Voodoo U/C Video
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Voodoo U/C Video
Page: [1]
Login
Voodoo U/C Video - 11/20/2009 8:44 PM
iflyg450
Score: 100
Last Login: 3/19/2010
Status: offline
http://www.youtube.com/watch?v=_r0fN2YQq5M
Here is a clip of my first Voodoo flight
Hide Signatures
       Post #: 1
RE: Voodoo U/C Video - 11/21/2009 1:32 AM
build light
Score: 100
Last Login: 3/21/2010
Status: offline
Sweet!
Robert
_____________________________
Roll Tide! FINAL:
Alabama beats Texas 37-21 for 2010 BCS national championship! Go Bama!
Hide Signatures
(in reply to iflyg450)
       Post #: 2
RE: Voodoo U/C Video - 11/27/2009 4:17 AM
jayseas
Score: 100
Last Login: 3/20/2010
Status: offline
Looks like she flys pretty good.Nice.What length lines are you using?
Jim
Hide Signatures
       Post #: 3
RE: Voodoo U/C Video - 11/27/2009 1:56 PM
iflyg450
Score: 100
Status: offline
65' lines sir
Hide Signatures
(in reply to jayseas)
       Post #: 4
RE: Voodoo U/C Video - 11/27/2009 6:16 PM
jayseas
Score: 100
Status: offline
Are you using .018 lines?
Hide Signatures
       Post #: 5
RE: Voodoo U/C Video - 11/27/2009 9:09 PM
iflyg450
Score: 100
Status: offline
yes
Hide Signatures
       Post #: 6
RE: Voodoo U/C Video - 11/29/2009 2:56 AM
green river rc
Score: 100
Last Login: 3/16/2010
Status: offline
Got a close up of that bird?
With the parts left over, I''m going to build a motorcycle.
Hide Signatures
       Post #: 7
RE: Voodoo U/C Video - 11/29/2009 5:16 AM
cutaway
Score: 100
Status: offline
If that was built with the 1960's vintage plans amount of line sweep, on 65' .018's, its probably going to be pretty light on the lines during maneuvers. The rules back then were 60' .015's. Around the time the rules changed to .015's and Goldberg subsequently came out with the longer tailed VooDoo, there was an plans addendum that had you moving the leadouts back about 1/2" from the plan location.
When I scratch built a short tailed one last year, I moved the leadouts back per the addendum and its line tension was good in all attitudes.
Hide Signatures
(in reply to green river rc)
       Post #: 8
RE: Voodoo U/C Video - 11/29/2009 12:34 PM
iflyg450
Score: 100
Status: offline
I did move the leadouts back it is short tailed. I got a set of full size plans with templetes off ebay
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 9
RE: Voodoo U/C Video - 11/29/2009 2:12 PM
Jim Thomerson
Score: 131
Status: offline
Looks to me like you have the long tailed version. I built one of Bear's monoboom airplanes for sport flying. I put in adjustable leadouts as I did not think the positions shown on combat plans were optimal. I was wrong.
Hide Signatures
       Post #: 10
RE: Voodoo U/C Video - 11/29/2009 6:26 PM
jayseas
Score: 100
Status: offline
Hey guy's how for from the Trailing edge is the leadout and how far apart should the lines be at the leadouts?
It does look like a long tail.
Jim
Hide Signatures
(in reply to cutaway)
       Post #: 11
RE: Voodoo U/C Video - 11/29/2009 8:24 PM
Jim Thomerson
Score: 131
Status: offline
The lines should be as close together as you are comfortable with. I will let a more knowledgable person tell you where they should come out.
Hide Signatures
       Post #: 12
RE: Voodoo U/C Video - 11/29/2009 10:10 PM
iflyg450
Score: 100
Status: offline
could be a long tail like I said I just made it to the print. It does a loop in about 4'
Hide Signatures
(in reply to Jim Thomerson)
       Post #: 13
RE: Voodoo U/C Video - 11/29/2009 10:21 PM
jayseas
Score: 100
Status: offline
Jim, could you explain what you mean by. "The lines should be as close together as you are comfortable with"
Hide Signatures
       Post #: 14
RE: Voodoo U/C Video - 11/30/2009 1:42 AM
Jim Thomerson
Score: 131
Status: offline
Ideally the lines should exit the wing through one hole. If they are separated as shown on all plans of yesteryear, The airplane will yaw every time you give it control. Try suspending the airplane from one leadout, then the other. If they are far separated, you will easily see the change in yaw angle. On 35-40 size stunters, I put them @ 5/8 apart. On a 1/2A stunter they come out one hole. I make my leadouts different lengths.
Hide Signatures
       Post #: 15
RE: Voodoo U/C Video - 11/30/2009 4:15 AM
jayseas
Score: 100
Status: offline
That is interesting.i will try your suggestion on my next plane.
Hide Signatures
       Post #: 16
RE: Voodoo U/C Video - 11/30/2009 5:39 AM
cutaway
Score: 100
Status: offline
You built the long tail one.
There's some pics of my short tailed one here.
Hide Signatures
       Post #: 17
RE: Voodoo U/C Video - 11/30/2009 4:43 PM
jayseas
Score: 100
Status: offline
From whom do you all buy your balsa from?
Hide Signatures
       Post #: 18
RE: Voodoo U/C Video - 11/30/2009 4:53 PM
cutaway
Score: 100
Status: offline
I wind up going to probably a half dozen different hobby shops within a 200 mile radius when I'm looking to stock up on wood. Finding the right piece of wood for a particular purpose can be a daunting task. Whenever I find an outstanding piece I'll buy it even if there's no particular need at the moment. About 95% of the wood in a hobby shop bin will be warped, wrong density, or wrong grain for your specific application.
Finding really superior wood is difficult. Sometime you'll wind up settling for mediocre just to get something finished and in the air.
Hide Signatures
       Post #: 19
RE: Voodoo U/C Video - 11/30/2009 6:06 PM
jayseas
Score: 100
Status: offline
What you describe is why i was asking, i have one hobby store and two craft stores in the area, and it is hard to find decent pieces of balsa.
Hide Signatures
       Post #: 20
RE: Voodoo U/C Video - 11/30/2009 6:21 PM
BtnFlyGuy
Score: 105
Status: offline
I live in MA and get my balsa from National Balsa:
http://www.nationalbalsa.com
The quality is excellent and the prices competitive.
Most balsa from hobby shops is, as mentioned, less than optimal but will do for repair wood. It's main drawback is consistency and price. Buying from a distributor such as National is more likely to  give you consistent grade. In some cases, I have had several sheets cut from the same log, great for "bookending" (a joinery term) to give good sheet splices.
This is a good Balsa factoid blurb...
http://www.sentex.net/~mec1995/hobby/sigbal.htm
I am "almost" OCD...and that bothers me.
Check my homepage!
Hide Signatures
       Post #: 21
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.202RCU1
