Links to all FAQ, undocumented features, mixes, tips, shortcuts and more, basically anything that will help
Hitec RCD Aurora 9, Eclipse 7, Optic 6, Flash, Prism and other AFHSS system & Telemetry users
maximise the use/programming of their radios.
Please Start A New Thread - For All Questions relating to the Aurora programming, set up. features or otherwise.
(This list is regularly updated with new information as Q&A arise worldwide.)
Hitec Aurora 9 Homepage 2012 Hitec/MPX USA Catalogue -
(11.2 MB) - 2.4GHz and Telemetry detail 2011 Full Catalogue -
(12.4 MB) - 2.4GHz and Telemetry detail AFHSS in operation -
Hitec Spectra 2.4 GHz and Optima Transceiver (RX)- Video #1 = Normal Mode, Video #2 = Scan Mode. AFHSS in operation - Hitec Spectra 2.4 GHz and Optima Transceiver (RX) -Video #3 (Answers queries received ex Videos 1 & 2.,
see also post #2933 Aurora 9ch - Video - 8 Video Walkthrough of Set Ups - Dashboard, Heli, Glider, Acro, Data Transfer A9<>A9 etc.
Aurora 9ch - Video - Basic Set Up
- new 17Aug10 36mb 7min8sec. Aurora 9ch - Video - Helicopter Set Up
- Finless Bob's Review, Tips and how To - Series.
(also full of many handy pointers for Acro and other users). Bob's Video Library Index.pdf Aurora 9 - Radio System Review RC Groups - By Mike Llewellyn -
with Video of Screens and Custom Folder setup Aurora 9 - Radio System Review Fly RC Product - by Scott Stoops with Bob Aberle & Thayer Syme
Aurora 9 - Radio System Includes - Stylus, Screen cleaner, Flight Preserver, Battery Holder/Switch
for ID Setup in lieu if using an ESC/BEC & BODA Holder
- see pictures. Aurora 9 - Neck Strap Balance "#55843 Transmitter Weight Balancer".
Provides best Neck Strap Balance position for Hitec 2.4Ghz Transmitters Aurora 9 - Transmitter - Care of, especially in high humidity areas.
Aurora 9 - Transmitter Case - Aluminium.
(or use for other Hitec transmitters). #553445 Aurora 9 - Transmitter Tray & Bling 23 May 2011: latest update & .jpg Tray #58494, Red Extra Long 33mm Sticks #55864 Aurora 9 - Latency a Non Issue - Understanding latency, with comparisons, speed test and
videos.
Aurora 9 - Latency a Non Issue 7yr old Justin Jee -
XFC 2010 RC Heli Competition Flight & comment - videos Aurora 9 - Latency a Non Issue Joe Manor's Dynamic60 doing 333 mph!
New World 60" DS Record - Video Aurora 9 - 2.4GHz & 72 mHz Manual (8MB .pdf) Two page view, search not included.
(Manual written V1.03, new pages/addendums below) (.pdf, right click & "save target as") Aurora 9 - 2.4GHz & 72 mHz Manual (13.01MB .pdf) Single page & searchable.
(Manual written V1.03, new pages/addendums below) (.pdf, right click & "save target as") Aurora 9 - 2.4GHz & 72 mHz Manual - Firmware Update V1.06
- 1 new Page for Manual. (Includes Butterfly / Crow Set Up) (171kb .pdf, right click & "save target as") Aurora 9 - 2.4GHz & 72 mHz Manual - Firmware Update V1.07
2 new Pages for Manual. (386kb .pdf, right click & "save target as") Aurora 9 - 2.4GHz & 72 mHz Manual - Firmware Updates V1.07(2) & V1.08
- 7 new Pages for Manual. (1.23mb .pdf, right click & "save target as") Manual V1.08(1) update Aurora 9 - 2.4GHz & 72 mHz Manual - Index
- Comprehensive addendum. Aurora 9 - 72 MHz Spectra Pro Version -
Synthesised HSD-09RQ (Freedom 9S) Manuals, Pinouts and ID Set-up Module details.
Aurora 9 - Transmitter On First - Off Last prevent failsafe and other errors. Aurora 9 - Startup Warning Alarms Disable / Enable Alarms and
Model Match FAQ.
Aurora 9 - Off/On Switch problem? A9 Auto Saves
(flash) each session's programming & trim changes on shutdown.
