Recommendations for a 1/8 scale hydroplane?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> Recommendations for a 1/8 scale hydroplane? Page: [1]
Login
Recommendations for a 1/8 scale hydroplane? - 11/15/2009 8:07 AM
MyStar
Score: 100
Last Login: 12/1/2009
Status: offline
Hi all,
I would like to buy a quality fiberglass hull but don't know of any manufacturers.
Don
Hide Signatures
       Post #: 1
RE: Recommendations for a 1/8 scale hydroplane? - 11/15/2009 2:36 PM
cyclops2
Score: 105
Last Login: 3/20/2010
Status: offline
Enjoy them
This is what happens later.......
Rich
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to MyStar)
       Post #: 2
RE: Recommendations for a 1/8 scale hydroplane? - 11/15/2009 7:18 PM
Tombsy
Score: 100
Status: offline
Phil Thomas hulls (RC Marine Design) are pretty nice, he has a Bud T5.
rcmarinedesigns.20megsfree.com/scale.htm
_____________________________
Brian
Namba 814
Hide Signatures
(in reply to cyclops2)
       Post #: 3
RE: Recommendations for a 1/8 scale hydroplane? - 11/16/2009 2:29 AM
advanced builder
Score: 100
Last Login: 3/19/2010
Status: offline
I'll second that Phil Thomas all the way
Hide Signatures
(in reply to Tombsy)
       Post #: 4
RE: Recommendations for a 1/8 scale hydroplane? - 11/17/2009 7:04 AM
MyStar
Score: 100
Status: offline
Anyone have Phil Thomas e-mail address?
I fell in love with the Bud T4 hull! Fine Design must be a dealer for Hydro & Marine out of Germany, but I don't know about the quality of the fiberglass work. Anyone have any comments about Hydro & Marine and the T4 hull?
Don
Click for fullsize
Hide Signatures
(in reply to advanced builder)
       Post #: 5
RE: Recommendations for a 1/8 scale hydroplane? - 11/17/2009 3:22 PM
Tombsy
Score: 100
Status: offline
PHIL THOMAS
supersport45@aol.com
RC MARINE DESIGNS
< Message edited by Dreamin Hemi -- 11/18/2009 9:59 AM >
Brian
Namba 814
Hide Signatures
       Post #: 6
RE: Recommendations for a 1/8 scale hydroplane? - 11/17/2009 3:28 PM
Grimracer
Score: 100
Status: offline
Phil Thomas is the man
Great products and very good prices
the 82-U55.. a very good hull
Grim
Click for fullsize
Click for fullsize
Aquacraft Boat Designer
Hide Signatures
       Post #: 7
RE: Recommendations for a 1/8 scale hydroplane? - 11/19/2009 1:39 PM
MyStar
Score: 100
Status: offline
Thanks for your responses guys!
3 recommendations for Phil Thomas is impressive.
I don't know if I'm going to get a T-4 hull now because I've heard from a couple of people they can be hard to trim.
Grim: Awesome detail in those pictures!
Don
Hide Signatures
(in reply to Grimracer)
       Post #: 8
RE: Recommendations for a 1/8 scale hydroplane? - 11/20/2009 4:20 AM
Hydro Junkie
Score: 105
Status: offline
No harder to trim than any other hydroplane. Are you looking at racing or just having a fun boat to run around the lake?
Hide Signatures
       Post #: 9
RE: Recommendations for a 1/8 scale hydroplane? - 11/20/2009 7:41 AM
MyStar
Score: 100
Status: offline
Maybe I'm using the wrong word when I said the T-4 hull is harder to "trim"?
A well known person in the R/C boat community e-mailed me who has a T-4 and said he had to redo the sponsons to get his T-4 running right.
This will be boat to have fun with.
Don
Hide Signatures
(in reply to Hydro Junkie)
       Post #: 10
RE: Recommendations for a 1/8 scale hydroplane? - 11/22/2009 1:00 PM
cyclops2
Score: 105
Status: offline
I can tell you that full size hydros are very sensitive to 1 part of the underside shapes. The HEIGHT or depth of the inner sponsons makes a world of difference in a smooth ride and cornering comfort for the drivers. The height & amount of air trapped underneath determines the amount of hard kick ups from each wave. So increase the sponson depths & or lengths for a smoother & less jerky ride. BIG.. DEEP..DEEP turn fins in the CORRECT position also smooth out the rides.
Deep enough sponsons WILL mask the need for a better turn fin & location. 1 of them, the inside 1, is a partial turn fin in disguise. When you get the fin in the correct place at full speed in a turn the boat will ONLY slip sideways. It will not need any rudder input changes to maintain the same curvature thru the rest of the turn. ..I test a fin location by standing on a hill & looking downward on to the boat. You will quickly see which direction to move the fin for improvements. Do these runs in a CONTINOUS circle. Large at first. You will reach a speed & tight circle that makes any fin MOVEMENT useless for inprovement. When no more improvement is possible. That signals you to go to a LONGER & or DEEPER turn fin at the SAME location.
TIme consuming but it can make a " DOG " into a good cornering boat.
All the above assumes you have already found the best " Center of Balance " by moving weights around.
You should finally move the weights around 1 more time to see if it is in the best location.
This will become a HIGHLY addictive procedure once you see the amount of improvements possible on a poorly set up boat with modifications made to it.
I am assuming the rudder is NOT being hit by any of the prop blast. A offset rudder.
Rich
Hide Signatures
       Post #: 11
RE: Recommendations for a 1/8 scale hydroplane? - 11/23/2009 10:53 AM
MyStar
Score: 100
Status: offline
Hi Rich,
Thanks you so much for that very informative info!!
Helps me understand why the well known T-4 owner/racer modified his sponsons.
"I test a fin location by standing on a hill & looking downward on to the boat. You will quickly see which direction to move the fin for improvements."
How would I know which direction to move the fin by looking downward at the boat?
Don
Hide Signatures
       Post #: 12
RE: Recommendations for a 1/8 scale hydroplane? - 11/24/2009 2:31 AM
cyclops2
Score: 105
Status: offline
I HATE typing!!
As you start crossing your own wakes, you will see that the bow seems to be yanked outward most of the times, if the turn fin is too far too the rear.
What would happen if the fin was 6" from the stern?
What would happen if the fin was 6" from the bow?
Do you get what we are trying to do ?
Use a support piece of plywood on the inside of the hull as you keep drilling new holes.
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
