Flair DR1 Manual    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Fokker DR-1 - 90
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> Kit Building >> Flair DR1 Manual
    Page: [1]
    Login
    Flair DR1 Manual - 11/23/2009 4:32 PM
    Robtck
    Score: 105
    Last Login: 6/16/2013
    Status: offline
    I was woundering if anyone has a Flair DR1 manual they can copy or sale. My Dr1 is about 70% built and my manual is missing after moving. I called Radical RC which is the importer for Flair. They had no manuals and said they have problems getting parts from Flair. If I can't get a manual, I should be about finish it without a manual, but it would easier with a manual.
    Robert
    Hide Signatures
           Post #: 1
    RE: Flair DR1 Manual - 11/26/2009 12:34 PM
    Hughes500E
    Score: 105
    Last Login: 6/17/2013
    Status: offline
    I have a Flair DR1 manual. Send me your email and I'll send you a scan of it. It's only 8 pages and does not appear to get too technical!
    Cheers
    Steve
    Hide Signatures
    (in reply to Robtck)
           Post #: 2
    RE: Flair DR1 Manual - 11/26/2009 6:06 PM
    eagledancer
    Score: 110
    Status: offline
    i also have one, if he doesnt come through send me a pm
    if you want some hints on take offs and landings with this bird let me know. took me awhile but i finally got to where i was greasing landings with it
    _____________________________
    I once had a drinking problem.....I divorced it, now shes someone else''s problem
    waco brotherhood # 140
    Hide Signatures
    (in reply to Hughes500E)
           Post #: 3
    RE: Flair DR1 Manual - 11/26/2009 9:48 PM
    Robtck
    Score: 105
    Status: offline
    Any help on how this plane flies would be great.
    Robert
    Hide Signatures
    (in reply to eagledancer)
           Post #: 4
    RE: Flair DR1 Manual - 11/27/2009 3:43 AM
    eagledancer
    Score: 110
    Status: offline
    on and off the ground is the difficult part, this plane will do the fokker dance without hesitation! when it does happen chop throttle and dont even think about horsing it off the ground the results are not pretty
    #1 rule: always and i mean always take off and land directly into the wind, no crosswinds for this bird or you will ground loop.
    first off the best way for the take off run is hold full up elevator to keep the skid firmly on the ground until enough speed is reached that the tail will become effective, add throttle slowly but steady all the while keeping it straight with rudder, when speed is up a bit relax up elevator tail will come up at this point you may have to hold a bit of down to keep the plane on the ground until flying speed is attained when you have the speed add up elevator to rotate off the ground and climb out.
    on landing keep a bit of power on this plane slows fast with all the drag. never try to 3 point it, always do tail up landings. when you are over the end of the runway chop throttle but dont forget about it you will need it again! set her down at a slow flying speed with the tail up as you are slowing a few blips of throttle will keep the rudder and elevator effective. if she starts to nose over use throttle usally a blip or two will get the tail back down. let the tail come down on its own. keep on the rudder until it stops.
    i found if i follow this to the letter i can do picture perfect takeoffs and landings every time! and people always thought i was a fantastic pilot to never nose it over LOL
    hope this helps, the flair tripe is a nice flying bird
    Hide Signatures
           Post #: 5
    RE: Flair DR1 Manual - 11/27/2009 3:53 AM
    eagledancer
    Score: 110
    Status: offline
    here is mine before i sold it
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Hide Signatures
           Post #: 6
    RE: Flair DR1 Manual - 11/28/2009 5:24 AM
    Robtck
    Score: 105
    Status: offline
    Thank you for the insight. Your Dr1 looks nice. What engine did you use?
    Hide Signatures
           Post #: 7
    RE: Flair DR1 Manual - 11/28/2009 4:06 PM
    eagledancer
    Score: 110
    Status: offline
    flew nice with supertigre 3000
    Hide Signatures
           Post #: 8
    RE: Flair DR1 Manual - 5/11/2010 1:00 AM
    smartmart99
    Score: 100
    Last Login: 5/11/2012
    Status: offline
    Steve
    I  too have just obtained a Flair DR1 kit and the build instructions were missing, if you still have the instructions I would be very gratfull if you could scan them for me (martinlee@hickorygardens.wanadoo.co.uk) What engine did you put in yours?
    Hide Signatures
           Post #: 9
    RE: Flair DR1 Manual - 5/23/2010 6:25 PM
    Robtck
    Score: 105
    Status: offline
    smartmart99
    Are you still looking for instructions for the DR1?
