RE: 1/2a Biplane    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: 1/2a Biplane Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: 1/2a Biplane - 11/29/2009 6:57 PM
flyinrog
Score: 109
Last Login: 5/24/2013
Status: offline
Oh, wait, is that the one you gave to a friends son and he crashed it?...I remember the pic, not sure of the story...Rog
_____________________________
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
Hide Signatures
(in reply to Bipe Flyer)
       Post #: 26
RE: 1/2a Biplane - 11/30/2009 3:25 AM
jeffie8696
Score: 120
Last Login: 5/25/2013
Status: offline
This little thing makes me woozy. It is the Herr Pitts at Sig , Totally Sweet!!!
Click to see fullsize image.
Click for fullsize
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to flyinrog)
       Post #: 27
RE: 1/2a Biplane - 11/30/2009 3:44 AM
Tom Nied
Score: 100
Status: offline
That is cool. Do they have ailerons on just the bottom wing?
Hide Signatures
(in reply to jeffie8696)
       Post #: 28
RE: 1/2a Biplane - 11/30/2009 7:10 AM
jeffie8696
Score: 120
Status: offline
I dont know, I will check with Mike Lee at Sig.
Hide Signatures
(in reply to Tom Nied)
       Post #: 29
RE: 1/2a Biplane - 11/30/2009 12:42 PM
Bipe Flyer
Score: 105
Last Login: 12/3/2012
Status: offline
quote:
ORIGINAL: flyinrog
That's the one. I don't think he's ever flown it though.
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 30
RE: 1/2a Biplane - 11/30/2009 6:52 PM
jeffie8696
Score: 120
Status: offline
Just ailerons on the bottom wing. Is it that significant if they are large enough?
Hide Signatures
       Post #: 31
RE: 1/2a Biplane - 11/30/2009 11:24 PM
Bipe Flyer
Score: 105
Status: offline
It's significant if the bottom wing is stalled and the top is not.
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 32
RE: 1/2a Biplane - 12/3/2009 6:45 PM
skaliwag
Score: 100
Status: offline
Here's an older design. You would have to add ailerons. Scroll down to Schoolgirl.
http://www.selecthobbies.com/kitdata.htm#Early%20RC%20Kits
And there is a Honker Bipe plan.
http://www.rcmplans.com/index.php?main_page=product_info&cPath=11&products_id=1374
< Message edited by skaliwag -- 12/3/2009 8:09 PM >
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
       Post #: 33
RE: 1/2a Biplane - 12/3/2009 7:43 PM
combatpigg
Score: 376
Status: offline
Here's one thrown together out of balsa sticks, bamboo skewers, cellophane covering, Spiderline controls....based on the Ultimate Bipe.
The flat bottom airfoil was an experiment to see if it would hold it's place in the sky better during upright flat spins and tumbles....it does pretty well.
Click for fullsize
Click for fullsize
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to skaliwag)
       Post #: 34
RE: 1/2a Biplane - 12/3/2009 8:31 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: skaliwag
Yeah - the Bipe came out shortly after the original Honker and used the same wing (if you had built a Honker, your wing construction was already half done ). The plans called for a .15 to .25 - it would fly fine with a .15; with a .25, it was "sporty" to say the least.
There was an even later offering by Dave Thornberg (designer for the Honker series) called the Honker Rocket which was used for some class racing. It was essentially a Honker with the fuselage cleaned up a bit.
All three planes used a Jedelsky airfoil making them some of the original SWR's.
andrew
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 35
RE: 1/2a Biplane - 12/14/2009 11:56 PM
Trinut
Score: 105
Status: offline
I am thinking of a 1/2 a bipe using one set of ace constant cord foam wings I had.
After you add ailerons, they come out to a six inch cord, and each section is 18 inches long.
I noticed this is the correct cord and wingspan for a scaled down Bill Warwick "hot canary",
which is a negative stagger racing bipe. I found some planes on line for a 30'' span version for American Modeler Magazine and scaled those down.
(Top flight did one at about 36 inch span for a .40)
18 inch span looks crazy small, but it is about the same proportions as the top flite sized one, and that flew ....
It would be so simple to use the molded foam wings as they are, in their 18 inch sections.
What do you think?
Hide Signatures
(in reply to Andrew)
       Post #: 36
RE: 1/2a Biplane - 12/15/2009 12:22 AM
Bipe Flyer
Score: 105
Status: offline
The ACE Simple Ultimate uses those wings. My Bipe Stik uses lighter foam copies of the same wing.
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to Trinut)
       Post #: 37
RE: 1/2a Biplane - 12/15/2009 12:44 AM
Trinut
Score: 105
Status: offline
Bipe flyer
Yes I saw the wire-cut reproductions of the ace molded wings.
I am familliar with the ace bipe that used them too - that was for a .10 or .15
What is unique abaout the bipe I am proposing is that it uses only one set, unjoined, so it would have about 200 sq inch wing area, the same as the simple series ment for 1/2a's.
So it would be an 18 inch span negative stagger bipe for 1/2a.
I'll try and frame someting up and post it ...
Hide Signatures
       Post #: 38
RE: 1/2a Biplane - 12/15/2009 12:56 AM
Bipe Flyer
Score: 105
Status: offline
Oh, I see what you mean. I would have thought the Hot Canary would have a narrower, longer wing than that. From looking at a 3 view a 6" chord would be a 28" span.
I built I bipe using the panels as you described, makes for very fast roll rates.
Click for fullsize
Click for fullsize
Click for fullsize
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 39
RE: 1/2a Biplane - 12/15/2009 1:11 AM
Trinut
Score: 105
Status: offline
Thats it !!!!!!!!
