Carbon tow for fiberglass fuselage seam?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Carbon tow for fiberglass fuselage seam?
Page: <<   < prev  1 [2]
Login
Carbon tow for fiberglass fuselage seam? - 7/17/2003 11:49:14 PM
DanSavage
Status: offline
Hi Vic,
[QUOTE]Originally posted by fw190
Dan, the balsa creates a channel to keep resin and glass within limits, also adds thickness to the flange. Questions... not a problem![/QUOTE]
That's what I thought.
Do you remove the balsa after the first half of the mold is done or do you just leave them in place throughout the mold-making process?
Dan
(in reply to fw190)
       Post #: 26
Carbon tow for fiberglass fuselage seam? - 7/18/2003 1:52:55 AM
fw190
Status: offline
Yes, I left them in place during the molding process. Its also a good indicator where to cut the flange.
Vic
_____________________________
www.VicRC.com
(in reply to fw190)
       Post #: 27
Carbon tow for fiberglass fuselage seam? - 7/18/2003 4:06:44 AM
Ricardo Aurelio
Status: offline
VIC
Can you tell me witch kind of fiber glass did you use to construct you P38? How many lay ups?
Thank you
Ricardo Aurelio
(in reply to fw190)
       Post #: 28
Carbon tow for fiberglass fuselage seam? - 7/18/2003 4:54:14 AM
fw190
Status: offline
I used
2 - layers of 3 oz,
3 - layers of 9oz
3 - layers of 18 oz
1 - more 9 oz layer for smooth handling
all west system epoxy
my freind and I did the layup in about 15 hour... non stop..... YIKES! that is for one side only, another 15 on the other side DOUBLE YIKES.....
It took me a week to make the splitter board..... It looked like the maze...
Do I sleep, sometimes
Vic
www.VicRC.com
(in reply to fw190)
       Post #: 29
Carbon tow for fiberglass fuselage seam? - 7/18/2003 8:42:19 AM
DanSavage
Status: offline
...my freind and I did the layup in about 15 hour... non stop..... YIKES! that is for one side only, another 15 on the other side DOUBLE YIKES.....
[/QUOTE]
That's a good idea about an easy way to add a lip to the edge of the flange. I'll try it.
Non-stop? Is that one layer on top of the other without stopping or did you wait for each layer to tack up before continuing? I'd think there'd be a lot of heat build-up with all that resin if this is a continuous lay-up.
I know what you mean about lack of sleep. Sure is nice once it's all done, though, huh?
Dan
(in reply to fw190)
       Post #: 30
Carbon tow for fiberglass fuselage seam? - 7/18/2003 9:08:18 AM
fw190
Status: offline
There is definitely heat build up, but I don't think it causes any problems. Plus I wanted to finish in one day instead of waiting and additional 2-3 hours for each layer to get tacky.
Vic
www.VicRC.com
(in reply to fw190)
       Post #: 31
Carbon tow for fiberglass fuselage seam? - 7/18/2003 12:32:50 PM
DanSavage
Status: offline
There is definitely heat build up, but I don't think it causes any problems.[/QUOTE]
As long as it didn't crack and you could still get the plug out of the mold (which you obviously did) then I guess there isn't a problem.
I just saw the pics you posted today on your site of the P-38 on it's feet. Very cool.
Dan
< Message edited by DanSavage -- Jul 18 2003 7:55AM >
(in reply to fw190)
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU2