Allow time to complete task before switching on again. After Market Accessories - Ignition Systems, Leads, Modules & Switches - Cautions.
Aurora 9 - Cross Trims or Re-Assign Thr<>Elev Trims, Throttle Stick Rev,
Sub Trims & Trim C & S problems.
Aurora 9 - Simulator function Set-up Aurora 9 - Module Pinouts and Compatibility Hitec Spectra, standard and other brand modules are not compatible.
Details and pictures. Aurora 9 - Trainer - Buddy system Master & Slave function Set-up & Data Transfer
Aurora 9<>Aurora 9. Aurora 9 - Trainer - Selective all 9Ch Pass-Through & RSSI Information On wish list. If and When implementation is confirmed will be promptly advised. Aurora 9 - Transfer Model Memory from Eclipse 7, Optic 6, Flash 4&5 and others
Aurora 9 - Transmitter Mode & Stick Tension Change. + Stick Tip knobs & extensions. Aurora 9 - Battery is not charged. Charge before first use so as not to damage battery.
Battery is 1300 mAh_charge rate is 80 mAh
(to minimise damage if left on to long at any time) = 19-20 hours for first full charge - please read the further details. Aurora 9 - Battery Installed ex Factory is part #54128 "TX NiMH battery (6 cell) Pack (Flat Type) for AUR (RA9) 7.2v / 1300 MAh"(not an Eneloop 2000)..
Includes notes on Battery Compartment Size, Alternate Batteries and 2S Lipo Capabilities for Aurora & Optima RX. Aurora 9 - Lipo User Adjustable Voltage sets Shut Down =
TURNS TX OFF to save damage to Lipo Battery and/or TX
(Audible Battery Warning is still at 6.9V with Lipo which provides say 10-20 min before shutdown.) Aurora 9 - Warning Alarms Battery types, Voltage Level Interpretation & Consumption.
CAUTION - Leave Auto Hibernation (was Auto Power Off prior to V1.06) as "Never" when using Lipo Battery. During "Auto Hibernation" (as with laptops)
TX Does Not Switch everything Off and batteries will be completely drained if TX switch is not manually moved to the off position in good time.
Remove battery and store separately if TX is to be unused for a period. Aurora 9 - RX Voltage on Screen SPC voltage has preference over BEC voltage if using tap.
Aurora 9 - 110/230 Vac charger Charge Plug/adaptor sizes. [
Red LED does not change to
Green simply dims out but charge continues same rate].
Aurora 9 - Diode in TX Charge Circuit Never Jump TX Charge Circuit Diode - Hitec FAQ. Aurora 9 - Lipo & Field Charging. includes Fast Charge Aurora, Eclipse 7, Flash 4&5, Laser, Optic 6, Prism 7 etc.
Aurora 9 - EPA & D/R Functions Create Dead Zone in Stick Travel
- keep either the D/R or EPA setting at 125% or less and the other at 120% or less < Corrected V1.08 - refer T.Limit below>. Aurora 9 - EPA & T.Limit (added V1.08) - Difference & Use.
Mixes can overthrow EPA% setting.
Travel Limit is a hard stop point so mixes can not overthrow % set in T.Limit and bind up a servo. Aurora 9 - On Screen "C" <> "S" & "T.App ". "C" is combined so if you want the same setting in different flight condition use it.
"S" is for single so as to make the setting unique to the condition.
"T.App" is Trim Apply - activate this if trims are to be the same in all conditions.
NB activate at start not part way/end of program or other conditions will be out of sync. - Set Up Conditions incl. Video Aurora 9 - OST & ACC - OST = Offset Curve Feature
- manual page 78. ACC = Acceleration
(for asymmetrical servo speed travel - manual page 80) Aurora 9 - Model Number Reset or Delete.
Aurora 9 - Programming Problem? - Parameters must be set in correct order e.g. V_tail, see chart. Aurora 9 - Pulse Width Data Aurora 9 - Resolution In depth explanation.
Aurora 9 - Screen Polarised Filter. View at angle when using Polaroid type sunglasses in bright sunlight .
Aurora 9 - Screen Protector & Intermittent Screen or Icon Problems -
Remove Protector or Not & alternate replacements & DIY Fixes. Aurora 9 - Screen Sensitivity & Recalibration - Pressure switches, not capacitive,
use either Stylus provided or very tip of finger for best results. Aurora 9 - Screen Touchlock - Included upgrade from V1.05 to V1.06
Aurora 9 - Servos. Slow (Reduce) Servo Speed
(does not effect torque), Control Movement Monitor & Servo Auto Test.
