RE: C-ARF Flash Build Thread for All Flash's being built this winter    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: C-ARF Flash Build Thread for All Flash's being built this winter
Page: <<   < prev  31 32 33 [34] 35 36 37 38 39 40   next >   >>
Login
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/19/2010 7:32 AM
gooseF22
Score: 103
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: hbutler
Another couple of questions...
Thinking of using an AR9200 for my flash. I prefer the AR9100, but because of some other components I currently have the the 9200 is a better fit.
Only concern is the current draw. The 9200 is rated at 20 amps continuous where as the 9100 is rated at 35 amps. What's your guys opinion? My guess is that 20 should be plenty. Manual suggest it would, but just want to check with others. The plane currently has 8411s all the way around. Would like to setup the plane's power system to be able to handle 8711s. I believe they are physically bigger than 8411, so they could be some fitting issues, but I'll deal with that if and when I change the servos out. So do you think 20 amps would be enough for hard flying with 8711s? (Not sure if 8711s would consume more current than 8411s. Stronger servo may not work as hard. So 8411s might be the bench mark)
Secondly would dual 2xxx mah packs be enough for a days worth of flying? Say 10 flights or so?
dont upgrade it tis fine. 8711 is huge overkill. I like the 8411.. they are quick and sensitive.
most jets use about 400 Mah per flight, I size my packs to have 50% more than I need. you woudl then need about 3-4000 MAH packs. If you run nickle, thats getting heavy. I run 2 2600 ion packs. thats 4 flights and charge.. not a big deal. my kingcat is the same way.. so size them however you prefer..thats my rule of thumb
_____________________________
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to hbutler)
       Post #: 826
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/19/2010 12:56 PM
RCFlyerDan
Score: 105
Last Login: 6/18/2013
Status: offline
You will love the plane! They are extremely fun to fly. I have a P-120sx internal kero start in mine. It has plenty of power with unlimited vertical. I even do blenders with mine on the way back down, which shocks everyone at the field that day. Don't buy the struts, you won't be happy. Get trailing link, especially if you are operating off of short runway. I fly off of a 450 x 40 paved runway with obsticles. Look into the Fromco Wolverine switch. It fails to the "ON" position. I also you dual Fromco Sahara regulators and Lipo batteries, but they are buried in the nose and don't remember what they are. Have 100 flights on mine and LOVE it!
There are those who have and those who will!!
Take Care! Dan
Hide Signatures
(in reply to gooseF22)
       Post #: 827
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/19/2010 1:47 PM
hbutler
Score: 100
Last Login: 6/14/2013
Status: offline
Thanks again all,
I went back over the thread and I'm going to go with the AR9100. The plane was originally fitted with one, so it will make for little adjustments. Additionally I already have one with very little time on it. Saving some $ is always a plus. Additionally, I'll use two 2300 A123s for my RX which I really like due to the simplicity and reliability. I'll wait to see what to power the turbine with until I'm working on the CG.
I haven't been this excited about RC in a long time. My interest in jets was the reason for getting into the hobby. Dubd has been trying to convince me for about a year now to get one and I finally listened. Really looking forward to getting this one in the sky.
Hide Signatures
(in reply to RCFlyerDan)
       Post #: 828
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/19/2010 2:18 PM
KC36330
Score: 328
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: hbutler
............I'll wait to see what to power the turbine with until I'm working on the CG.
Don't wait, put a Duralite LiMg in there and you'll be glad you did, all day flying without recharging.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
       Post #: 829
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/19/2010 3:08 PM
hbutler
Score: 100
Status: offline
quote:
ORIGINAL: KC36330
quote:
ORIGINAL: hbutler
I was considering that. I have a couple of 4300s in my 36% sbach... Have been very happy with them thus far. As recommended, I'll wait and see what is going to happen with the CG. Additionally, that will give me a feel for how long the cables should be. I've had duralite customize the length of cables in the past. Looks tight in the fuse, so would like to do my best to keep it organized and clean.
Hide Signatures
(in reply to KC36330)
       Post #: 830
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/19/2010 3:18 PM
gooseF22
Score: 103
Status: offline
quote:
ORIGINAL: hbutler
Thanks again all,
Me too, thats what got me back into the sport.. I LOVE Jets!!. Being a full scale Jet pilot, sealed the deal for me..
