RE: Electric Retracts - Modifying existing Air/Servo-operated Retracts    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Robotics and Autonomous Robots >> RE: Electric Retracts - Modifying existing Air/Servo-operated Retracts
Page: <<   < prev  2 3 4 5 6 7 8 9 [10] 11   next >   >>
Login
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/11/2010 8:13 AM
trickydevil
Score: 100
Last Login: 5/18/2013
Status: offline
There is a ready available micro processor unit available for this very type of problem, from S.M. Services.
It's called "screw jack controller", believe it or not! It's about half way down the page if you paste in the link below.
http://www.smservices.net/acatalog/Large_Model_Units.html
Hope this is some help,
Richard
Hide Signatures
(in reply to Larry3215)
       Post #: 226
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/11/2010 10:44 AM
Larry3215
Score: 100
Last Login: 11/8/2011
Status: offline
Thanks Richard!
_____________________________
Larry
Hide Signatures
(in reply to trickydevil)
       Post #: 227
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/11/2010 9:20 PM
Boeing314
Score: 100
Last Login: 3/19/2012
Status: offline
Here's a link to the video of my retracts installed in my Cessna 310:
http://www.youtube.com/watch?v=r2oViHbOuDY
Hide Signatures
       Post #: 228
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/11/2010 9:52 PM
Larry3215
Score: 100
Status: offline
Very nicely done!!!
Larry
Hide Signatures
(in reply to Boeing314)
       Post #: 229
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/11/2010 11:17 PM
mark_d
Score: 100
Last Login: 9/8/2010
Status: offline
I'm not sure Larry.  You could use a programmable controller to interpret the pwm in and a stepper driver at each actuator to drive them with out the need for feedback.
Hide Signatures
       Post #: 230
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/15/2010 1:00 AM
Boeing314
Score: 100
Status: offline
We tried using the stepper motors but found them very low in torque and consumed a LOT of power...they got quite hot.
Hide Signatures
(in reply to mark_d)
       Post #: 231
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/15/2010 4:05 AM
Larry3215
Score: 100
Status: offline
I was looking at those and the total cost of a stepper and controllers puts it out of the price range too.
I havent seen anything that can compete with what Tom came up with originally as far as cost.
If it wasnt for the programing of the controllers, anyone could do it
Larry
Hide Signatures
       Post #: 232
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/15/2010 8:24 PM
monocoupe
Score: 100
Last Login: 5/4/2013
Status: offline
Boeing 314,
The Cessna landing gear is impressive! Thanks for the video.
Richard,
Thanks for the link to SM. I contacted them and unfortunately (for me anyway) the unit is for end points only. Great for this thread's topic of landing gears!
Cheers, Nigel
M.A.A.C. 6949
Hide Signatures
       Post #: 233
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/24/2010 11:22 PM
Boeing314
Score: 100
Status: offline
Thanks, Monocoupe.
Just an update on our progress.
Boards: I just got two of the dual layer boards from China 2 hrs ago. Here's a pic of one of them, and I must say I'm very impressed with the quality we got. We're going to fab up this board for the second prototype (I ordered 3 more motors to make a set of stronger retract units). My programmer has made more changes to the board design, however. The second generation board we'll be making is half the size of this one (and therefore half the cost). I'll be meeting with him in Norman, OK on Tuesday. I'm going there myself for and electronics course, and won't be back til May 25th.
Software: We've updated the electronics code to get rid of some troublesome software bugs we were having. I'm hoping to try the new program in my Cessna on June 12th, where we'll be flying it in Denver for a few days for testing. I hope to work on the project later this spring after my class lets out.
Click to see fullsize image.
