FEJ 1/7 F-15 vs FB 1/7 F-15    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Skygate CARF, Viperjet - RTF
Seller:  snobird
Details:   $9,600.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> FEJ 1/7 F-15 vs FB 1/7 F-15
Page: [1] 2   next >   >>
Login
FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/3/2009 10:17 AM
dubd
Score: 135
Last Login: 6/19/2013
Status: offline
Okay fellas, I am in the market for a 1/7 F-15. How would you stack the F-15s by FEJ and FB in terms of quality? Also, how do you think the F-15 will fly with a P-160SX? Better than scale? Or is a P-180/200 necessary?
Thx,
DD
Hide Signatures
       Post #: 1
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/3/2009 11:38 AM
mick15
Score: 105
Status: online
Hi DD, NO CONTEST! The FB F15 is head and shoulders above the dreadfully engineered and grossly overweight FEJ one. How do I know? I own them both.
The FB 15 will fly on a 160, won’t sparkle, will fly though, the model can come out at around 42-43 lbs. Both mine have twin 160’s.
Hide Signatures
(in reply to dubd)
       Post #: 2
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/3/2009 4:29 PM
lavi rider
Score: 101
Status: offline
The FB is by far more scale and better looking including the landing gear which FB has very accurately reproduced in 1/7 scale and will fly on a 160sx but better if a P-180 is in there....
Also I can provide all the decals in this scale for the IAF F-15I "RAAM" ...Actually for all the "birds" that are in service with the IAF.
Regards
Peter
_____________________________
Comp-Arf dealer , ATJ ,Jets-munt Turbines , Weatronic Sys , Power-box systems,Detail4scale ,C&C models Italy, Airworld model
Hide Signatures
(in reply to mick15)
       Post #: 3
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/3/2009 8:50 PM
ravill
Score: 125
Last Login: 6/6/2013
Status: offline
Dantley,
Why are you resisting a P-200? Don't be scared, stop listening to Arnaud on engine choices will you???
Raf
RAVjets Demo team. All We Do Is Fly.
Hide Signatures
(in reply to lavi rider)
       Post #: 4
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/3/2009 9:01 PM
dubd
Score: 135
Status: offline
Thanks for the input fellas. Looks like if I go with a F-15 it'll be from FB/GJC.
Raffy!!!! I'm going to stuff a P-200 in the 1/6 F-16. I guess I am going to stuff a P-200 in this F-15 too.
DD
Hide Signatures
(in reply to ravill)
       Post #: 5
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 3:29 AM
JET FX
Score: 105
Last Login: 2/25/2013
Status: offline
I dont think a 200 is really required by any stretch of the imagination. Iam going with a Merlin M160 in my one which offers very similar thrust to the turbine installed in Lewis's FB F-15E, that said his model was a pre production prototype and somewhat more heavy again... So the lighter new production version with the same power 160 turbine will be even stronger again.
http://www.youtube.com/watch?v=niknd4x9T6o
MARTY COWAN CEO
JET FX ~ JETS & WARBIRDS
Hide Signatures
(in reply to dubd)
       Post #: 6
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 5:18 AM
dubd
Score: 135
Status: offline
I thought Mr Patton was using a Rhino LPSS turbine pushing around 44#s of thrust? That is quite a bit better than a 36# turbine.
Hide Signatures
(in reply to JET FX)
       Post #: 7
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 5:21 AM
JET FX
Score: 105
Status: offline
Not sure about exact thrust of Lewis's turbine? but remember the production airframe is now much lighter also so performance with a strong 160 (Merlin 38~40 lb) should be at least on par logically
MARTY COWAN CEO
Hide Signatures
(in reply to dubd)
       Post #: 8
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 5:45 AM
jeteye
Score: 110
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: dubd
My F-15 has the LPSS Rhino.  Thrust is 40 pounds.  Flys the 15 really well.  Soon will have the new Jet Central Mammoth at 45 pounds.  That should make for some very good verticals with this airframe.  Dry weight of my F-15 is 42 pounds.
Click to see fullsize image.
Click for fullsize
Click for fullsize
The General-Jet Central,Team Horizon Hobby,Fly Eagle Jets,Robart,"Jets Over Kentucky week", ElectroDynamics,
Hide Signatures
(in reply to dubd)
       Post #: 9
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 9:15 PM
ianober
Score: 105
Status: online
Dantley, get the airframe first and then you can figure out what to stuff in it, 2 120SX's would be the bomb!!!!
Hide Signatures
(in reply to jeteye)
       Post #: 10
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 10:39 PM
mikedenilin
Score: 114
Status: offline
HI Dantley,
Ian is right about that. Just want you to know that we have the bulkheads and pipes set up for twin! The cost of 2 P120s is comparable to a P200.
Mike
Global Jet ARF PRO- Air-C-Race-Germany, CNC-Italy, Feibao, Gryphon/Redwings, Der Jet, Jet Legend, & more - globaljetclub.com
Hide Signatures
(in reply to ianober)
       Post #: 11
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/4/2009 11:50 PM
lavi rider
Score: 101
Status: offline
A single P-200 will give you more fuel for flight time than two P-120's....
a single engine is more fuel efficient than two that are at the same amount throttle thrust setting...Besides ...the single engine setting is lighter the a two engine installation.