Aurora 9 - Servos. Use Any Modern Servo with 1.5ms Neutral Position.
Aurora 9 - Slider DIY Centre Detente (Notch) Slider for
(Aurora pre Mar10). Center/Beep out of synch with Detent
Aurora post Mar2010. Aurora 9 - Switches Re-assign/Swap Switches and or Functions "F" & "H" - DIY notes.
Aurora 9 - Switch Replace with Push Buttons
pictorial. Aurora 9 - Timer x 3 Set and Beeps. Count Down/Up Set On/Off % of Throttle Stick Movement and reset method for V1.04<V1.07. Aurora 9 - Heli FlyBarLess Throttle
- negate possible mid range jump. Aurora 9 - Heli Swash (Cyclic) Ring refer post #6 & post #11 for "Travel limit" or "Ultimate EPA's". Aurora 9 - Governor (Align) Setup Aurora 9 - Gyro Set-up - How to interpret numbers & modes on screen.
Aurora 9 - Gyro for Acro - Used to stabilise Airplane wag or takeoff.
Aurora 9 - Gyro setup Different Procedure to JR/Spektrum.
see also following post #340. Aurora 9 - Gyro GY-401 Heading Hold etc set up 450 Heli.
Aurora 9 - Gyro GY-520 and others - set up
Aurora 9 - Gyro Align 750 set up 450 Heli.
Aurora 9 - CGY750 & SBE-1 Encoder for FBL Heli Setup
Aurora 9 - Heli EP Ensure ICE ESC/BEC has been updated Or Use Switchmode Regulator.
Aurora 9 - Heli EP Manual set ICE ESC for Throttle - Do Not Use Auto Set.
Aurora 9 - Quadcopter, TriCopter & MultiCopters Set Up
Aurora 9 - Flight Conditions - Explanation, Use and order of Priority -
Video x 3. Aurora 9 - Airbrakes -Twin Rudder set up.
posts 4503 & 4504 e.g. Stryker 27Q & Funjet mode 1&2 setup & Zip files Aurora 9 - Butterfly - Crow Set Up - updated V1.06 & Stick SET Position for Butterfly v 1.08 (1).
Aurora 9 - Butterfly - Crow Flap Offset (OST) is set up under Cambmix Menu
(is not under Butterfly menu). Aurora 9 - Butterfly - Crow Switch/Slider assignment -
includes V1.05 and V1.06 downloadable files. Aurora 9 - Delta or Flying Wing - Set up Elevon, Ailevator, Taileron & Launch Modes.
Aurora 9 - Delta or Flying Wing - Set up EPA, D/R & EXP w/photos.
Aurora 9 - DLG Set up guide with many screen shots for setting Camber, P.Mixes, Flap Control etc ***
Aurora 9 - Dual Elevator (Ailevator ) - Set Up.
Aurora 9 - Dual Rates, Ailevator, Cambermix uses and assignments, see also Posts 226 & 248. Aurora 9 - Flapperon - Flaps - Set up.
Aurora 9 - Flap to Elevator - Mix Set up.
Aurora 9 - Flap (Landing) Mix see also sailplane below Aurora 9 - Flap Con - Switch Reversal & ELE Activation Pos 0
Aurora 9 - Flaps - Snap.
Aurora 9 - Four Aileron Bipe - Set Up independent Aileron Servos.
Aurora 9 - Knife edge - setup , refer posts #2355 & #2357.
Aurora 9 - P-Mix Tips: 6,7,8 use 7 point curves where 1-5 are linear.
Aurora 9 - Rudder-Elevator PMix In Flight Trimming
Aurora 9 - Sailplane_Fullhouse Glider - Electric Power Setup
(inc motor_flaps on/off at low throttle) many screen shots. Aurora 9 - Sailplane_Glider - Motor Control Menu - Delays explained.
Aurora 9 - Sailplane_Glider Flap Mixing - assign flap channel to a 3 position switch First
(refer posts 208, 209, 210 & 211). Aurora 9 - Sailplane_Glider setup examples for several types of gliders, simple to advanced.
Document in .pdf format.
Aurora 9 - Retract Servo Slow -
Video of Heli Tri gear set up.