Click for fullsize
< Message edited by Boeing314 -- 4/25/2010 8:14 AM >
Hide Signatures
(in reply to monocoupe)
       Post #: 234
RE: Electric Retracts - Modifying existing Air/Servo-op... - 4/30/2010 12:37 AM
stagger123
Score: 100
Last Login: 4/30/2013
Status: offline
looking for help with my e flite bonanza .iam snapping my front wheel in the grass on landings 8 flights snapped two front gear .anyone have a fix  or suggestion thanks
                     Staggerr
Hide Signatures
(in reply to TOMAPOWA)
       Post #: 235
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/2/2010 6:20 PM
vampire67
Score: 100
Last Login: 7/10/2010
Status: offline
Hope I'm not the killjoy.
Just found this chinese electrical gears: http://easytigermodels.com/index.php?main_page=product_info&cPath=11&products_id=171
Assuming from the look and the cables running to each gear it seems to have no limit switches and is likely based on the same idea as being discussed here.
Could of cause also being simpler and just timer related.
Anything usable from the controller front yet ?
I'm about to modify a pair of mechanical retracts with the geared motors.
But I can use it only with a matching controller.
Those china PCB seems strange to me.
They seems not to contain the controller or the motor driver.
Or is this a deception?
I would rather suggest doing a simple 1/2 channel controller with controller and driver on board.
Peter
Hide Signatures
(in reply to stagger123)
       Post #: 236
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/2/2010 6:31 PM
vampire67
Score: 100
Status: offline
Upppps, double post ...
Hide Signatures
       Post #: 237
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/2/2010 8:14 PM
Boeing314
Score: 100
Status: offline
I am currently in school, so cannot work on the project atm. I'm waiting for version 3 of the retract board to come back from the printer which will allow the user to define the limits of the gear doors and their timing without the use of a computer. The newest version of the code requires us to assemble the new board. Here's a pic of the version 1 board assembled:
Click for fullsize
Hide Signatures
(in reply to vampire67)
       Post #: 238
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/2/2010 8:57 PM
vampire67
Score: 100
Status: offline
quote:
ORIGINAL: Boeing314
Do I get this right that the board is just a breadboard to wire the connections to the motor drivers and is somehow attached to the Arduino board ?
Peter
Hide Signatures
       Post #: 239
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/4/2010 2:01 AM
Boeing314
Score: 100
Status: offline
Peter
Yes. Its a circuit board designed with standoffs to attach to the top of the Arduino board, providing a fast and convenient way to tie the two motor controllers, switches and servo outputs to one board. You can power it several ways, including from the Arduino itself, or a separate battery supply just for the servos. The newer version of this will be much smaller, about half this size. It also makes use of the newer programming (which includes gear door control) after all the gear are successfully retracted.
Hide Signatures
       Post #: 240
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/11/2010 1:13 AM
cjbotox
Score: 100
Last Login: 5/20/2013
Status: offline
Alright, I've gotta do this. I have a pair of Robart 630's and I'm totally sold on this electric DIY concept. Need help on  basic key components.I understand the motor and where to get it. But could someone please submit a detailed list of all those other parts? Tom mentions 'clamshells" and limit switches, 4-40 all thread, what about drilling and tapping the drive sleeve (existing) in the unit that connects to the pneumatic arm?
And I like the idea of 'pressure' bearings installed but at what two points?
When I'm done with these babies, I'll be back for the electronics, which won't be difficult for me, my friend's an electronic engineer.
Thanx
Hide Signatures
       Post #: 241
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/12/2010 7:05 PM
cjbotox
Score: 100
Status: offline
Hold the phone - found answer to my question by looking back over the thread on POST 95.
And should anyone else have missed the DIY spot like I did, check out Tom's forum at: http://www.laureanno.com/RC/E-Retracts.htm
John
Hide Signatures
(in reply to cjbotox)
       Post #: 242
RE: Electric Retracts - Modifying existing Air/Servo-op... - 5/31/2010 10:34 PM
TOMAPOWA
Score: 110
Last Login: 3/19/2013
Status: offline
I finally got my DIY retracts in the wing of my Zero... tested sat.... probably fly her in the next week or so... weather permitting.
(video taken with iphone so quality is hokey... but it gets the point across).
