Seeing double? Naa, that's just my new Cor-Star 60!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Seeing double? Naa, that's just my new Cor-Star 60!
Page: [1] 2   next >   >>
Login
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 7:05:31 AM
Deadeye
Status: offline
Here she is, my Sig Four-Star clone!
Click to see fullsize image.
Click for fullsize
_____________________________
Randy Rossmiller, proud husband of Terrorist Hunter www.shannenrossmiller.com
       Post #: 1
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 7:06:19 AM
Deadeye
Status: offline
And here she is with her weak sister.
Click for fullsize
(in reply to Deadeye)
       Post #: 2
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 7:07:18 AM
Deadeye
Status: offline
Everything is 4 mil coroplast: fuse, turtledeck, wings, tail, control surfaces, etc....
Click for fullsize
       Post #: 3
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 7:10:20 AM
Deadeye
Status: offline
She weighs in at 9 1/4 pounds. Her weak balsa sister weighs 8 1/4. Extra pound is in the wings. Fuse was actually lighter than the balsa one until I painted her.
Click for fullsize
       Post #: 4
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 7:54:17 AM
Ross Kean
Status: offline
I'm most impressed. I may just show these to a 4* nut in our chub who is as anti-spad as they come. "SPADS are OK I guess, but I wouldn't fly one" Thanks for sharing!
Ross
       Post #: 5
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 8:00:09 AM
Tattoo
Status: offline
Incredable workmanship!!!! That is a really awesome job!
       Post #: 6
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 8:03:23 AM
Piraro76
Status: offline
Looks sweet.
Nice work, Deadeye
The norse god of planewreckin' ;D
       Post #: 7
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 9:58:16 AM
PigMan Buggerus
Status: offline
Any Chance you have plans for this? It looks great!
The Voice of the Angry!
http://www.voxirati.com
       Post #: 8
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 9:49:20 PM
Deadeye
Status: offline
I do have plans, but I don't know how I would reproduce them. I simply measured, and drew out the profile of my balsa 4* by laying it on it's side and drawing around it.
The airfoil isn't the same as the 4*, but I sure tried like hell. I couldn't get the coro to bend as abrupt as it's balsa counterpart. However, I think I have it figured out now. 2 guys in our club want one now, (even before the test flight) and one guy is going to cut his own wing out of foam, but the other guy will go with all coro. So he will get the first of the cloned wing airfoil. Mine is more flat bottomed, which I think will be OK due to the increased weight of the thing. It should only make it more stable. I wonder how a 2 mil wing would work? I've never seen or felt 2 mil coro, but I assume it must be about half the weight of the 4 mil.
A flight report will follow as soon as the friggin' wind stops blowing up here in MT. The whole month of June has been 20 MPH days, calming down about 30 minutes before dark. And now it's spilling over into July.
Everything on this bird is identical to it's balsa sister. with two exceptions; it's airfoil, and I made my ailerons a constant chord verses the tapered ailerons on the original. I can't wait to get her in the air.
       Post #: 9
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 9:57:01 PM
Deadeye
Status: offline
I wasn't sure how ChrisSpad did his turtledeck on his beautiful coro Cap, but this is how I did mine on the Cor-star. It proved to be very easy to do, and the taper factor was no problem after I shaved the flutes out like I did.
Click for fullsize
       Post #: 10
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 9:57:58 PM
Deadeye
Status: offline
A closer look:
Click for fullsize
       Post #: 11
Seeing double? Naa, that's just my new Cor-Star 60! - 7/5/2003 9:58:31 PM
Deadeye
Status: offline
And one more.
Click for fullsize
       Post #: 12
Seeing double? Naa, that's just my new Cor-Star 60! - 7/6/2003 2:50:09 AM
BenJammin
Status: offline
Great work Deadeye! Now find yourself some 2 mil and get it even closer to the same weight as your balsa 4*.
Your turtle deck is pretty much the same meathod I use on my 1/12 scale radial engine fighters. I just slit every other flute but don't remove the extra piece. For added strength I heat a piece of 2 mil and curve it then glue that inside, makes it rock solid.
If you ever get down this way, let me know. Maybe we can get together and do a little flying.
       Post #: 13
Seeing double? Naa, that's just my new Cor-Star 60! - 7/6/2003 3:22:34 AM
Deadeye
Status: offline
I'd love to find some 2 mil. Do you know of any coroplast dealers in Billings? Where do you get yours, Ben?
       Post #: 14
Seeing double? Naa, that's just my new Cor-Star 60! - 7/6/2003 3:25:38 AM
BenJammin
Status: offline
Montana Mouldings in Billings has it in white and they can order colors. They have all the 4 mil you can use in all colors.
The toll free phone # is: 1-800-342-2353
       Post #: 15
Seeing double? Naa, that's just my new Cor-Star 60! - 7/6/2003 3:31:16 AM
Deadeye