(NB use analogue or digital servo as retract servos are 180* On/Off only
and cannot be slowed)post #5121. - Retract Curves post #5706. Aurora 9 - Retract Wheels - Steerable -
Lock Steerable Nose & Tail Wheels whilst retracted. Aurora 9 - Retracts and Flaps Set up with Various Flight Conditions - posts #2052 & #2054.
Aurora 9 - Test Mode - is inhibited if Throttle Lock On.
Aurora 9 - Throttle Lock (Hold) & Transmit Yes-No Features & Use. -
How to use Icon and/or Switch method (operates when in transmit mode only) Aurora 9 - Throttle Cut & Idle Down Set-Up..
Throttle Cut Programming - Step by Step.
Aurora 9 - Throttle Curve & Throttle Expo Set-Up.
[NB: Hitec TX use Minus (-) Expo wherever JR/Spektrum use Plus (+) Expo] Aurora 9 - Throttle Control - Glow Driver &/or Ignition On/Off
post #2239 Aurora 9 - Throttle on stick J3 convert to Crow control for landing gliders.
Aurora 9 - Throttle>Smoke. a) -
Video PMix Tutorial (text version
post #2104)
Aurora 9 - Throttle>Smoke. b) with own 7-point curve.
Assigned a two position switch with identical curve on throttle-1
& zeroed out the curve on throttle-2 one position to turn the pump off. posts #1698 & #1699 Aurora 9 - Trim Mixes In-flight - Cross Trim, In Flight Mix Changes, Re-Assign or Mix Trims. Aurora 9 - Trim Step Adjustable 1-200
(12 default, Approx.0.025deg ~ 5deg / Step). & Sub Trim
adjust/cautions posts #2 & #4. Aurora 9 - Trim Twin EP Motors (synchronise multi motors) Aurora 9 - (Mini) Ultra Stick and Crow Setup - Thread.
Aurora 9 - Variable Pitch Prop Set Up - VPP for Foamies using Heli mode.
(Brandon Chitty - Video). Aurora 9 - Giant Scale set up Brandon Chitty's 42% Aeroworks Yak -
Video presentation of set up.
Aurora 9 - BoneDoc's 3D Clinic #20 -
VIDEO - Snap to Hover
(5 min 36 sec) + J.Yee & Basic set up videos AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure for
Aurora 9, Spectra 2.4Ghz Module <> Optima Transceiver or Minima Receiver. AFHSS - Normal & Scan Modes Explained includes Redundant (Dual) Receivers & How Channel Selection Works. AFHSS - How To Select Optimum Channels - For Your Field *
AFHSS - Aurora 9, Spectra 2.4Ghz Module & Optima Transceiver -
Fail-Safe Settings AFHSS - Power Down - Range Check Procedure for Normal Mode & Scan Mode at 1mw
- tested to at least 1/4 mile. AFHSS - Warning Beeps Aurora 9 & Spectra 2.4Ghz Module
- Interpret & Manage the Independent Alarms. AFHSS - LED Status Card -
What the colours/combinations are indicating.
. Digital .pdf copy which can be printed and inserted as a page in manual or extra cards made. AFHSS - Multiplex Evo 2.4 conversion - DIY Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use
(with screenshots).
Hitec HPP-22 - Replacement Leads, Extensions and DIY Access to Transceivers buried in models.
Hitec Programmers - Download Software for HPP-21 & HPP-21+
for Digital Servos. Hitec Programmers - Download Station for HPP-22
- Enables update to Aurora 9, Optic Sport, Spectra 2.4Ghz Modules and Optima Transceivers. HFP-20, HPP-21 & HPP-21+ - Manuals.
HPP-22 Firmware Upgrade History,
now V 1.13.(0) 26 Sept 2012.
Aurora 9 - Firmware Version and Date of Manufacture.
refer to posts #4 & #15 Aurora 9 - Firmware Update V1.06 Details.
Aurora 9 - Firmware Update V1.07(1) & (2) 01Oct10.
Aurora 9 - Firmware Updates V1.07 & V1.08(1)..
Screen shots of the new displays plus additonal information includes planned updates for V1.08+. Aurora 9 - Firmware Updates V1.09. 20Sep12 -
Advanced sensor station telemetry items added & timer issue fixed. HTS-Navi & HTS-Voice Firmware Updates Optima 6, 7 & 9 Ch Transceiver Update V2.02 07Oct11
(•Improved reboot and recovery methods after severe RF interference.) - Requires Module V3.01 and Aurora V1.07(2) + Spectra Module V1.01, V2.00 & V3.01 Updates & Manual. Screenshots &
additional information. Aurora 9 - Model Set Up & Templates Program (Model) Templates.