TOMAPOWA
Hide Signatures
       Post #: 243
RE: Electric Retracts - Modifying existing Air/Servo-op... - 6/26/2010 7:23 AM
Down and Locked
Score: 105
Last Login: 5/10/2013
Status: offline
Guys if you are in need of electric retracts at Down And Locked we offer conversions for most all brand's of retracts on the market old, new, air or mechanical, If interested take a look at www.downandlocked.com and visit the FAQ or feature's page for a full description of what these offer and how they work. Then give us a call or email we would love to hear from you. Thanks Mitch Stott
Mitch Stott Co-owner Down And Locked
Hide Signatures
       Post #: 244
RE: Electric Retracts - Modifying existing Air/Servo-op... - 6/29/2010 6:59 PM
4DFlyer
Score: 100
Last Login: 12/21/2011
Status: offline
quote:
ORIGINAL: promod1
Wow that is one shamless plug Mitch!
I thought this was a DIY Retract thread.  Looks like you "took" the fellas idea and exploited it man!  Shame Shame...
Hide Signatures
(in reply to Down and Locked)
       Post #: 245
RE: Electric Retracts - Modifying existing Air/Servo-op... - 7/11/2010 9:14 AM
secatur
Score: 100
Last Login: 4/18/2012
Status: offline
What GearMotor did you use ?
Hide Signatures
       Post #: 246
RE: Electric Retracts - Modifying existing Air/Servo-op... - 7/12/2010 9:51 AM
secatur
Score: 100
Status: offline
Does anyone know if the controller unit for the smaller electric tri gear sets (Easy tiger F100) available would support larger motors ? If yes, this could solve the controller problem.
Hide Signatures
(in reply to secatur)
       Post #: 247
RE: Electric Retracts - Modifying existing Air/Servo-op... - 7/19/2010 5:50 PM
cjbotox
Score: 100
Status: offline
Thanks Mitch for letting us know you're out there, and I see you have a honorable track record. I am too busy/lazy for a DIY project like this and even though I have already started on the basic mods, I'd rather do business with you. This thread has been very interesting and informative, but the underlying sum (especially near the beginning) was the lack of commercial interest to answer the present need. My only question is WHERE HAVE YOU BEEN? I've been looking/googling electric retract systems for almost a year now, and this was where I finally landed.
NOTE: this guy's web site shows at least 2 years of manufacturing retro fits for ANY brand retract, and an up-front post to backlog wait with a gaurantee not to charge/bill until ready for shipment.
John
Hide Signatures
(in reply to 4DFlyer)
       Post #: 248
RE: Electric Retracts - Modifying existing Air/Servo-op... - 7/13/2011 1:47 AM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
I see it's been almost one year since anybody has posted about the DIY E-Tracts.  I, like many here, have no problem with the mechanical side of the hobby, but electrical stuff quickly overwhelms me.  I’m good with an iron as long as I’m told “pin A in hole B then solder”.
Down and locked looks to have a nice product, but it’s frustrating not to be able to get an idea on pricing without making contact.  Gosh, how hard would it be to give half a dozen examples and the cost???
 edit;   E-mailed D&L.  $350 average cost to mod my exsisting retracts!  To rich for my blood
So, What has been the progress on the electronics to control the screw jacks?  It sounded like good thing coming and we are left hanging.
Thanks!
Ken
< Message edited by kenh3497 -- 7/14/2011 1:54 PM >
Sent from my Dry-Erase-Board
Hide Signatures
       Post #: 249
RE: Electric Retracts - Modifying existing Air/Servo-op... - 7/14/2011 5:17 PM
Jag Fan
Score: 100
Last Login: 7/4/2012
Status: offline
you can always go to www.wingspanretracts.com and check those guys out. they sell linear actuators to replace the air cylinders on your air retracts and is a cheaper option than down and locked. worth looking into at least.
Rich
Hide Signatures
(in reply to kenh3497)
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