Hide Signatures
(in reply to mikedenilin)
       Post #: 12
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/5/2009 10:08 PM
mikedenilin
Score: 114
Status: offline
Hi Dantley,
Lavi_rider has good points on single turbine configuration.
However, this is an impressive F-15, especially with true twin configuration, and you get to bring it back when 1 engine goes out. Fuel economy, who cares? Al Gore?
Anyway, both options are good. Try to flip a coin.
Mike
Hide Signatures
       Post #: 13
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/5/2009 10:26 PM
ianober
Score: 105
Status: online
The single setup would be lighter but with an F-15 weight is not really going to be an issue here. 2 P-120SX's are only a pound more than a P-200 and as far as fuel consumption goes a 120 sucks 12 oz. per minute at full throttle and a 200 sucks 24 oz. per minute so its a wash. It basically comes down to a couple of things for me.
It basically comes down to whether you want a single or twin setup, heck, even twin P-80SE's will fly this plane, but the 120's will give great vertical I am sure.
Mike, for the twin setup, whats the fuel capacity for each engine?
Hide Signatures
       Post #: 14
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/5/2009 10:56 PM
mick15
Score: 105
Status: online
In my opinion bifurcated models always sound wrong, plus the F15 needs two 160s to perform as the full size, with two 120s you will not be able to take off and immediately pull vertical, the real one can and does. With the supplied fuel cells you can easily get 12 to 14 minute flights with the 160s…….go for it!
m
Hide Signatures
       Post #: 15
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/6/2009 5:13 AM
AFTERBURNER1
Score: 139
Last Login: 6/12/2013
Status: offline
Stuff a big block 2HUNSKI in that bad boy DUB!!!!!!! See ya at the Willow.... You could stuff it in a S-Master Viper down the road as well!!!
Jetcat USA
Hide Signatures
       Post #: 16
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 11/7/2009 7:16 AM
dubd
Score: 135
Status: offline
Decisions decisions! Thanks for the info fellas. I have a Titan SE here... so if I go with a twin, I'll pick up a used Titan SE and have twin Tee-tan set-up! 68 #s of thrust sounds pretty good!
Doug, I hear ya bro. The two hunny will cross over well! See ya at the Willow!!!
Hide Signatures
(in reply to AFTERBURNER1)
       Post #: 17
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 12:11 AM
i3dm
Score: 100
Last Login: 6/9/2013
Status: offline
FEJ 1/7 F-15 flown by yours truly with a P-160:
It does lack the "scale" power, but it does fly fair. i think a P-200 would be better suited for this heavy model.
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to dubd)
       Post #: 18
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 5:31 AM
FenderBean
Score: 124
Last Login: 6/10/2013
Status: offline
is the above FEJ F-15 in the new material? I can give insight to the weight of the 1/7 FEJ, mines done so well see how it looks when it gets here. Keeping my fingers crossed
mines the twin planning on 2 140s
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to i3dm)
       Post #: 19
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 10:55 AM
Levi Wags
Score: 100
Status: offline
Hey Dantley
Why go a twin if you dont have too. More weight, drama ect. My single P200 powered Mig sounds louder and more realistic than my mates twin P160 powered Su27.
Levi
Hide Signatures
(in reply to dubd)
       Post #: 20
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 11:21 AM
mario tavarez14
Score: 103
Status: offline
A twin engine is a twin engine , my friend has a fej twin and for a couple time he lose 1 engine and bring his plane back to safety I think he safe his investment , the f-15 have 2 p-120 and is the heavy one from fej
Kingtech 140G 2 JETCAT P-140RX P-180RX P-120-P-80
FEJ F-15 E/ FEJ F86/FEJ 1/3 hawk/ cessna 182 1/3 scale/comp arf euros
Hide Signatures
(in reply to Levi Wags)
       Post #: 21
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 11:53 AM
i3dm
Score: 100
Status: offline
quote:
ORIGINAL: FenderBean
That is the old FEJ one.
www.liorzahavi.com
Hide Signatures
(in reply to FenderBean)
       Post #: 22
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 3:12 PM
TED ANTON
Score: 100
Status: offline
Hi guys
Don't want to hijack the thread but since your on the topic of big F15's heres a pic of my new project
It's 137 inches in length , plug is in the detailing stage hope to have the molds done by June
Good luck
Ted
Click for fullsize
Hide Signatures
(in reply to i3dm)
       Post #: 23
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 4:09 PM
FenderBean
Score: 124
Status: offline
Wow cool u fly 2 p-120s? cooll deal I think two 140s with full wingstores should be perfecto then
quote:
ORIGINAL: mario tavarez14
Kingtech 170F
Hide Signatures
(in reply to mario tavarez14)
       Post #: 24
RE: FEJ 1/7 F-15 vs FB 1/7 F-15 - 4/17/2012 5:23 PM
dubd
Score: 135
Status: offline
Levi, this is a old thread. I was interested in the F-15 a couple of years ago, but lost interest because both manufacturers were having problems with their planes.
BTW - I responded to your PM about the MIG-29 pipe, but I got a message saying you can not accept PMs.
If I were to get a F-15, I would use a P-200SX.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