Excellent combo. simple and reliable, no switches, just the 9100 soft switch.. I am a fromeco rep, and their stuff absolutely rocks, so I like the wolverine setup as well, but with the 9100 and the 1222 receivers, I prefer the Iron Corps Extreme batteries (A123). I use the Fromeco balancing circuit that can be put under the shrink wrap on the A123's if you have a two wire charger (ion Cube), otherwise put balancing wires on them, so you can balance charge them in the plane.. I had some good Giant Scale stuff left over and it works well in Jets.. My power systems were very comparable, which resulted in overkill for jets, but nothing ever fails..
If you fly alot, the fast charge of the A123 rocks...just balance them often..
Goose
Hide Signatures
       Post #: 831
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 2:44 PM
hbutler
Score: 100
Status: offline
Just found out that the flash I have coming doesn't have a wing tank. Check the comp-arf website and they only list the fuse tank in the spare parts section. I seem to remember one post in a thread where someone was asking to purchase a wing tank and would pay good money for one....
Am I reading to much between the lines if I've arrived at the conclusion that it is difficult to get a wing tank for this plane? Anyone else have to deal with this and have tips?
I've emailed all the us distributors and waiting to hear back. Thought I would hit you guys up also.
Hide Signatures
       Post #: 832
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 2:50 PM
seflyer
Score: 105
Last Login: 6/16/2013
Status: offline
just call one of the reps, the wing tank is available. about 100.00 for it. it is also one of the CT-114 tanks.
Kevin
Hide Signatures
       Post #: 833
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 2:55 PM
sailing1
Score: 100
Status: offline
Dreamworks sells the set with the main and wing tank. Don't know if they sell just the wing tank but would be easy enough to email them and ask.
Hide Signatures
(in reply to seflyer)
       Post #: 834
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 3:00 PM
gooseF22
Score: 103
Status: offline
Ray Labonte got mine quickly. he is on the CARF website.
Goose
Hide Signatures
(in reply to sailing1)
       Post #: 835
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 3:01 PM
seflyer
Score: 105
Status: offline
the wing tank is on the accessories page under fuel system.
Kevin
Hide Signatures
       Post #: 836
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 3:37 PM
mtnflyer14
Score: 100
Status: offline
http://www.carf-models.com/public_carf/pages/shop/accessoryDetail.html?root=Accessory&proId=1699&linkId=@1699
The link above will take you to the Flash wing tank from C-ARF. I received it in about a week, costs $99, comes with all plumbing, etc., ships from Ray Labonte in Maine.
Also, my Behotec retracts had five pages of instructions - all in German! Go to altecarerc.com and you can download the instructions in English.
Regards,
Mark
AW Extra 260/ZDZ Super 80; Elan/K-80; C-ARF Ultra Flash; YA F-15C/K-140
Hide Signatures
       Post #: 837
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/22/2010 3:47 PM
PaulD
Score: 105
Status: offline
John at MAP has a Flash wing tank conversion that mounts to the fuse and fits into the pocket in the wing. Eliminates the requirement to disconnect the fuel lines when disconnecting the wing.
http://www.modelaviationproducts.com/index.html
It's not shown on the web page - you have to call and ask for it.
PaulD
If it''s too LOUD - You''re too OLD
Hide Signatures
(in reply to mtnflyer14)
       Post #: 838
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/23/2010 12:57 AM
hbutler
Score: 100
Status: offline
quote:
ORIGINAL: PaulD
PaulD
Thanks guys. Really appreciate the help.
I would really like not to have to deal with managing the wing tank connection. Therefore I'm interested in this suggestion. I've been told it is managing the connection to the wing tank is easy and the downside putting an additional fuse tank is possible CG movement while burning fuel... Those that are using second fuse tanks versus wing have an opinion?
Hide Signatures
(in reply to PaulD)
       Post #: 839
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/23/2010 1:22 AM
phjoker
Score: 100
Status: online
The Wing tank Connection is not as bad as it seems Just connect the 2 lines together with a festo fitting and your done.
There is really not a lot of room to add another fuse tank.It's Crammed in there!!!
You could mount 2 tanks by the intakes. I mounted 2 there (as well as a lot of other people) but they are for smoke.
