bob27s
OH, USA Status: offline
The Juno F-20 is a great kit, and results in a VERY good flying airplane.... Flutter is not prevented by the servos. Too many folks look for servos that can survive flutter. Best to address the source of flutter. Seal the control surfaces gaps. That is the best way to prevent flutter. And be sure your torque rod linkages are properly installed. Either aircraft does not need anything special servo wise. Anything you would trust in any decent aircraft is good. The F-20 I had a few years back had basic JR 517 ball bearing sport servos in it. Any decent BB modern BB sport servo would be good. Although from a weight/size standpoint, you may want to consider some mid-size digital servos. Save an ounce or three in weight, and easier to fit into the plane. As for engine choice..... the OS55AX will be ok. Keep in mind, the engine prefers lower rpm, but it can do ok for itself in a speed application. With either the stock muffler or at tuned muffler such as the Jett-Stream, select a prop that allows the engine to turn between 14,500 and 15,500 rpm peak rpm. With the stock muffler, a 9x8, 9x9 or 10x6, 10x7. With the tuned muffler, 10x7, 10x8, maybe the 9x9.
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
