YS 91!! Whats the problem??
Tower Hobbies
Logged in as Guest
  Printable Version
The Amazing FLAMING DOOFUS Mini Flying Wing RTF!
Seller:  EASYTIGER
Details:   $89.00   |  11/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> YS 91!! Whats the problem??
Page: [1] 2   next >   >>
Login
YS 91!! Whats the problem?? - 7/4/2003 10:19:06 AM
alex24
Status: offline
I'm having a tremendous problem with my YS 91. I only have about4 flights with this engine and is killing me!
here are my problems or symptoms:
1) At iddle the engine have a change in rpm (about 100 to 200).
in about a minute after it accelerates and desacelrates, the engine suddenly quits. (i changed the spar several times)im usng an OS plug!!!
2) At full throttle the engine is only giving me about7,000 to 7,500 rpm with a APC 13 x 11. (i think this is too little rpms)
3) In one of the flights I inverted the plane and the engine lows in rpms and then quits!!
other considerations: im using Cool Power 15% nitro!
I dont know if this is good, but my high speed neddle valve is about 1 1/16 open... (is that too much closed?, but thats when the rpms are at it highest)
thanks for your answers....
Alex
       Post #: 1
YS 91!! Whats the problem?? - 7/4/2003 11:11:16 AM
azhar
Status: offline
Alex,
Is your engine used in an in-cowl application? If so, it sounds like it may be overheating or it is running a little lean.
I have no experience with the 13x11. I have used 14x8 and 15x6 APC. I run 20/20 fuel and get about the mid to upper 9K rpms. The 15% fuel may cost yoiu some power. Try a 14x8 and see what happens.
Azhar
(in reply to alex24)
       Post #: 2
YS 91!! Whats the problem?? - 7/4/2003 2:26:14 PM
Nelson Fong
Status: offline
Alex,
this is a common problem of all YS engine.
I have two YS91AC with the same problem what you had today.
fortunately, all of them are recovered to normal.
First of all, check all screws, the screws are loose when exit factory or after first flight. it cause the pressure inside the engine very unstable. escpecially the valva cover and air chamber. becareful in tighten all screws.
Second, check the codition of the gaskets (valva cover and air chamber), replace it if broken where will cause pressure leak.
Third, screw out the regulator and carefully clean inside. sometime the lubricant oil will stick around there.
Nelson
       Post #: 3
YS 91!! Whats the problem?? - 7/4/2003 6:25:40 PM
robert
Status: offline
What type of Os plug are you using, just out of interesT?
       Post #: 4
YS 91!! Whats the problem?? - 7/4/2003 6:38:15 PM
alex24
Status: offline
thanks for your responses! my engine is in cowl! i will cut the cowl a little bit more, because right now the muffler and cylynder head is tight. I will check also al the scews!!!
I will try today again, to see how it works!
By the way how closed you have your high speen needle valva????
Keep flying,
Alex
       Post #: 5
YS 91!! Whats the problem?? - 7/4/2003 7:33:50 PM
Sprink
Status: offline
Just in case you don't know, to increase cooling, increase the size of the hole that lets the air OUT, or decrease the size of the air that lets the air IN.
_____________________________
"If it doesn't break, it is probably too heavy"
       Post #: 6
YS 91!! Whats the problem?? - 7/4/2003 8:14:14 PM
Nelson Fong
Status: offline
set the high speed needle 1 1/8 turn.
an OS type F or YS 4 stroke plug must be used.
       Post #: 7
YS 91!! Whats the problem?? - 7/5/2003 4:27:59 AM
alex24
Status: offline
ok i am in the process of making the cowl holes a little bit bigger, that is the hole in the muffler and in the cylynder head!
My high speed neddle is now about 1 1/8 open! i will try tomorrow how it works!!!
Thanks again,
Alex
       Post #: 8
YS 91!! Whats the problem?? - 7/5/2003 12:49:47 PM
azhar
Status: offline
Alex,
just a note. The needle valve adjustment may vary slightly from engine to engine. The % of nitro will also determine your needle setting. The best way to set it is to use a tach and set it about 100-200 rpm below peak.
Azhar
       Post #: 9
YS 91!! Whats the problem?? - 7/5/2003 7:13:42 PM
alex24
Status: offline
yepa thats right! Im using Cool Power fuel. This fuel have 15% nitro, not 20% YS recommends, but i think it shoukd work.
Hope my engine gets better today!
Keep flying,
Alex
       Post #: 10
YS 91!! Whats the problem?? - 7/5/2003 9:01:54 PM
klhoard
Status: offline
Alex,
I have a YS .91FZ on my pattern plane. I've tried the 15% route before, but $adly, you won't get much over 8500 RPM with it (14 x 10 APC). Try a tank of 30% heli fuel and you will have a new engine on your hands. You also have to run an OS-F or the YS 4-stroke plug in this engine.
Remember, this engine has high compression and performance. Also, cooling is a must. Good luck!!
Keith Hoard
Collierville, TN
       Post #: 11
YS 91!! Whats the problem?? - 7/6/2003 2:15:39 AM
alex24
Status: offline
I agree..
I just came from my starting the engine and I think i discover the problem..
I found a lot of bubbles from the small line from the diafraghan to the carburetor.... I think this is a major problem. thats why i have this changes in the rpm in iddle... what do you think guys?? i replace the line to make sure the line wasn't broken...
I think i have to send the engine to YS!!!
Any suggestions
Alex
       Post #: 12
YS 91!! Whats the problem?? - 7/6/2003 7:15:39 AM
klhoard
Status: offline
I have bubbles in the line of my YS .91 also. . . . try some 30% heli fuel and an OS-F glow plug. . . .
If that doesn't fix it, send it in. . . .
Keith Hoard
Collierville, TN
       Post #: 13
YS 91!! Whats the problem?? - 7/6/2003 8:55:48 AM
azhar
Status: offline
Alex,
The bubbles is normal between the regulator and carb. You seem to be having a problem with engine overheat. Open up the cowl some. The YS's do not like to be hot.
Azhar
       Post #: 14
YS 91!! Whats the problem?? - 7/6/2003 2:03:17 PM
alex24
Status: offline
wow bubble are normal in this engine! I though they weren't in any motor!
umm i'm confused now!!I think the bubbles have make my iddle go bad!!! i'm using OS plugs! wow i dont know what to do?
