Choosing airfoils based on calculated polars
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld Sukhoi SU-26MX - RTF
Seller:  BAGOSTIX
Details:   $8,800.00   |  11/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Choosing airfoils based on calculated polars
Page: [1]
Login
Choosing airfoils based on calculated polars - 7/5/2003 6:33:55 AM
yclui
Status: offline
Hello,
I have just download the Profili and after getting acquainted with the functions, the first thing I did was to compare the polars of HN354 and S4083 at Re = 216K which is typical for 60” slope racers in moderate lift conditions.
These are the polars of HN354 and S4083 plotted by Profili. HN354 is the airfoil used in my 60” slope racer http://www.euro-sailplanes.co.uk/uk/html/sport-hlg/mini-nyx.htm and the S4083 is used in my 60” HLG http://www.euro-sailplanes.co.uk/uk/html/sport-hlg/highlight.htm . The polars indicates that HN354 performs poorer than S4083 at high Cl and I wonder why it is still chosen for my slope racer as one of the major requirements for racers is that it won’t loose speed in tight turn.
I am trying to learn the basics of model design and if someone can kindly shed some light on this, I will appreciate it.
Y C Lui
Click to see fullsize image.
Click for fullsize
       Post #: 1
Choosing airfoils based on calculated polars - 7/8/2003 5:50:31 AM
Ben Lanterman
Status: offline
You would need to calculate the turn rate (load factor) which can give the lift needed and then the CL needed to achieve the turn and see where it falls on the polars. The CL needed to turn might still be in the low CL area where the drag is a little lower. But keep in mind that although aerodynamics is rocket science that it isn't always applied with precision. You are headed toward a good start in your learning quest though.
_____________________________
Ben Lanterman
(in reply to yclui)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU3
