RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 12/22/2010 6:26 PM
A.T.
Score: 181
Last Login: 5/22/2013
Status: offline
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Content has been updated and transferred to Post #103
This as RCU does not provide for Edit/Update to posts after 5 weeks
Inconvenience caused transferring to new post is regretted.
Alan Tong
< Message edited by A.T. -- 1/30/2011 11:40 PM >
_____________________________
R/C hobby consultant for various companies
Hide Signatures
(in reply to A.T.)
       Post #: 101
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 12/23/2010 6:56 PM
A.T.
Score: 181
Status: offline
Finless Bob's Xmas Present to all Aurora Owners = Three New Video uploaded last night to:
Aurora 9ch - Video - Helicopter Set Up - Finless Bob's Review Tips and how To - Series
quote:
1. Video Link ->Aurora 9 - Model Menus Part 4 - Pitch and Throttle Curves (146 Megs)
The gyro menu took 2 videos to cover. It can be as SIMPLE as you want or super complicated... I say KISS (Keep it simple stupid) but I spent the time to cover every aspect of understanding HOW the gyro menu works and what it means to TRUE gain to your gyro. Again if something was not clear.... Let me know!
2. Video Link ->Aurora 9 - Model Menus Part 5A - Gyro Menu basics (120 Megs)
3. Video Link ->Aurora 9 - Model Menus Part 5B - Gyro Menu advanced and tips! (99 Megs)
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Hide Signatures
(in reply to A.T.)
       Post #: 102
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 1/30/2011 11:36 PM
A.T.
Score: 181
Status: offline
"Content has been updated and transferred to Post #109" http://www.rcuniverse.com/forum/m_9247572/anchors_10372551/mpage_5/key_/anchor/tm.htm#10372551
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
< Message edited by MikeMayberry -- 3/3/2011 4:41 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 103
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/7/2011 6:41 PM
dkennedy35
Score: 100
Last Login: 5/21/2013
Status: offline
Has anyone had any problems with the Castle Creations Thunderbird 54, starting up the electric motor even with the stick all the way down and sub trim set to negative max, and trim setting set to down max.
It only seems to happen after you have shut the throttle off, and you are gliding in for a landing.  The wind over the prop is enough to spin the prop, but you can tell that the motor is starting back up.  I am wondering if it is some kind of Back EMF with the motor.
Once you have landed it doesn't do it anymore.  It is not a serious issue just a nagging issue.  It is also not an every flight occurance.
I love my Aurora and have been using it for almost a year now.  I haven't seen this issue on my old Futaba or my friends Spectrum.  However we are both having it on the Auroras we now have.
- Don
Hide Signatures
(in reply to A.T.)
       Post #: 104
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/12/2011 7:07 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: dkennedy35  Has anyone had any problems with the Castle Creations Thunderbird 54, starting up the electric motor even with the stick all the way down and sub trim set to negative max, and trim setting set to down max.  It only seems to happen after you have shut the throttle off, and you are gliding in for a landing.  The wind over the prop is enough to spin the prop, but you can tell that the motor is starting back up.  I am wondering if it is some kind of Back EMF with the motor. Once you have landed it doesn't do it anymore.  It is not a serious issue just a nagging issue.  It is also not an every flight occurance. I love my Aurora and have been using it for almost a year now.  I haven't seen this issue on my old Futaba or my friends Spectrum.  However we are both having it on the Auroras we now have.   Don
Was ESC reset and re-calibrated to the new transmitter?  the following may assist..
Aurora A9 - Heli EP Ensure ICE ESC/BEC has been updated Or Use Switchmode Regulator.
Aurora A9 - Heli EP Manual set ICE ESC for Throttle - Do Not auto set.
An aftermarket accessory, not a Hitec product, thus any queries must be referred to Castle Creations.
Alan T.
(quick search = Ctrl+F)
Hide Signatures
(in reply to dkennedy35)
       Post #: 105
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/12/2011 3:54 PM
dkennedy35
Score: 100
Status: offline
Thanks, AT I will check that out.