I have the wing tank,fuse tank, the little 4 oz that was meant to be the hopper and a 4 oz MAP High Flow UAT tank. With the Rhino I can get up to 7 min of flying with a little time to spare. Now if the Throttle was full for most of the flight (Like I usually fly the my Flash) then I get about 5 min
Pete H
A Happy Jet Central Falcon & Rhino Owner
Hide Signatures
       Post #: 840
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/23/2010 1:47 AM
Wayne22
Score: 105
Last Login: 6/15/2013
Status: offline
Do you have one of those in your's Paul?? I'm installing one as well....
All I ask is for a chance to prove that money can't make me happy......
Hide Signatures
(in reply to phjoker)
       Post #: 841
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/23/2010 4:12 PM
PaulD
Score: 105
Status: offline
Gonna order one in a bit. Focussing on getting the Boomer Torus done for now but I suspect I will be needing some stuff from MAP pretty soon.
The only thing I need to work out is how I will do the rest of the wing connections with that tank in the way. I like the set-up I have now where I can slip the wing connections up into the front section, do up the wing bolts and then flip the aircraft over to finish the connections. Makes it much easier than trying to make those connections while you're holding the wing.
Hope U have a good Christmas Wayne and to everyone else as well.
PaulD
Hide Signatures
(in reply to Wayne22)
       Post #: 842
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/23/2010 7:29 PM
Wayne22
Score: 105
Status: offline
Thanks Paul....and same to you!!!
I'm going to run the connectable stuff up between the intakes into the cockpit area for final connections. Hopefully there is room for everything with that tank hanging there, but will find out very soon......
Hide Signatures
(in reply to PaulD)
       Post #: 843
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/23/2010 7:43 PM
siclick33
Score: 125
Status: offline
I was a bit concerned about the tank in the wing but it really is a non-event and 'when' I build another I will use the same method.
Here's how I did mine.
Festo 90 degree thingy on the wing tank line with standard on-off tap in fuselage. After flying I turn off the tap and unplug the Festos and job done. To keep the car clean I then add a plug and a cap to the bare ends to stop fuel coming out. Easy
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
It was all going really well, then I suddenly ran out of talent!
Hide Signatures
       Post #: 844
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/24/2010 12:08 AM
fast jets
Score: 100
Last Login: 9/30/2012
Status: offline
Ther is lots of room to make the connections in the fuse after wing is in place. There is more room with our wing tank than with the comp arf wing tank. If you need pics of what I did just let me know.
John
Model Aviation Products
Hide Signatures
(in reply to siclick33)
       Post #: 845
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/24/2010 12:38 PM
KC36330
Score: 328
Status: offline
post 115 back on page 5 shows how i had my wing tank connection, and how much room there is to connect everything after the wing is secured in place.
Hide Signatures
(in reply to fast jets)
       Post #: 846
RE: C-ARF Flash Build Thread for All Flash's being buil... - 12/24/2010 7:28 PM
phjoker
Score: 100
Status: online
quote:
ORIGINAL: KC36330
Post 127 on pg 6 for mine
Pete H
Hide Signatures
       Post #: 847
RE: C-ARF Flash Build Thread for All Flash's being buil... - 1/4/2011 10:25 PM
ricardinho
Score: 100
Last Login: 6/12/2013
Status: offline
how does she fly with the p80.. do you like it.. is the speed ok.. have you done takeoff with paved runway yet.. anyway just trying to get an idea how the flash flys with a p80..thanks pat
Hide Signatures
(in reply to Gary Szetlak)
       Post #: 848
RE: C-ARF Flash Build Thread for All Flash's being buil... - 1/6/2011 12:11 PM
Jet Doctor
Score: 100
Status: offline
Hi HButler
I have used the tank setup as shown in post # 127 in this thread and have been very happy with it.
Click for fullsize
Go Big or Go Home!
Hide Signatures
(in reply to ricardinho)
       Post #: 849
RE: C-ARF Flash Build Thread for All Flash's being buil... - 1/6/2011 12:41 PM
ricardinho
Score: 100
Status: offline
that looks pretty slick... what engine and how many minutes are you getting. also what size tanks are they....
Hide Signatures
(in reply to Jet Doctor)
       Post #: 850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
