RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/8/2010 3:25 AM
A.T.
Score: 181
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Stoeptegel    HI, looks like a killer radio. One question though, is the EPA actually limiting the servo throw? i.e. does the transmitter allow the servo go beyond the EPA when applying full flaps and aileron input at the same time on flaperons and thus go beyond the set EPA? Or is the EPA limiting and does not allow to sum different mix inputs? (if you know what i mean...)
User of any type of transmitter must always ensure models are set up mechanically correct and use EPA, ATV etc  with carefull testing to ensure that mixes do not over extend servos beyond their mechanical stops - the TX does not know the limits of individual servos, some of which have greater adjustment than others.
Do not rely on electronic trims solely - listen for any signs of binding and back off.
Aurora A9 - Heli Swash Ring to be included in a future Firmware Update.
may be of interest as well as:
Aurora A9 - FAQ & Undocumented Features - Mixes, Setups, Tips, (includes Spectra Pro and Optima RX features) .  {frequently updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
_____________________________
R/C hobby consultant for various companies
Hide Signatures
(in reply to Stoeptegel)
       Post #: 26
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/8/2010 3:31 AM
A.T.
Score: 181
Status: offline
No electronic means presently possible of governing maximum servo travel on all mixes known in any TX apart from Swash/Cyclic on some top end TX. However, refer to:
Aurora A9 - Heli Swash Ring to be included in a future Firmware Update. - can apply to Mode 2 only.
Models should always be set up mechanically correct so EPA, ATV etc are kept to a minimum. Never rely solely on any type of electronic trim to fix as there are many different servos with differing fixed stops. Listen to servo and back off if any binding is heard.
Regards
Alan T.
Hide Signatures
       Post #: 27
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/8/2010 7:36 AM
Meyer1811
Score: 100
Last Login: 3/16/2011
Status: offline
I posted this in one of the other threads - please excuse me if you are reading it twice.
Well I found something not to do!!
I was testing the setup for a plane with the transmitter "on" checking throws and such. Throttle lock was enabled.
I wanted to do some things with spoilerons and went to the model type screen. I then tapped the "motor" icon and changed it to Motor + Air-brake - WRONG thing to do with the transmitter "on".
My motor started up and left Aileron went to full up!!!! I powered down the transmitter before any damage was done, but had quite a scare.
So what happened? My existing servo configuration was replaced with the default configuration that had my left aileron on ch 3 where the ESC was plugged in. Since the stick was in its neutral position the motor started and the left aileron went up because the throttle stick was in its lowest position.
With all the warning messages that the Aurora gives, you would think that it would be smart enough to know that it was about to replace a non default configuration and display a warning.
Mike - please think about that for a future update.
So be aware that the existing configuration will be over written without warning and unexpected things can result.
John
Hide Signatures
       Post #: 28
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/10/2010 8:45 PM
AJsToyz
Score: 304
Last Login: 5/22/2013
Status: offline
A.T. or Bob or Mike ?
I was reading the manual and it says you need to change the module and antenna for 72mhz, does the radio come with both modules?
thanks !!
Andy
www.Deathbychina.com
Hide Signatures
(in reply to A.T.)
       Post #: 29
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/10/2010 9:21 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: AJsToyz  A.T. or Bob or Mike ?   I was reading the manual and it says you need to change the module and antenna for 72mhz, does the radio come with both modules? thanks !!  Andy
Negative.
Spectra Pro 72Mhz Module -  delayed until at least Feb 2010.
Coupons and Pricing Comparisons
as per
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.  {frequently updated}
Regards
Alan T.
Hide Signatures
(in reply to AJsToyz)
       Post #: 30
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/10/2010 10:39 PM
AJsToyz
Score: 304
Status: offline
Thank you Al !!
Hide Signatures
(in reply to A.T.)
       Post #: 31
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/16/2010 12:24 AM
mainbeam225
Score: 100
Status: offline
Just got the Spectra/Optima 7 conversion for my Eclipse 7. Can anyone tell me if there is a preferred consideration for mounting the RX? Thanks in advance.
Mainbeam 225
Hide Signatures
       Post #: 32
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/16/2010 1:12 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: mainbeam225  Just got the Spectra/Optima 7 conversion for my Eclipse 7. Can anyone tell me if there is a preferred consideration for mounting the RX? Thanks in advance. Mainbeam 225
Much depends upon the model and space available.
Apart from instructions in the
Hitec RCD Optima 6, 7 & 9ch Receiver Manual
the following may assist:
Optima RX - Installation RX, BODA Antenna & Range Test Results.
Carbon Fiber Fuse... Report - from well known Glider Pilot and Fly RC author Mike Lee
Aurora A9 - Giant Scale set up Brandon Chitty's 42% Aeroworks Yak - Video presentation of set up.
Regards
Alan T.
Hide Signatures
(in reply to mainbeam225)
       Post #: 33
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/22/2010 2:18 AM
Langster
Score: 100
Last Login: 8/15/2010
Status: offline
Could someone please direct me to the airspeed telemetry feature of the Aurora if it is available?
Lang
Hide Signatures
(in reply to A.T.)
       Post #: 34
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/22/2010 3:02 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: Langster    Could someone please direct me to the airspeed telemetry feature of the Aurora if it is available?   Thanks   Lang
Aurora A9 Telemetry / Flying Range
Aurora A9 Telemetry Screens & Displays
as per
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.  [- a major update to this page should be visible within 48 hours.]
regards
Alan T.