(Download existing Set Ups and transfer to your Aurora. Upload & share your own set ups/solutions.) Aurora 9 - Template Index: Acro, Glider, Helicopter, Rock Crawler, Tanks, Simulator.
Aurora 9 - Software Wish List Thread Aurora 9 - Programming Chart Aurora 9 - Programming Spreadsheet - Put all your model settings into a Printable Excel Spreadsheet. Optima Receivers - Light Weight. Optima_6 LITE Transceiver, Minima 6E, 6T & 6L Lite Micro Receivers...
Minima are compatible only with Spectra Module V3.01 or higher. Caseless Weights for 6 & 7ch Optima Transceivers. Optima Transceiver - Conversion Lighten 6ch for Indoor & Park-Flyers plus Alternate Light Weight 2.4GHz Antenna.
Hitec "Factory Pilot" Brandon Chitty uses the Optima 7 in his indoor competition Fancy Foam Maxima that weighs 8oz, as well as his 170CC DA powered 42% Aeroworks Yak. Optima 6, 7 & 9ch Transceiver & Minima Receiver Manual V3.00 (3.12mb.pdf, right click & "save target as") Optima Transceiver & Minima Receiver -
Installation RX & BODA Antenna FAQ, Volts & Range Test Results.
{Regularily Updated with Q&A} Optima Transceiver (RX) - Independent Comprehensive Range Test
"The Hitec system worked as well as any I have tested and better than most.
It performed better than the Futaba FASST, the Airtronics, the XPS and the JR low end receivers.
It performed at least as good as my reference receiver, the JR AR7000." this with a JR Tx using twice output in USA than O/seas Carbon Fiber Fuse... Report - from well known Glider Pilot and Fly RC author Mike Lee
Carbon Fibre Fuse...Report - High Speed DS
Optima Transceiver (RX) - BODA Antenna explained - as good, arguably better than a two antenna system.
BODA Antenna Tip Wire (DIY Security for receivers manufactured pre Apr10.) & Spare BODA Holders #58474
Optima Transceiver (RX) - Low Battery Warning settings for both Aurora & Spectra 2.4Ghz module.
Adjustable LBW Voltage Alerts V1.07 up (not available V1.04<06). Optima Transceiver (RX) - Basic Telemetry Includes Battery Voltage Level but not "Range Out warning".
Optima Transceiver (RX) - Battery set up for Nitro/Gas models #1 - caution re NiMH & Alert re LiFE. Optima Transceiver (RX) - Battery set up for Nitro/Gas models #2 - caution re NiMH. Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid
Brownout & Add Redundancy,
even one for each servo. Optima Transceiver (RX) - Dual Redundant receivers - The first turned on after the Transmitter will be the recognised telemetry sender. Optima Transceiver (RX) - EP Models Use SPC Port for RX Power Supply
(BEC only is unreliable) & correct Battery Telemetry.
Optima Transceiver (RX) - Polarity of Ports & Servo Leads - with pictures. Optima Transceiver (RX) - PowerExpander Connections NB: also refer "After Market Accessories" above. Optima Transceiver (RX) - SPC connection & Lead FAQ for EP & GP models.
Low & High Voltage setup, Current Draw/Amps - Warning: Never use Balance Taps - Video Optima Transceiver & Minima (RX) - Voltage Input Limits. Optima Transceiver (RX) - Servo Move Slower Than Usual - then
Rebind. ...(Switched between Normal <> Scan mode with power off before process completed). Optima Transceiver (RX) - Servo Wag & Jerky Servo Movements Reasons & Cure - Do Not Fly With This Condition.
(...includes when switching on some ESC) .
Optima Transceiver (RX) - Servos Stepping - Battery pack (power supply) failing under load.
Spectra 2.4GHz Module V3.01 Manual. see also
Addendum re Range Check & new Smart Scan.
Spectra 2.4GHz Module Manual V2.0 & Optima Failsafe Settings. Spectra 2.4GHz and Optima RX - FCC Approval Specifications and Test Results.
Spectra 2.4GHz Antenna Mast DIY easy install / remove remote mounts for single or multiple antenna on Aurora and other TX.
