What radios are you guys using?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> What radios are you guys using?
Page: [1] 2   next >   >>
Login
What radios are you guys using? - 11/12/2009 2:36 AM
wierd_dragon
Score: 100
Last Login: 2/12/2010
Status: offline
I have a simple Futaba 2 Ch. FM radios with a micro receiver that I'm planning on using for my boat, but was wondering if there's an advantage to shelling out a couple hundred for some 2.4 ghz model.
sooo, with that said, what are you guys using so I get a rough idea of what I should get, if anything at all!
Hide Signatures
       Post #: 1
RE: What radios are you guys using? - 11/12/2009 2:47 AM
Dan S
Score: 115
Last Login: 3/20/2010
Status: online
Futaba 3PM FASST 2.4Ghz
no problems what so ever, and outstanding range.
Dan.
_____________________________
F-41 Stryker Cat 260 Full Mod - Super Sport 21 Hydro - FireFighter 18 - Miss Vegas CVRM 18
Futaba FASST
Hide Signatures
(in reply to wierd_dragon)
       Post #: 2
RE: What radios are you guys using? - 11/12/2009 2:51 AM
Tundrahog
Score: 100
Last Login: 3/19/2010
Status: offline
Futaba Tx - 3PMX and Rx R603FS - 2.4g
Knowing that no one is on your frequency. Converted all my planes and heli's to 2.4g also(Futaba). Had glitches on FM radios that resulted in crashes. No problems with my BJ55 when I had JR FM radio, but its still in the back of your mind.....
John
Boats - Blackjack 55 "BAD KITTY" - DF Mini Hydro "under construction"
Hide Signatures
       Post #: 3
RE: What radios are you guys using? - 11/12/2009 2:54 AM
wierd_dragon
Score: 100
Status: offline
yah! that's exactly why i'm considering changing over. I don't want some guy to be walking by with something and all of a sudden my boat goes haywire or something.
Hide Signatures
(in reply to Tundrahog)
       Post #: 4
RE: What radios are you guys using? - 11/12/2009 5:45 AM
wierd_dragon
Score: 100
Status: offline
I found an airtronics M8 with 2 receivers on FM channels for $60 on my local craigslist....worth it? or should i just save up for a 2.4ghz?
Hide Signatures
       Post #: 5
RE: What radios are you guys using? - 11/12/2009 6:45 AM
sheograth
Score: 172
Last Login: 3/21/2010
Status: offline
3PM FASST here
www.mangosnake.com
Hide Signatures
       Post #: 6
RE: What radios are you guys using? - 11/12/2009 8:06 AM
dicko
Score: 136
Status: offline
M11 on 2.4 GHz here. I've had no issue with range or interference.
The M8 can have the module swapped out to their new FHSS 2.4G system. 60 bucks for an M8 isn't bad at all if it's in good condition.
The answer is always more power.
Hide Signatures
(in reply to sheograth)
       Post #: 7
RE: What radios are you guys using? - 11/12/2009 6:18 PM
rcguy1411
Score: 100
Status: offline
jr xr3 with r 135 recevers FM never had a glitch or range problems my nerve have always run out before the range of the radio (always have fresh batt installed before every outing )
Hide Signatures
(in reply to dicko)
       Post #: 8
RE: What radios are you guys using? - 11/12/2009 6:24 PM
FlogginHarvey
Score: 110
Status: offline
4PK FASST for me and a 3PKS FASST for my wife...the security in transmission and control for a 20 lb, 40-50MPH missle is well worth it for any spectators' safety and my hard-earned $. I have watched a friends boat hit the shore WOT and heard of another whose boat went WOT into a dock...both TOTAL LOSSES. Thanks goodness no one was hurt.
I was planning on picking up a 3PM FASST when I stumbled onto a 3PKS that was hardly used for cheap with some 1/4 scale servos...
Spend the extra $$ and you will never be dissapointed or disgusted with the purchase...I promise.
Hide Signatures
(in reply to rcguy1411)
       Post #: 9
RE: What radios are you guys using? - 11/12/2009 8:39 PM
wetsleeves
Score: 100
Last Login: 3/18/2010
Status: offline
3PK FASST 2.4g here
Hide Signatures
(in reply to FlogginHarvey)
       Post #: 10
RE: What radios are you guys using? - 11/13/2009 4:40 PM
magnum57
Score: 100
Status: offline
3PK FASST 2.4Ghz. One control system for all my RC's. Awesome set up. The range is unbeatable. PB's and EKG kill guards in all my rigs
silex
Conquest
Stryker Y6
Mantaray
Hide Signatures
(in reply to wetsleeves)
       Post #: 11
RE: What radios are you guys using? - 11/14/2009 12:32 AM
dwr9
Score: 105
Status: offline
Futaba 3GR-FS FASST 2.4Ghz. Great radio if you like stick radios. Doug
Hide Signatures
(in reply to magnum57)
       Post #: 12
RE: What radios are you guys using? - 11/14/2009 9:03 AM
benckie
Score: 115
Last Login: 2/25/2010
Status: offline
Thanks shane
Hide Signatures
(in reply to dwr9)
       Post #: 13
RE: What radios are you guys using? - 11/18/2009 9:48 PM
skboatman
Score: 105
Last Login: 2/1/2010
Status: offline
quote:
ORIGINAL: magnum57
   Hey Mag 57 ....