No it was not recalibrated to the Aurora.  That had not been needed on other radios, so I have never done that.
No big deal.  Love the radio.
- Don
Hide Signatures
(in reply to A.T.)
       Post #: 106
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/24/2011 8:17 AM
eddiemans
Score: 100
Last Login: 5/1/2013
Status: offline
Have tried to set up telemetry in 100" gasser with sensor station in cowl as the temp & rpm sensor leads are short, with extension leads back to receiver, however, No Sensors Fitted displays when I try to look at whats happening. Plugged sensor station direct to receiver & no problem. Tried different extensions, etc. all to no avail.
Can someone please tell me if there are specific extension leads for either the sensors or data lead to reach approx. 18" back to the receiver or forward to the sensors.
Now they want me to instruct!!!!!!!!!!! God help the newbies
Hide Signatures
       Post #: 107
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 2/24/2011 8:59 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: eddiemans    Have tried to set up telemetry in 100" gasser with sensor station in cowl as the temp & rpm sensor leads are short, with extension leads back to receiver, however, No Sensors Fitted displays when I try to look at whats happening. Plugged sensor station direct to receiver & no problem. Tried different extensions, etc. all to no avail.    Can someone please tell me if there are specific extension leads for either the sensors or data lead to reach approx. 18" back to the receiver or forward to the sensors.
Telemetry - Instruction Sheets & User Guide with pictures plus Enhancements Under Development.
". 6. Extension Leads.
Optical Sensor, with DIY extension, attached Heli tail pictures x 3
. At the present time, there are no extension leads for the telemetry units.
...."The stock length of the RPM leads are supposed to be longer on the next batch but extensions are needed in many cases although this should help. Temp leads can become inaccurate (I've been told) if they get much longer but I don't know to what extent. There is an extension offered here that would work with the RPM sensors for now.- Mike"....
in case Horizon as usual blocks direct link = SPMA2001 6-inch Ultra Micro Extension "
Data cable wiring is not standard, refer pictures attached above link.
Alan T.
Hide Signatures
(in reply to eddiemans)
       Post #: 108
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/1/2011 9:54 PM
A.T.
Score: 181
Status: offline
Content has been updated and transferred to Post 112
< Message edited by A.T. -- 4/4/2011 9:29 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 109
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/4/2011 3:43 AM
romeln
Score: 100
Last Login: 8/17/2012
Status: offline
Is there a way to turn of the beeping after every minute when the timer is on? Is there a way to reset the timer (not the integral timer) other than going into the timer menu and pressing reset. I have to wait for the timer to run out or I have to go into the timer menu and choose reset.
Hide Signatures
(in reply to A.T.)
       Post #: 110
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 3/4/2011 4:07 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: romeln    Is there a way to turn of the beeping after every minute when the timer is on? Is there a way to reset the timer (not the integral timer) other than going into the timer menu and pressing reset. I have to wait for the timer to run out or I have to go into the timer menu and choose reset.
At this point in time there is no way to stop the timer beeps, full details:
Aurora 9 - Timer x 3 Set and Beeps. Count Down/Up Set On/Off % of Throttle Stick Movement and reset method for V1.04<V1.07
(Ex previous post #109
Alan T.
Hide Signatures
(in reply to romeln)
       Post #: 111
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/4/2011 9:23 PM
A.T.
Score: 181
Status: offline
Aurora 9, Spectra 2.4Ghz Module & Optima Transceiver - FAQ & Undocumented Features - Mixes, Setups, Tips.
Content has been updated and transferred to Post 117
Alan T.
< Message edited by A.T. -- 5/4/2011 11:08 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 112
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/7/2011 3:29 PM
mattingham
Score: 100
Last Login: 8/4/2011
Status: offline
I have a new Aurora with Spectra Pro 72 MHz module.  My first impression is that half the manual is about using the 2.4 Ghz system.  That aside, I don't see any information about the ID setting module that came with it.  So I don't know if I'm supposed to use it or if its for the 2.4 system.
