Name the plane
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Name the plane
Page: [1]
Login
Name the plane - 11/4/2009 2:56 PM
grotto2
Score: 100
Last Login: 11/22/2009
Status: offline
This should be easy...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
I finally got a tattoo. It reads, "Born too loose."
Hide Signatures
       Post #: 1
RE: Name the plane - 11/4/2009 3:17 PM
Jim Thomerson
Score: 116
Last Login: 11/21/2009
Status: offline
I have a # 3 and two # 2's.
Hide Signatures
(in reply to grotto2)
       Post #: 2
RE: Name the plane - 11/4/2009 3:33 PM
grotto2
Score: 100
Status: offline
It was a little hard to find an unbuilt kit. I watched eb@y for years until one surfaced, then made duplicate parts from the kit to build this.
I had one when I was 11-12. Never got it to fly.
Hide Signatures
(in reply to Jim Thomerson)
       Post #: 3
RE: Name the plane - 11/4/2009 5:02 PM
controlliner
Score: 100
Status: offline
I believe it was a Carl Goldberg product.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
       Post #: 4
RE: Name the plane - 11/4/2009 5:19 PM
grotto2
Score: 100
Status: offline
Nope.
Hide Signatures
(in reply to controlliner)
       Post #: 5
RE: Name the plane - 11/4/2009 6:37 PM
BtnFlyGuy
Score: 105
Status: offline
I can't name it, but that thing is so "old-school" ugly it's gorgeous! Me want to build one!
Planes light, lines tight...
Leader, bandits at 2 o’clock!
Roger; it’s only 1:30 now—what’ll I do ‘til then?
Hide Signatures
       Post #: 6
RE: Name the plane - 11/4/2009 6:47 PM
grotto2
Score: 100
Status: offline
You have to be willing to carve. That wing's solid balsa!
Hide Signatures
(in reply to BtnFlyGuy)
       Post #: 7
RE: Name the plane - 11/4/2009 6:58 PM
BtnFlyGuy
Score: 105
Status: offline
My "other" hobbies are woodworking and boatbuilding so I can handle a plane pretty well for shaping a solid wing, but it would make a pretty nifty traner with a simple built-up flat bottom wing for the novice builder/flyer. Is the fuse also a solid slab?  I'd build the fuselage similar to a hollow core door, downsize it a bit and hang a .15 on it. (I love those li'l beasties!) The front end certainly looks rugged and the upright engine promotes easy startups. The wheels are turning already!.
After someone guesses the pedigree of this thing, could you let us have the particulars?
Hide Signatures
       Post #: 8
RE: Name the plane - 11/4/2009 7:03 PM
controlliner
Score: 100
Status: offline
Tell us, tell us, the suspense is killing me..........oh , and do you have the plans?
Hide Signatures
       Post #: 9
RE: Name the plane - 11/4/2009 9:15 PM
grotto2
Score: 100
Status: offline
I'm certain Jim nailed it, as he has three of them. And he was classy enough not to say right off and spoil the fun.
It's a Guillows Trainer.
There were three sizes made: #1 for .049, #2 was .10-.15 and #3 was for .19-.36.
There are not plans so much as instructions for assembly, being marketed to juniors. What I have is in pretty sad shape, but I'll try to post something soon.
-Ron
Oh-And the reason I never got it to fly? It had a 'weekend' McCoy 35 in it.
< Message edited by grotto2 -- 11/5/2009 3:47 PM >
Hide Signatures
       Post #: 10
RE: Name the plane - 11/4/2009 10:12 PM
BtnFlyGuy
Score: 105
Status: offline
Cracks me up...I truly knew it but was hesitant to toss it out until I found out about the solid wing. I'm easily bluffed at cards, too.
Hide Signatures
       Post #: 11
RE: Name the plane - 11/5/2009 2:10 AM
grotto2
Score: 100
Status: offline
Assembly instructions.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Name the plane - 11/5/2009 2:13 AM
grotto2
Score: 100
Status: offline
Plan. Note 80% scale!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Name the plane - 11/5/2009 2:39 AM
proptop
Score: 100
Status: offline
I had the small one...baby bee .049
A friend has the middle one with an .09 Diesel...
At least they fly better than they look
grotto2...yours looks nice, finish wise, but...I think you know what I mean
Kind of a "utilitarian" design, huh!?
For a while, we had throttle on a Cox .049, and my nephew could get the small one to hover/fly laps at a crawling speed with the nose pointing about 85 degrees up from level...sometimes could get it to go backwards...
I think I still have parts of that one around here somewhere...
It''s bad luck to be superstitious...
Revver Bro #77
Hide Signatures
       Post #: 14
RE: Name the plane - 11/5/2009 2:47 AM
grotto2
Score: 100
Status: offline
quote:
ORIGINAL: proptop
Kind of a ''utilitarian'' design, huh!?
I understand completely. Marry a homely woman and dress her up nice.
Hide Signatures
(in reply to proptop)
       Post #: 15
RE: Name the plane - 11/5/2009 3:45 PM
Jim Thomerson
Score: 116
Status: offline
Some figures on the #3. Span 35 in, chord 8 at fuse, 6 1/2 at tip (fixed flap),wing to nose tip 5 1/4, wing to front of stab 5 1/2, stab span 15 1/2, chord 5 tapering to 4, fuse 3/4 wide, 2 in high. Rudder 3 1/2 high. Such a trainer is easy to build and very sturdy. I'm recovering from some leg problems, and went out Sunday to fly for the first time since early June. Flew my #2 with McCoy 19 on 65 ft lines. Flew three fights and did not crash nor fall down.
Hide Signatures
       Post #: 16
RE: Name the plane - 11/5/2009 3:51 PM
grotto2
Score: 100
Status: offline
Jim-
Can you tell us more about the specs for #2? I was going by memory on the displacements in the previous post, so I'm not certain about that, even. Wingspan, length of #2?
-Ron
Hide Signatures
       Post #: 17
RE: Name the plane - 11/19/2009 1:35 AM
Gungadin
Score: 100
Status: offline
I had the Guillows Profile Trainer #1 with a OK Cub .074. Flew it on 25" Dacron lines. Must have had 30 or 40 flights on it when I was about 12 yrs. old, before I did it in learning to do loops.
Hide Signatures
       Post #: 18
RE: Name the plane - 11/20/2009 2:49 AM
Schultz
Score: 100
Status: offline
I've owned three of the #2's and sold the last of these at a swap meet last winter. Got that one at a garage sale for a buck. It had a Fox 35 on it!! They had a preformed wing and fuselage made of very hard balsa and a preshaped engine crutch made of hard pine or some variety of hardwood. Flew mine on 52' .012" lines with an OS 15. They will loop and fly inverted if you are very careful.
Schultz
Hide Signatures
(in reply to Gungadin)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.906RCU1
