Tattoo
quote:
up ailerons about 1/8" above the rail bottom, airplane now is more stable but it still needs 1/2" of down elevator If moving the ailerons up as you describe made the aircraft performance better, then by all means, keep going a little at a time and see if it keeps getting better. Eventually you will reach the "sweet spot" where it's as good as you can get it, before starting to get worse again. Where the surfaces end up in their neutral position is less important than having your plane fly the way you want it to. quote:
No stiffeners in the TE before the ailerons The music wire just in front of the ailerons is very important, and something we learned when strapping larger engines to these planes. It was theororized that when giving aileron input one direction, the force on the wing caused it to flex in the opposite direction...negating the aileron input. When Kraut strapped a GMS .47 on a stock PQHOR...man...it barely rolled and was a wild ride! I'm going to have to say this theory is correct, because he inserted the music wire...and regained all control and his roll rate!!! BTW, it was because of reading about the music wire somewhere in a forum that we tried it, and immediately incorporated it into the Spa3d design. Whoever it was that did it first, please let us all know so we can thank you!!!