   What do you mean by PB's ???  thanks !!!! SK.
Hide Signatures
       Post #: 14
RE: What radios are you guys using? - 11/18/2009 11:57 PM
spoolinaww
Score: 100
Status: online
I'm switching to a 3PMX with the FS receiver soon, I have my Enforcer outfitted with the below right now!
The EKG “Engine Kill Guard” is a new product designed by; Frank Ackinno and Tony Castronovo of Warehouse Hobbies Inc
prompted by a overseas customer to produce a device that is actually mandated in Europe, that will shut a gasoline ignition down in the event of low radio (receiver) batteries or worse a complete loss of power.
"Overtemp Kill Guard" New! from Enforcer Mfg Co.
Easy to install device attaches to your Zenoah water jacket as shown. Connect the black coil tap wire to one terminal and the second terminal to the engine block. Designed to stall the engine if water jacket temperature exceeds 180 degrees F.
"Radio Safeguard"
New for 2008, Micro Fail-Safe. Automatically throttles your engine down in the event of a radio signal "glitch" or signal failure. Combine this with the new Enforcer "EKG" and you will all but eliminate any potential radio failures.
Hide Signatures
(in reply to skboatman)
       Post #: 15
RE: What radios are you guys using? - 11/19/2009 12:44 AM
skboatman
Score: 105
Status: offline
quote:
ORIGINAL: spoolinaww
"Radio Safeguard"
Hey Spool....   thanks for the info. I just wasnt sure of what PB meant.  I appreciate the info!!!! SK.
Hide Signatures
(in reply to spoolinaww)
       Post #: 16
RE: What radios are you guys using? - 11/19/2009 2:08 PM
Lakefrontlivin
Score: 100
Last Login: 3/2/2010
Status: offline
quote:
ORIGINAL: Dan S
Dan.
I'm with Dan on this one
I've switched over to this Radio and love it.. Nothing like the feeling of having a built in failsafe !! Also no worry about frequency conflicts and the range is incredible !! Save your $ and go the FASST route.. Tom H.
Hide Signatures
(in reply to Dan S)
       Post #: 17
RE: What radios are you guys using? - 11/19/2009 2:12 PM
skboatman
Score: 105
Status: offline
   Hi Tom,
     What receiver would you recommend with the 3PM ???? I'm sure there's a marine secific one !!??    thanks !! SK.
Hide Signatures
(in reply to Lakefrontlivin)
       Post #: 18
RE: What radios are you guys using? - 11/19/2009 2:36 PM
monsterbrad
Score: 100
Last Login: 3/3/2010
Status: offline
I have JR Synthesized stuff in my boats now but I want all FASST stuff
due to no job all this past summer things stayed that way
I do have Fasst systems in both my wife and I's Baja'a and love them both they are awesome
Hide Signatures
       Post #: 19
RE: What radios are you guys using? - 11/19/2009 2:55 PM
skboatman
Score: 105
Status: offline
Tom & M/B ,
    I was just on Tower Hobbies and the Futaba 3PM is discontinued!  DOes anyone know of another place that might have these ???
             thanks for the info !!!! Steve K.
Hide Signatures
(in reply to monsterbrad)
       Post #: 20
RE: What radios are you guys using? - 11/19/2009 3:03 PM
spoolinaww
Score: 100
Status: online
the 3PMX is the new release with more options and comes with a Rx that is ready for marine use also
I upgraded the rx to the R603FS to get the "dad" operation also
Hide Signatures
       Post #: 21
RE: What radios are you guys using? - 11/19/2009 4:44 PM
skboatman
Score: 105
Status: offline
   Thanks Spool .... so the R603FF is good for the boats ??? SK.
Hide Signatures
       Post #: 22
RE: What radios are you guys using? - 11/19/2009 4:47 PM
spoolinaww
Score: 100
Status: online
everyone that I have talked to said that the FF version rx works just fine, I just wanted that little extra something with the FS rx option
Hide Signatures
       Post #: 23
RE: What radios are you guys using? - 11/19/2009 4:59 PM
SUPER-V
Score: 100
Status: online
Futaba Fasst 2.4 Ghz , excellent radio for the money.
Hide Signatures
       Post #: 24
RE: What radios are you guys using? - 11/19/2009 5:01 PM
skboatman
Score: 105
Status: offline
is the fs more for marine or just other options ???
   With a chance of getting yelled at here .....is Spektrum any good ???
       I have a chance at a DX3R  for 150 bucks .....is this worth it or no ????
                         Thanks,,,  Steve K.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