DIY with photo instructions x 3 examples post#2. Spectra 2.4GHz Antenna - Hide coaxial cable inside TX. This if not intending to ever use 72Mhz or other modules.
Spectra 2.4GHz - original Prism 7 not 7X requires minor fix.
Spectra 2.4GHz Module - Futaba & other Compatible TX usuage therein is approved by FCC
(also refers to legality of PPM modules) Spectra 2.4J Module - JR Telemetry Module
NB: 3 different types = Universal, Japan & France
... TX RF Indicator light is inoperative, it is replaced by those on module.
Spectra 2.4GHz Module - Spektrum DSM, DSM2 & DSMX Compatible - Unlikely ex Hitec in foreseeable future. Spectra 2.4GHz module - Spektrum DIY Conversion Fly BNF's.
with DM8 for MZ and DC/DC converter. Original article post #59 Spectra Pro 72MHz PPM/QPCM Module Manual, Addendum re Range Check
Specifications, Pictures & Screen Shots. Spectra Pro 35, 36, 40 & 41 Mhz PPM/QPCM Modules - Hitec.
(see also post 11621) Spectra Pro 35. 36. 40 & 41 MHz PPM/QPCM Module - DIY
Convert Standard Crystal Based HPF-MIM Module, see also Post #54 Spectra 2.4GHz DSSS Module #28724 - not for use with Optima RX / aircraft
Spectra 2.4GHz DSSS Module and Atom 3 RX Manual - for Surface use only.
Tactic Anylink Module - Aurora 9 Setup, includes all other Hitec Tx.
Telemetry - Instruction Sheets & User Guide with pictures
plus Enhancements Under Development.
Telemetry - Battery Voltage via SPC and/or HTS-SS Blue for EP Models Telemetry - Bluetooth & Android App..
Android Readout & Voice Video Demo .. (Aftermarket, not made nor tested by Hitec) Telemetry - Flying Range Telemetry - HTS-GPS (GPS Sensor) - Install and use, with screenshots.
Telemetry - HTS-Iview I-Phone App information & Download page.
Iview Iphone Sound Features, manual etc.
(Hitec’s 2.4GHz telemetry on your iPod touch / iPhone and iPad) Telemetry - HTS-Voice Voice Announcing System. (includes manual and firmware update details).
Telemetry - HTS-Navi AFHSS 2.4GHz Wireless USB Telemetry Receiver Install & Operation -
Manual Telemetry - HTS-Volt & HTS-SS_Blue setup.
Telemetry - Range test Using Segway & GPS -
Video - Remarkable 2100+ ft not only through large obstacles
but also with Heli sitting in ground effect. Telemetry - Full installation in Skylink 50cc
- Static & Flying Demo -
Video( 6 min 29 sec)
Telemetry - Screens & Displays -
Video Telemetry - HPP-22 Screen as viewed live on PC/Laptop. -
Video Telemetry - Download Demo 2D Graphic Flight displays of an actual flight.
NB: GPS updates every .5 sec and will
be fairly accurate for level flight but not dive speed since it is using ground coordinates for the calculation. Telemetry - Compatibility & Open Source - status
Telemetry - Telemetry System Command Center - new Jun'11.
Telemetry System - Spectra 2.4Ghz installed Alternate TX Connections.
Telemetry - FPV Chainlink DIY for Aurora 9
Video.
Hitec Eclipse 7 & Eclipse 7 Pro - All Manuals, Addenda, Quick Setup, CCPM and Additional Programming FAQ .
Hitec Optic 6 & Optic 6 Sport - Manuals, Tutorial, Comparison Charts, Updates & FAQ .
Hitec 2012 Servo Chart .
Hitec Service Bulletins .
Team Hitec pages - Facebook .
Team Hitec pages - YouTube .
Hitec RSS News Feed - Subscribe.
Special Offers from Hitec USA.
These offers are only available to Hitec customers in the USA, Canada & Mexico Coupons, Validity/Expiry & Pricing Comparisons Limited Time Offer 1/2 price limited time specials on some items & Promo packs at foot of page. Alan Tong (Hitec NZ).
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F) .
Hitec 2.4GHz Telemetry Displays (.jpg 42.3KB)
Aurora 9 Comparison Chart (.pdf 2.53MB)
Aurora 9 Comparison Chart_Updates (.pdf 27.9KB)
A9 - Bob's Video Library Index (.pdf 63.1 KB)
