hobbycity mirage 4000 flown !
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
T-45 V1 Composite - SAPAC - ARF
Seller:  BeanerECMO
Details:   $240.00   |  3/20/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> hobbycity mirage 4000 flown !
Page: [1]
Login
hobbycity mirage 4000 flown ! - 11/19/2009 10:12 PM
foodstick
Score: 119
Last Login: 3/21/2010
Status: offline
Well,
This was my first EDF, it went together simple and quick. I did have an issue with the supplied epoxy..I didn't think it setup as good as it should have.. I have mixed my share of epoxy, this just seemed different. Anyhow it setup and was ok. It just had me worried for awhile. The only real problem I had was a lock key on the motor shaft was broken I was able to get a new 25 cent piece from the hardware store.
The initial flight used a 2350 4 cell lipo 25c, and I was a bit nose heavy..being overly safe turned into a problem as I had some cheap receiver in the plane and combined with the balance issue I nearly lost it..I got it back on the ground, rebalanced, and set my reflex on the elevons a little higher..BINGO
I now have 5 issue free flights .. I adjusted the servo travel on the retracts to keep it from folding on taxi.
Its not super fast, but on a gray day it still doesn't take long to get out of visual with the light color scheme.
I have only been flying two short flights of around 3 minutes each charge so far. I want to get a feel for the plane and the length I can stretch the battery run time before I accidently have to deadstick it. It behaves well on landing approach, I am still unused to the long flat warmish glide though.
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10014&Product_Name=Mirage_4000_Fighter_w/_Brushless_EDF_&_Retracts_Plug-n-Fly
< Message edited by foodstick -- 11/20/2009 1:00 AM >
_____________________________
A builder can not be broken ..only his airplanes can !
Self proclaimed RC addict member #1
Hide Signatures
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
