune
Score: 100
Status: online
hmmm
ok...I see what I do.
thanks for answering guys
Rune Gjelsnes
Hide Signatures
(in reply to Silent-AV8R)
       Post #: 10
RE: Futaba Fasst and servos from diffrent brands? - 11/7/2009 9:43 AM
Rune
Score: 100
Status: online
http://www.youtube.com/watch?v=bhsQ-so0lfY
here is a video from that crash..tobad
Rune Gjelsnes
Hide Signatures
(in reply to Rune)
       Post #: 11
RE: Futaba Fasst and servos from diffrent brands? - 11/7/2009 3:48 PM
ExFokkerFlyer
Score: 100
Status: offline
The issue was with the 6014 receiver and it was not the heat issue, that caused problems with some servos. On the 6014, the voltage on the signal wire is dropped to around 2V (not sure exactly what value, but it's markedly reduced compared to other receivers) on channels 3-14. The only servos that I am aware that had the problem if you plugged them in direcetly to the Rx were the Hitec 5955TG, and it wasn't all of them, just the older versions. If you had those or other servos ganged up on a "Y" harness plugged into channels 3-14 you would have an issue too.
I tested it myself on my equipment and what would happen is that the servo would become uncontrollable and just fluctuate from one side to another... If you used channel 1-2, no problem. Servos not on a "Y"? As long as they weren't certain Hitecs, no problem... Also did not affect the 608 receiver, or any other receiver. There are threads on this on other sites.
If you were having this problem, the solution was to either use a power distribution system, eliminate the "Y", or send your servos back to Hitec and have them modded. Later servos could operate with lower signal voltages. Futaba's response was don't use anything but Futaba servos. Nice huh?
But unless you are doing the above, it shouldn't affect you. If you have a problem, you will know right away after applying power and moving the servo.
Tom M
Any pilot can describe the mechanics of flying. What it can do for the spirit of man is beyond description.- Barry Goldwater
Hide Signatures
(in reply to Rune)
       Post #: 12
RE: Futaba Fasst and servos from diffrent brands? - 11/7/2009 6:25 PM
Rune
Score: 100
Status: online
I am not sure but think he used the 6014 rec. ....the big 14 ch one and pretty sure he used Hitec servoes ....but I you look at the video you se the ailron locks and when the model get almost inverted it released again to bad he didnt manage to push down and save the Yak ..lot off work and money waisted
Rune Gjelsnes
Hide Signatures
(in reply to ExFokkerFlyer)
       Post #: 13
RE: Futaba Fasst and servos from diffrent brands? - 11/7/2009 8:07 PM
Jon Wold
Score: 100
Status: offline
Just leave your Futaba servos to me Rune, I'll take good care of them while you experiment with JR :-)
They'll go nicely with my new Futaba Fasst radio
F3A blog: http://www.aerowold.com
Hide Signatures
(in reply to Rune)
       Post #: 14
RE: Futaba Fasst and servos from diffrent brands? - 11/7/2009 11:23 PM
Silent-AV8R
Score: 122
Status: online
The 6014 had a reduced voltage on some channels. That voltage was 2.7 volts versus 3.0 volts. The one and only brand of servos to have issues were some older Hitec models. Hitec acknowledged the issue and was doing upgrades for free.
The new 6014HS has 3 volts signal on all channels.
Beyond that, Futaba, or any other manufacturer for that matter, is only responsible for making sure their equipment works within their brand. JR will tell you teh same thing.
Having said that, I have never seen, experienced, or heard of anyone having an issue with any servo on a Futaba radio other than the Hitec/6014FS issue.
Hide Signatures
(in reply to Jon Wold)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
