RE: C-ARF Flash Build Thread for All Flash's being built this winter    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: C-ARF Flash Build Thread for All Flash's being built this winter
Page: <<   < prev  31 32 33 34 35 36 37 38 39 [40]
Login
RE: C-ARF Flash Build Thread for All Flash's being buil... - 7/6/2012 5:01 AM
InboundLZ
Score: 140
Last Login: 6/17/2013
Status: offline
If you are on the ground at that speed you are doing something wrong, and if you are trying to land at that speed you are going to have all kinds of problems......
_____________________________
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
(in reply to DrV)
       Post #: 976
RE: C-ARF Flash Build Thread for All Flash's being buil... - 7/6/2012 10:46 AM
aquaskiman
Score: 100
Last Login: 6/16/2013
Status: offline
I don't know what speed we are doing with our CF at take off, but at 5400ft on a 80deg day we use all the 600ft of runway to get it the air with a JC120sx. I have seen many wheels come off jets that were not glued on.
George
Hide Signatures
(in reply to InboundLZ)
       Post #: 977
RE: C-ARF Flash Build Thread for All Flash's being buil... - 7/6/2012 2:47 PM
tucson
Score: 100
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: aquaskiman
George, I have many flights on my CF with a JC 120SX. I live at an altitude close to 3000 ft. Lately I have been flying mine when the temp's have been in the middle to high 90's. The density altitude is pretty high at those temp's.
I never use more then 250 -300 ft without TO flaps.
Our runway here at Timpa is 750 ft. I start my take off roll near mid field and am off way before the end of the runway.
I have never lost a wheel or tire. I have never glued them on. I bought them from Dreamworks almost two years ago.
I can't explain why, Maybe I am one of the lucky one's.
Stan
Hide Signatures
(in reply to aquaskiman)
       Post #: 978
RE: C-ARF Flash Build Thread for All Flash's being buil... - 7/6/2012 4:03 PM
KC36330
Score: 328
Status: offline
the Flash sits with a slight negative AOA and full thrust pushes the nose down during the takeoff roll, this makes it hard to rotate if you're waiting till flying speed to put in back elevator.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
(in reply to tucson)
       Post #: 979
RE: C-ARF Flash Build Thread for All Flash's being buil... - 8/16/2012 11:31 AM
David J Ruskin
Score: 100
Last Login: 6/18/2013
Status: offline
Guys,
Anyone recognise the make of these wheels. I lost the tyre, yep neither my caller nor i saw it come off. The rims don't come apart so im not sure where i can source a replacement tyre.
Any assistance appreciated.
David
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 980
RE: C-ARF Flash Build Thread for All Flash's being buil... - 8/16/2012 11:42 AM
hotspot 01
Score: 100
Status: offline
Peter Agnew makes them can be found at Intarico.
Hide Signatures
(in reply to David J Ruskin)
       Post #: 981
RE: C-ARF Flash Build Thread for All Flash's being buil... - 8/16/2012 12:38 PM
aquaskiman
Score: 100
Status: offline
Dreamworks also has them
George
Hide Signatures
(in reply to hotspot 01)
       Post #: 982
RE: C-ARF Flash Build Thread for All Flash's being buil... - 8/16/2012 1:40 PM
basimpsn
Score: 120
Status: offline
quote:
ORIGINAL: KC36330
quote:
ORIGINAL: IFlyEm35
HYPOTHETICALLY what do you see?
Hypothetically speaking, it would take several laps to pull ahead of the highly exaggerated 120sx posted above......my best guess on the above post was their radar was in KPH not MPH, if that's not the case is there anyone willing to trade their 120sx for a 40 lb K170??
I'm sorry but that's funny
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to KC36330)
       Post #: 983
RE: C-ARF Flash Build Thread for All Flash's being buil... - 1/22/2013 2:39 PM
txshan130
Score: 100
Status: offline
Does anybody know where to get those light kits for the wing booms? Would be interested in one...
thx,
Brian
Hide Signatures
(in reply to basimpsn)
       Post #: 984
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/16/2013 8:03 PM
tucson
Score: 100
Status: offline
I am in the process of deciding how to mount my 16 oz (two) Dubro smoke tanks in my Flash.
I plan on putting one on each side of the fuse.
I do not want to rest the tank on the main tank in order to allow the main tank to expand when the tank is full.
When I put the tank as close to the fuse side as I can the bottom of the smoke tank can only rest on one inch before it overlaps the main tank.
Not enough to secure the smoke tank.
Placing a 1/8 plywood platform below the smoke tank will raise one part of the smoke tank slightly above where the wing rests on the fuse mount as I plan on using Velcro to secure it.
I have seen pictures where someone has mounted this type of tank before with success.
Any information would be greatly appreciated.
Stan
Click for fullsize
Hide Signatures
       Post #: 985
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/16/2013 9:18 PM
Dave Wilshere
Score: 108
Status: offline
Stan
Saw your request on the UF thread, don't think we really get what you are asking. I think the pictures you remember were on the UF thread (when it was back about building!)
The tanks are not going to go far with just Velcro, as long as you stop the forward and backward movement, sitting between the wing and fuse it will be fine.
The fuselage tank only blows during filling, once full the bottom does not go much below the wood cross mount
Dave
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
       Post #: 986
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/16/2013 10:08 PM
tucson
Score: 100
Status: offline
Thanks Dave,
I saw the pictures somewhere back on one of these two threads.
I agree forward and aft would work fine. My concern is the tank moving to the center of the fuse where it would block the inlet air.
I guess it won't hurt to attach it partially to the bottom of the main tank then with velcro also.
I will give it a shot.
Stan
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 987
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/16/2013 10:42 PM
Dave Wilshere
Score: 108
Status: offline
Stan
Should be fine, you can always glue some 3/8"high "stops" inside each tank. But don't think you are going to need them
Blocking the inlets will only slow her down, turbines breath from any gap available!
Dave
Hide Signatures
       Post #: 988
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/17/2013 1:20 AM
KC36330
Score: 328
Status: offline
the pic's were of Douggy's old classic flash and my classic flash, they are just Velcro'd in, it works great. the wing holds them in place in flight and the Velcro when the wing is off.
Click for fullsize
Hide Signatures
       Post #: 989
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/17/2013 1:38 AM
tucson
Score: 100
Status: offline
Thanks KC,
Thats the picture I remember.
Glad to hear there is no problem.
Stan
Hide Signatures
       Post #: 990
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/21/2013 9:55 PM
john josey
Score: 110
Status: offline
My good friend and flying buddy has the classic flash unpainted and wanted the red, yellow and black colour scheme of the ultra. I took some pictures of how i did the masking as it may be of some interest to others. Another benifit to doing this is you get rid of that 'orrible' seam !
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 991
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/21/2013 10:31 PM
Dave Wilshere
Score: 108
Status: offline
Now that looks great! Actually suits it, I guess the F stickers warn people before you take off
Nice job!
Dw
Hide Signatures
(in reply to john josey)
       Post #: 992
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/21/2013 10:50 PM
john josey
Score: 110
Status: offline
The 'F' sticker has probably halfed it's value.....someday he'll see the light
Hide Signatures
       Post #: 993
RE: C-ARF Flash Build Thread for All Flash's being buil... - 4/21/2013 10:55 PM
KC36330
Score: 328
Status: offline
looks good!!
Hide Signatures
       Post #: 994
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
