Vogt Exhaust Restrictor Throttle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Vogt Exhaust Restrictor Throttle Page: [1]
Login
Vogt Exhaust Restrictor Throttle - 7/5/2003 8:42:18 PM
boberos
Status: offline
Here attached is the original 2 piece Carl Vogt Exhaust Restrictor Throttle from American Modeller June 1967.
It is/was used on Cox engines that had a flanged cylinder but will work as well on straight cylinders. A small lathe is required.
Hope this helps.
Bob G
Click to see fullsize image.
Click for fullsize
       Post #: 1
Vogt Restrictor - 7/5/2003 8:48:01 PM
boberos
Status: offline
Sorry about the dark background on the image. It was dark in the magazine as well.
It came from the "Radio Control World - Grid Leaks " column by Howard McEntee.
(in reply to boberos)
       Post #: 2
Vogt Exhaust Restrictor Throttle - 7/5/2003 10:11:57 PM
BMatthews
Status: offline
[SIZE=3]THAT'S THE ONE ! ! ![/SIZE]
It was later reprinted in American Modeller with that same drawing I'm sure.
This is the one that I was tallking about in the 010 thread.
_____________________________
Witty saying to be plagarized shortly.....
       Post #: 3
The magic of Photo Shop - 7/6/2003 12:52:32 AM
William Robison
Status: offline
Try this:
Bill.
Click for fullsize
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
       Post #: 4
Vogt Exhaust Restrictor Throttle - 7/7/2003 5:16:23 AM
prole
Status: offline
I know that this picture is kind of an unspecific angle which leaves quite a bit to be desired but do you guys think this is one?
Thinking about picking this up, any of you guys know how these work compared to the Cox/Ace R/C ones?
Click for fullsize
AMA 776580
VR/CS 405
       Post #: 5
Proes restrictor - 7/8/2003 10:25:59 PM
boberos
Status: offline
Hi Prole,
It looks like some one else's version of the Vogt unit.
The heavy spring makes me think it is manually adjustable only & not servo operated.
Try it & let us know.
Bob G
       Post #: 6
Vogt Exhaust Restrictor Throttle - 7/9/2003 12:45:53 AM
fritzke
Status: offline
I think that heavy clip is to hold the two halves together, the looped wire in the lower right is for servo/throttle operation.
Looks simple enough, and better idle than a carb (no flame-outs).
dave
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.844RCU3
