Scorpion or align esc?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Scorpion or align esc?
Page: [1]
Login
Scorpion or align esc? - 11/17/2009 9:31 PM
TheStapler
Score: 100
Last Login: 3/3/2010
Status: offline
hi
just like to know what esc should i go for?
scorpion 35a v2 or align rce-35x?
the scorpion is about $12 more. i'm running a align 450x motor
only got a dynam 40a esc and very basic gets alittle hot and only has a 2amp bec
would i see improvement with a scorpion??
here is the link for the specs for the esc i got now
http://www.dynam-rc.com/download/diantiao.pdf
thanks
Hide Signatures
       Post #: 1
RE: Scorpion or align esc? - 11/18/2009 5:18 AM
Cleared2Engage
Score: 105
Last Login: 3/13/2010
Status: offline
Personally I'd go for a Castle Phoenix 45 ESC. I love the flexibility that the CastleLink provides. I can program in the exact headspeed that I want and a whole bunch of other features. I've used the Align ESC's and they are ok. Never had an experience with the Scorpion ESC.
_____________________________
When it absolutely, positively has to be destroyed overnight...
USMC 0861 Fire Support Man (Artillery/Naval Guns/CAS)
Hide Signatures
(in reply to TheStapler)
       Post #: 2
RE: Scorpion or align esc? - 11/18/2009 10:09 AM
helicrazedout
Score: 100
Last Login: 3/11/2010
Status: offline
just a thought but arent the hyperion esc supposed to be very good? ive got a 30a titan hyperion and its very good and i heard the 35a + ones are exellant
450 size- Dx7 AR7000 Align GP750 gyro Hyperion titan 30a esc Towerpro sg90 servos Align DS520 tail servo esky motor
Hide Signatures
(in reply to Cleared2Engage)
       Post #: 3
RE: Scorpion or align esc? - 11/18/2009 10:32 AM
ace22459
Score: 100
Status: offline
I have a Scorpion 35amp Commander, a 45amp Commander and a Castle Phoenix 35amp. While all are good ESC's, I don't think the Castle is worth the $85 dollar price tag. You can have the Scorpion 35amp for $55 and for $5 more, the 45amp. The Scorpions also come with a wireless infrared programming card which is pretty cool. If you want to access the advanced programming features of the Castle, you need your computer AND the USB programming link which costs an extra $23 dollars bringing the price up to $!08 dollars. These are prices listed at ReadyHeli. Alan
T-Rex 450 SEV2, T-Rex 600nitro Pro, T-Rex 500 GF, Hirobo SDX, T-Rex 450 SE night rig, T-Rex 450 SA scale Hughes 500D Defende
Hide Signatures
       Post #: 4
RE: Scorpion or align esc? - 11/18/2009 11:30 AM
TheStapler
Score: 100
Status: offline
quote:
ORIGINAL: ace22459
hey
So you have never had a problem with scorpion 35a? how does it run??
do you use the govener?
i thought i would get the scorpion because of all the things you get with it.
thanks
Hide Signatures
(in reply to ace22459)
       Post #: 5
RE: Scorpion or align esc? - 11/18/2009 11:14 PM
ace22459
Score: 100
Status: offline
I have never had a problem with my Scorpion ESC's. I'm running Scorpion 2221-8 motors with both the 35 and 45 in T-Rex 450's. I have never used the governor mode on any of my ESC's. Just a flat 100% throttle curve. From what I have read here on the forums, most guys just run a flat curve instead of governor mode as they usually don't work very well. You don't have to run 100%, you could go something like 85% in normal, 90% in idle 1, and 100% in idle 2. By the way, I did smoke the Castle ESC once and they did replace it under warranty. Alan
Hide Signatures
       Post #: 6
RE: Scorpion or align esc? - 11/20/2009 11:21 AM
TheStapler
Score: 100
Status: offline
Well i went with the scorpion 45a v2 it looks like the best value for money. there isn't really any hobby shop what sell good esc for heli in Australia.
will be upgrading my align 450x later hopefully the esc doesn't get as hot as my old one.
for a align 450x motor what setting should i run the esc at?
thanks!
Hide Signatures
       Post #: 7
RE: Scorpion or align esc? - 11/20/2009 5:02 PM
ace22459
Score: 100
Status: offline
The factory defaults should work just fine. You will want to make sure you have it in helicopter mode to get the soft start function. You can then set it for how long it takes to fully spool up. Make sure the brake is off and for the timing, use the auto setting. Alan
Hide Signatures
       Post #: 8
RE: Scorpion or align esc? - 1/3/2010 5:40 AM
TheStapler
Score: 100
Status: offline
well i got my Scorpion esc and all i beening having is problems with it.
first had it running with my align 430x motor and it had problems spinning up. plus when i would be flying the motor would start glitching.
so i brought a scorpion motor ran that with my old esc ran perfect! change to the scorpion esc my it spins up fine but seem to be getting glitch still.
i'm going to try running it with out the IR receiver connected.
if anyone else has any ideas feel free to tell me.
i'm using a DX6i
thanks
Hide Signatures
       Post #: 9
RE: Scorpion or align esc? - 1/3/2010 8:18 AM
TheStapler
Score: 100
Status: offline
i think i have found the problem its is the connecter on the IR receiver. when i riggly the esc cable when its plug it glitch or reset the esc.
so would it be ok to run without the IR receiver connected??
can you buy a new IR receiver?
don't know if i can bother with warrenty might get stuffed around
Hide Signatures
       Post #: 10
RE: Scorpion or align esc? - 1/3/2010 2:33 PM
Cleared2Engage
Score: 105
Status: offline
Isn't the IR receiver only on the esc when you are programing?
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.828RCU1