Hide Signatures
(in reply to A.T.)
       Post #: 113
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/7/2011 9:17 PM
mstcitabria73
Score: 100
Status: offline
Using a Miracle Dual switch, 2- A123 2300ma batteries, Wik's IBEF on a DLE 55, Aurora 9 w/9 CH Optima. Would like info on the best way to to run the 2 batteries into the Optima 9, without damaging anything, any suggestions, Thanks.
Hide Signatures
(in reply to A.T.)
       Post #: 114
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/7/2011 10:01 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: mattingham     I have a new Aurora with Spectra Pro 72 MHz module.  My first impression is that half the manual is about using the 2.4 Ghz system.  That aside, I don't see any information about the ID setting module that came with it.  So I don't know if I'm supposed to use it or if its for the 2.4 system.
The Aurora manual covers the Aurora 9 with both 2.4Ghz and the 72 Mhz modules installed.
There are also separate manuals for both modules.
My understanding is  that the Aurora was only available with the 2.4GHz module in USA  and that the 72MHz Spectra Pro module was only an optional extra at this time.
There is no mention of a "ID Setting Module"  in the  Spectra Pro 72MHz manual, nor have I seen one here.
72 Spectra Pro module manual, as lodged with FCC, under range test:
"Warning!
- Do the range check before each flying session to confirm the
radio system is working properly.
- Do the range check before the engine or motor is started."
amend to read
- Do the range check with the engine or motor running and cycled up <> down or add
"and repeat with Engine/Motor running which will highlight and vibration/electrical problems"
Please start a separate thread with a picture and further detail of that "ID Setting Module".
This partcular  thread is intended for answers to questions posted in many various forums.
Please post further questions relating to new topics as a new thread at
Hitec/MultiPlex Radios- Ask Hitec Customer Service ,
This ensures new questions will stand out and be seen and read by all qualified persons.
Later, have this a.m. learnt the Aurora is now available as TX with a 72 Spectra Pro module and Freedom 9 Sythesised RX only.
The "ID Set up Module" is detailed & additional 9S pictorial manual at:
Hitec - Synthesised HSD-09RQ (Freedom 9S) Manual and set-up
Hitec - Synthesised HSD-09RQ (Freedom 9S) Manuals, Pinouts and set-up
Alan T.
Alan T.
< Message edited by A.T. -- 4/8/2011 11:23 PM >
Hide Signatures
(in reply to mattingham)
       Post #: 115
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 4/7/2011 10:34 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: mstcitabria73 Using a Miracle Dual switch, 2- A123 2300ma batteries, Wik's IBEF on a DLE 55, Aurora 9 w/9 CH Optima. Would like info on the best way to to run the 2 batteries into the Optima 9, without damaging anything, any suggestions, Thanks.
1. Miracle Switch posts 1,4 & 8.
Miracle Switch Problems posts 12, 60 & 63
2. WRC Wike R/C Products IBEF Ignition Battery Eliminating Filter - Manual, should not present any problem set up either via a spare channel or in the manual setup .
following may also assist:
Optima Transceiver (RX) - Battery set up for Nitro/Gas models #1 - caution re NiMH & Alert re LiFE.
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed for redundancy, even one for each servo.
Alan T.
Hide Signatures
(in reply to mstcitabria73)
       Post #: 116
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 5/4/2011 11:02 PM
A.T.
Score: 181
Status: offline
Aurora 9, Spectra Modules & Optima : FAQ, Undocumented Features & Mixes, Setups,Tips.
Content has been updated and transferred to Post 118
Alan T.
< Message edited by A.T. -- 6/9/2011 3:31 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 117
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 6/9/2011 3:26 AM
A.T.
Score: 181
Status: offline
Content has been updated and transferred to Post # 120
Alan T.
< Message edited by A.T. -- 7/6/2011 5:13 AM >
Hide Signatures
(in reply to A.T.)