Hide Signatures
(in reply to Langster)
       Post #: 35
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/22/2010 2:06 PM
Langster
Score: 100
Status: offline
Thanks A.T. Is there also a pitot tube sensor available for airspeed, and would that respond faster than a GPS. Sort of like a stall warning alarm?
Hide Signatures
(in reply to A.T.)
       Post #: 36
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/22/2010 11:10 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: Langster     Thanks A.T. Is there also a pitot tube sensor available for airspeed, and would that respond faster than a GPS. Sort of like a stall warning alarm?
Not at present, refer -
Hitec Catalogue 2010 - 2.4GHz and Telemetry detail
Aurora A9 Telemetry Screens & Displays - Video
Pictures attached are from 2010 Catalogue and pre-production examples posted earlier.
Photos of final units displayed at a recent show proving elusive at present.
see also:
Regards
Alan T.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/23/2010 3:21 AM
Langster
Score: 100
Status: offline
Hi Alan,
Many thanks for your feedback.
Cheers
Lang
Hide Signatures
(in reply to A.T.)
       Post #: 38
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/27/2010 2:51 AM
A.T.
Score: 181
Status: offline
"Initial list updated with new information and as Q&A arise - check back regularily.
Content updated and transferred to post #45. "
Thank you
Alan Tong
< Message edited by MikeMayberry -- 4/3/2010 12:21 AM >
Hide Signatures
       Post #: 39
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/13/2010 4:48 AM
rajul
Score: 105
Status: offline
As per Bob, to make the A9 work with AFPD, create a ACRO model in the A9, remove the module, power it up (it doesn't power up automatically with the trainer port plugged in), plug the usb cable in (no adapter needed) and calibrate in AFPD.
< Message edited by rajul -- 3/15/2010 8:20 AM >
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to Bob Pastorello)
       Post #: 40
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/13/2010 5:55 PM
Bob Pastorello
Score: 126
Status: offline
I found a surprise on my Aurora the other day...the manual refers to "throttle lock", but it doesn't function on my tx.  Wonder if it was there before I upgraded to v. 1.06 ???
It would be a handy feature for setting up collective on the heli without wearing out the wire connectors on the motor/esc, but I sure can't see where to access it, and "press and hold for 2 seconds" ain't gettin it done.
Anyone?
It really shouldn''t be this hard....
Hide Signatures
(in reply to rajul)
       Post #: 41
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/13/2010 6:43 PM
Chancho
Score: 101
Last Login: 5/10/2013
Status: offline
Bob,
Throttle Lock works just fine on mine.  You press the Icon on the lower left in the main menu, for ~2 seconds and it toggles the contrasts in the display image and then reads "THRD Lock" above the icon...  See pictures.
Click for fullsize
Click for fullsize
Click for fullsize
Phil Green
Saito Club # 658
Hide Signatures
       Post #: 42
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/13/2010 7:00 PM
Bob Pastorello
Score: 126
Status: offline
USER (me) Error!!!!!
For Throttle Lock to work, it must be "Transmit" mode, meaning that it is set to radiate RF.  If you select "No" at the power up prompt, it disables the Throttle lock function.
BTW - this works just DANDY for setting up collective on a CCPM heli.....thanks Hitec programmers!!!!
Hide Signatures
(in reply to Chancho)
       Post #: 43
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/29/2010 10:42 PM
A.T.
Score: 181
Status: offline
Aurora A9 - Fly RC Product Review by Scott Stoops with Bob Aberle & Thayer Syme  attached.
This for readers easy access because currently not available on Hitec USA pages whilst they are being renewed.
Click to see the file in new window.Attachment.pdf
Hide Signatures
       Post #: 44
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/2/2010 11:25 PM
A.T.
Score: 181
Status: offline
Content updated and transferred to post #49.
This as RCU does not allow Edit/Update posts after 5 weeks (posts  #2 , #39 & 45)
Thank you
Alan Tong
< Message edited by A.T. -- 5/5/2010 9:44 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 45
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/14/2010 3:27 AM
A.T.
Score: 181
Status: offline
*** previous post  duplicated in error **
< Message edited by A.T. -- 4/18/2010 12:28 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 46
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/21/2010 11:41 PM
A.T.
Score: 181
Status: offline
*** Delete duplicated post  #45 **
< Message edited by A.T. -- 4/25/2010 2:35 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 47
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/24/2010 12:55 PM
A.T.
Score: 181
Status: offline
< Message edited by A.T. -- 4/25/2010 2:36 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 48
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 5/4/2010 6:12 AM
A.T.
Score: 181
Status: offline
Content updated and transferred to Post #57
This as RCU does not allow Edit/Update posts after 5 weeks (posts  #2 , #39, #45 & #49)
Inconvenience caused transferring to new post is regretted.
Alan Tong
< Message edited by A.T. -- 6/6/2010 2:21 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 49
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 5/14/2010 4:39 PM
misha034
Score: 100
Status: offline
one question for AT.
I have followed instructions for binding and everything seems to work. but when I turn on second model,
controls on both planes are working.
is it ok? should only activ model controls move?
best regards
Hide Signatures
(in reply to A.T.)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