    Robert
    Hide Signatures
    (in reply to smartmart99)
           Post #: 10
    RE: Flair DR1 Manual - 5/23/2010 11:49 PM
    smartmart99
    Score: 100
    Status: offline
    Robert
    Yes, if you have a set I would really appreciate a pdf or a photo copy, and if you have already built one I have some technical queries I could do with a hand with.
    Martin
    Hide Signatures
           Post #: 11
    RE: Flair DR1 Manual - 5/24/2010 7:17 PM
    Robtck
    Score: 105
    Status: offline
    I can scan the instructions and email it to you. Right now i'm covering mine in fabric. I will try to answer any questions you have.
    Robert
    Hide Signatures
           Post #: 12
    RE: Flair DR1 Manual - 5/25/2010 10:01 AM
    djay
    Score: 100
    Last Login: 6/12/2013
    Status: offline
    Hello Robert.
    can you read your instructions and tell me where the CofG is supposed to be.
    I have finished my DR1 but the instructions have beem filed away as I am in the middle of moving house.
    But you have to get your priorities right and I want to test fly the plane before moving.
    many thanks
    Darryl
    I used to land in English cow poo, now I land in Camel poo. Plane still smells the same though.
    Hide Signatures
           Post #: 13
    RE: Flair DR1 Manual - 5/25/2010 10:20 PM
    smartmart99
    Score: 100
    Status: offline
    Robert
    My email is martinlee@hickorygardens.wanadoo.co.uk.  Have you managed to conceal the servo wires from the top wing down the cabanes? If so I could do with some ideas. Also what engine have you chosen, I am still undecided, I have a OS 120 pump but I might go petrol if I can find an engine which will keep her under 7.5kg.
    Hide Signatures
           Post #: 14
    RE: Flair DR1 Manual - 5/26/2010 2:52 AM
    eagledancer
    Score: 110
    Status: offline
    on mine i put the servo wires inside a piece of brass tube running down the left rear cabane. worked out well.
    on the gas engine i tried a 1.6 and it wasnt enough to fly it. this has a huge amount of drag. but i also weighed in at 17 lbs if i remember right. ended up with a supertigre 3000 and it was enough but no extra. if i was to do it again i would either set the firewall back enough for a g-38 or use a moki 2.10
    Hide Signatures
           Post #: 15
    RE: Flair DR1 Manual - 5/26/2010 8:44 AM
    djay
    Score: 100
    Status: offline
    I have for the test flight just fixed the wires down the outside surface of the rear struts, unless you look you cannot see them, small hole in the wing and a small tie wrap top and bottom, leads passing through the lower wing
    I have an RCV 1.30 in mine which hopefuly will be more then enough.
    I have the Flair Hannibal which is larger and heavier and this flies fine on a 1.20 four stroke.
    Will find out Friday morning when i test fly it, at least I have 250 metres of tarmac runway to take off from.
    Hide Signatures
           Post #: 16
    RE: Flair DR1 Manual - 5/27/2010 2:59 AM
    eagledancer
    Score: 110
    Status: offline
    good luck on your maiden and make sure you look at my above post on takeoffs and landings!
    Hide Signatures
    (in reply to djay)
           Post #: 17
    RE: Flair DR1 Manual - 5/27/2010 5:19 PM
    Robtck
    Score: 105
    Status: offline
    The CG from the Flair manual "nose down by about 3 degrees when it is supported at a point 65mm back from the leading edge of the middle wing."
    Good luck on your maiden flight.
    Robert
    Hide Signatures
           Post #: 18
    RE: Flair DR1 Manual - 5/30/2010 8:08 AM
    djay
    Score: 100
    Status: offline
    Went to test fly the DR1, but the engine would not idle.
    it is an RCV 1.30 fs, whith only about 30 minutes running on it before it seized and rusted up inside. I only got it back from the manufacturer 4 days ago after extensive repairs which despite the engine having a 2 year warranty, suprisingly, everything that needed repalcement was not covered. One of the things I sent it back for was, it would not idle. And after a lot of money spent on it, it still does not idle.
    I will try again next weekend with different fuels and plugs, but considering it was supposed to have been test run after repair, the low end needle was so far in , no fuel at all passed through it.
    Darryl
    Hide Signatures
           Post #: 19
    Page:   [1]
    Page: [1]
    Fokker DR-1 - 90
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.812RCU1