Thrue, 6 x 18 inch doesn't scale from that drawing of the actual plane. I scaled it from a .40 size published in American Modeler magazine - take a look
http://www.rcgroups.com/forums/showthread.php?t=965961&highlight=hot+kanary
Which cox engine/prop is that? I have a norvel big mig .049 I was thinking of using.
Regarding the fast roll rate, the .40 size I am scaling from had ailerons on the bottom wng only, which I think I would do too, for such a short span.
Thanks so much for posting your bipe, it really encourages me to give it a try.
Hide Signatures
       Post #: 40
RE: 1/2a Biplane - 12/15/2009 3:52 AM
Bipe Flyer
Score: 105
Status: offline
At first I thought they shortened the wings in the drawing for space, but when checking the scale indicator against the chord on the side view of the fuselage, then using that to calculate the span and scale it to 18" without the wing tips, you get a chord of 6". I've never seen a Hot Canary with wings that short.
The engine is a pre-Revlite Norvel AME .061 with an APC 5.7X3 prop.
To be perfectly honest that wasn't my best design. The aspect ratio of the wings, thick airfoil and having 2 of them made for a very draggy plane.
I prefer ailerons on both wings because you can run into a situation where one wing is stalled and the other is still flying, especially if you use different incidences on each wing. For example, it's not uncommon to put the bottom wing at a few degrees relative to the top wing - if you get slow or at high AOA the bottom wing can stall while the top wing has not, giving you no aileron control. In the case of the Hot Canary, it's actually preferable to have the bottom wing stall first because, as it is the forward wing, the CG would shift forward, dropping the nose and building up airspeed. Of course things like stagger and using different airfoils on each wing change the stall characteristics of each so I just stick to zero incidence for both wings and ailerons on both. Also, I believe that rolls are more axial when your control surfaces are not so far offset from the centre line of the plane.
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 41
RE: 1/2a Biplane - 12/19/2009 4:17 AM
Honker1
Score: 100
Last Login: 1/11/2013
Status: offline
Hello all,
Well I am finally home for about two weeks!! Will retire to the basement soon and start cutting balsa and building 1/2a like I do every year. I really appreciate everyones plans that were posted, I plan on building the Jn-4, Waco, Bandito and the Niewport. I love 1/2a, probably because most of my young life I got a Cox P-51 control line for Christmas every year and I flew it until the wings broke (really)!
Hope everyone has a great break however long it is (I used to get no break, finally seniority has caught up!) Build some planes to fly this spring, life is short, enjoy what time is left.
Honker1
Hide Signatures
       Post #: 42
RE: 1/2a Biplane - 12/19/2009 8:10 PM
Jaspur_x
Score: 100
Last Login: 3/5/2013
Status: offline
I was lookingfor a similar project for my building season. I`m having a hard time trying to find anything at all from clancy aviation. I really wanted to downsize their bipe to an .010 or .020 size. I would settle for a ladybug or yard bee though in case anyone runs across anything, or knows anyone, etc.
Hide Signatures
       Post #: 43
RE: 1/2a Biplane - 12/20/2009 2:41 AM
Bipe Flyer
Score: 105
Status: offline
I tried to find one too and finally gave up and drew a partial plan.
Just let me know what file format you want and shoot me your email address.
Click for fullsize
1/2A all the way!
Club Saito #151
Hide Signatures
(in reply to Jaspur_x)
       Post #: 44
RE: 1/2a Biplane - 12/20/2009 5:54 AM
MJD
Score: 125
Status: offline
quote:
ORIGINAL: Trinut
What do you think?
My low wing monoplane with one 17" piece of ACE wing and an .049 works fine, and glides really well. So single pane; ACE wing things are feasible, yes.
I try to be pessimistic, but why bother?
Hide Signatures
       Post #: 45
RE: 1/2a Biplane - 12/20/2009 6:16 AM
Boomerang1
Score: 120
Status: offline
quote:
I was thinking a loose Jenny, SE5 , Moth. Slow, light....
I can help you out with an SE5, a 1/10 scale version at about 30 inch span, motor shown is a Mills 1.3 diesel.
PM me if you are interested. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 46
RE: 1/2a Biplane - 12/20/2009 6:22 AM
Boomerang1
Score: 120
Status: offline
Other plans for small engines I would never build, but would be a shame to throw out are:
Farman Moustique, for a 25 size engine.
Short Skyvan, engines shown are two Medallion or Tee Dee 049's.
D.H Moth minor for 20 size engine.
Luscombe Silvaire, 15 to 20 size engine.
Not 1/2 A, but I'm not likely to build a 40 size Fokker EIII either, who wants it?
John.
Hide Signatures
(in reply to Boomerang1)
       Post #: 47
RE: 1/2a Biplane - 12/20/2009 6:31 AM
Boomerang1
Score: 120
Status: offline
Aeromodeller plans which I no longer have but you may be able to trace are the Bristol Scout, Sopwith Triplane & Nieuport II.
These were all free flight plans, all sheet construction, so simple to build.
I tried them free flight with Babe Bees, the Scout was a good flyer, the Nieuport not so good.
Never got around to the Triplane. - John.
Hide Signatures
       Post #: 48
RE: 1/2a Biplane - 12/20/2009 6:39 AM
Boomerang1
Score: 120
Status: offline
Whoa! Just dug out a couple more, designed for electric but convertable:
Bristol Beaufighter, my guess, for two 10 size engines, hand launched.
Sopwith 1 1/2 Strutter, designed for a speed 600, a 20 to 25 would do the job.
John.
Hide Signatures
       Post #: 49
RE: 1/2a Biplane - 12/20/2009 8:03 AM
fullfun
Score: 100
Last Login: 3/28/2013
Status: offline
well if you don't find anything from now to march check out the cpaa.us website and see about the biggest flea market down at the lebanon fairgrounds in march i'll definately be there
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.842RCU1
