Darrinc
OH, USA Status: offline
I love aerobatic planes and there is nothing better than a lite one, but biplane naturally lend themselves to coming out heavier than expected, so you must go to the n'th degree when building. It's a great challenge that pays off in spades in the air, but it is difficult to do less, and you really have to focus to not build like you always have, or fall into the famous, "Oh, just a little extra here". They all add up quickly. Just a few lightening tips that I have been using for several years and they work very well. Bring your scale to the hobby shop when you get wood. Balsa longerons: Use the third lightest of your balsa sticks to frame up the fuse. Use unicarbon in high load area's. Remember, the shape of the fuse gives more strength than the individual pieces. Balsa spars: use the second lightest set you can find, 3M unicarbon to outside face of the spar, then use thin CA here when you apply the sheeting. Stick build tail: Use the lightest of your balsa sticks to frame up the tail, sheet with 1/16" x 1/2" over all sticks (creates a I-Beam) apply unicarbon (same as constructing the spar) around edges of frame if it needs extra stiffness. Stick build outer cabanes. Contest Balsa: Use everywhere. 8lb density is good for all around use. Fuse box and doublers would be fine with this wood, spread the CA around the edge, down the center, then in a X pattern when installing any doublers, this will give you both max longitudal and torsional strength for the weight. Also works well for shear web in the wing, double w/doubler it at the center, double two ribs out, single for rest of wing, stop at third rib from the tip. (there is very little load there) Do not use ply: (except formers) No 5-ply. Use 1/4" endgrain balsa, sandwiched in 1/64" ply for firewall landing gear plate and anywhere else you use 5-ply. I have 1/4" endgrain if you need some. Use1/8" lite ply for formers and cut them out to have 3/8" width around edges. Do not use epoxy: Flex CA works wonders, its holding my DA100 in my Cap. Let set for about three minutes, then kick it. It's light and strong! Use uni carbon: You can place it just where the load is, that way your not carrying aound dead weight. In the long run it will be cheaper than 5-ply aircraft ply since you only need to use a 1/4"~3/8" wide strip, so that uni that you buy will go a long way. Best of luck and keep flying!
< Message edited by Darrinc -- Jul 18 2003 3:21PM >
_____________________________
"Make everything like your going to make the front page of NASA Tech Briefs" Go Team Orange! Darrin R Cash