       Post #: 118
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 6/14/2011 11:43 AM
A.T.
Score: 181
Status: offline
HPP-22 Firmware Upgrade - Telemetry System Command Center
HPP-22 V1.10(0)
1. Telemetry monitoring display function and firmware update function have been separated.
- Firmware update function : Select "Update / Setting" category
- Telemetry monitoring display : Push "HTS-CC(Hitec Telemetry System Command Center)" Icon
2. New HTS-NAVI(Wireless telemetry receiver) has been added in HTS-CC.
3. SPECTRA 2.4 V3.01(0) Upgrade Information.
- Changed "Scan Mode" to less complex "Scan Function"
- Added compatibility with Hitec's non-telemetry 2.4GHz receivers
- Improved LED indicator error after Scan is done
Prompt appears when connecting HPP-22 to PC, self explanatory pictures and documents are attached.
Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click to see the file in new window.Attachment.txt
< Message edited by A.T. -- 6/14/2011 12:17 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 119
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 7/6/2011 5:11 AM
A.T.
Score: 181
Status: offline
Content has been updated and transferred to Post # 121
Alan T.
< Message edited by A.T. -- 8/7/2011 9:12 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 120
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 8/7/2011 9:10 PM
A.T.
Score: 181
Status: offline
Content has been updated and transferred to Post 122
Alan T.
< Message edited by A.T. -- 9/10/2011 9:34 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 121
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 9/10/2011 9:32 PM
A.T.
Score: 181
Status: offline
Aurora 9, Spectra Modules & Optima : FAQ, Undocumented Features & Mixes, Setups &Tips.
Content has been updated and transferred to Post #: 123
Alan T.
< Message edited by A.T. -- 10/12/2011 8:55 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 122
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 10/12/2011 8:51 PM
A.T.
Score: 181
Status: offline
Content has been updated and transferred to Post #: 126
Alan T.
< Message edited by A.T. -- 11/11/2011 8:11 PM >
Hide Signatures
(in reply to A.T.)
       Post #: 123
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 11/3/2011 2:29 PM
72
Score: 100
Last Login: 5/16/2013
Status: offline
Trying to update my A9 module and keep getting "internet is not connected" even though it is. Tried uninstalling hp-22 and reinstalling no luck.
Club Saito #614/Ultimate Brotherhood #57
Ultra Sport Brotherhood #34
Hide Signatures
(in reply to A.T.)
       Post #: 124
RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocument... - 11/3/2011 7:07 PM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: 72  Trying to update my A9 module and keep getting "internet is not connected" even though it is. Tried uninstalling hp-22 and reinstalling no luck.
The HPP-22 program was updated just a few days ago to V1.11(1).
Latest report is attached with full screenshots and details , but update must not be run before old program is uninstalled.
". Old HPP-22 V1.10 or HPP-22 V1.11(0) etc. must never be uninstalled using MS Windows own "Add or Remove program" facility,
refer attached screenshot to locate HPP-22 own uninstall feature. "
Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to install & Use Instructions (with screenshots).
. Instruction will appear on screen regarding updates, usually  automatic but if a major change,
then new program must be downloaded and installed only after old is removed as shown:
Take particular note of instructions for users with Win Vista or Win 7.
HPP-22 Firmware Upgrade - Screen shots of sequence.
HPP-22 Runtime error fix (may appear in isolated instances).
Hitec RCD - 2.4GHz Firmware & Software Updates
For optimum performance use:
HPP-22 Software Version 1.11.1 - Released October 24th, 2011
HTS-Navi Firmware Version 1.02.0 - Released October 24th, 2011
Spectra 2.4GHz Module Firmware Version 3.01 - Released April, 18th, 2011
Optima Receiver Firmware Version 2.02 – Released October 7, 2011
Aurora 9 Firmware V1.08(1) - Released 10 July 2011
Alan T.
Hide Signatures
(in reply to 72)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.688RCU1
