AirGar
Joined: 12/5/2001 From: Alta Loma, CA, USA Status: offline
Dean320, The F-20 is a good choice for your first speed plane, however, I would recommend starting with a stock 46 motor, and upgrade after you get used to it. They float in quite nice actually, but you do need to have some throttle in it for landing. The DC F-20 does not have retracts. The Kanghe one does. Get the DC, cover it bright with the bottom a completely different color, as these can get out of your sight very quickly. Use the fixed gear it comes with. Gary
_____________________________
>>>>>> Un-Certified Speed "Demon"!! <<<<<< (((Revver numero three'o)))
