RE: Wild Hare Electrics    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Wild Hare Electrics Page: <<   < prev  1 2 3 4 5 [6] 7 8 9   next >   >>
Login
RE: Wild Hare Electrics - 12/20/2010 3:09 AM
theSteam
Score: 100
Last Login: 3/20/2012
Status: offline
quote:
ORIGINAL: droland
BTW, I picked up a couple of these Friday.
Two of the 540's, but one was suppose to be a Slick.
For those of you that have them, did any of you find that the canopy latch would not work.
Mine will not budge and I can't get the canopy off.
Tom says maybe it got glue on it during the construction.
If anyone has had the issue and found a solution, I'd like to hear about it.
Thanks, Dan
I found you must lift the ball lever up before sliding it.
Sorry if you already knew that
Hide Signatures
(in reply to droland)
       Post #: 126
RE: Wild Hare Electrics - 12/20/2010 11:37 AM
droland
Score: 100
Last Login: 8/26/2012
Status: offline
Thanks for the tip.
I have the canopy off now.
Dan
Hide Signatures
(in reply to theSteam)
       Post #: 127
RE: Wild Hare Electrics - 12/20/2010 4:40 PM
Jonathan Ott
Score: 105
Last Login: 5/23/2013
Status: offline
Mine was difficult and stickie too at first, but it'll loosen up with use.
Jon
_____________________________
Jonathan Ott
Extreme Aerosports
Hide Signatures
       Post #: 128
RE: Wild Hare Electrics - 12/20/2010 9:42 PM
theSteam
Score: 100
Status: offline
You are welcome
Hide Signatures
(in reply to Jonathan Ott)
       Post #: 129
RE: Wild Hare Electrics - 12/23/2010 12:10 AM
droland
Score: 100
Status: offline
quote:
ORIGINAL: rctom
quote:
Then I'll have a servo package with 4 Hitec HS-81s TF
Tom, will there be a fitment issue with the HS-81 since it is about 29mm long and the servo mount is 23mm long.
Is there enough re-inforcement behind it to trim out that far and still have enough left for the servo screws?
Hide Signatures
(in reply to rctom)
       Post #: 130
RE: Wild Hare Electrics - 12/23/2010 3:30 PM
rctom
Score: 114
Last Login: 6/19/2013
Status: offline
Yes and no. The elevators and rudder servo mounts will need to have the interior backing plates trimmed back. The main holes are the proper size for the hs-81 if the backing pieces, which allow a smaller servo to be recessed, are cut away. This only takes a few seconds to do with a razor knife.
The aileron servo holes do not have those backing pieces so the hole must be lengthened a little, there is plenty of room to do this and again it only takes a few seconds.
TF
Hide Signatures
       Post #: 131
RE: Wild Hare Electrics - 12/24/2010 6:04 PM
peteb
Score: 100
Last Login: 10/22/2012
Status: offline
I have a question that I am almost embarrass to ask. I am building up a E-Slick-540, and after bolting on the motor and cowling I am having a hard time figuring out how to tighten the prop nut. I hold the prop and spinner backing plate but when I try to tighten the prop nut the motor turns. As I have about 1/8” clearance between the spinner back plate and the cowling I see no way to hold the motor shaft in order to tighten the nut. Am I overlooking something here?
The only thing I can think of at this point is to custom build a spanner wrench that will fit the motors prop adapter from 1/16” aluminum.
There must be an easier way to do this?
peteb
peteb
Cleveland, Texas
Hide Signatures
(in reply to rctom)
       Post #: 132
RE: Wild Hare Electrics - 12/24/2010 8:16 PM
theSteam
Score: 100
Status: offline
quote:
ORIGINAL: peteb
peteb
I haven't gotten to the point of tightening the prop nut yet. VERY good question!
I await an answer as well...
Hide Signatures
(in reply to peteb)
       Post #: 133
RE: Wild Hare Electrics - 12/25/2010 11:02 AM
rctom
Score: 114
Status: offline
There are a couple ways to do it that I have found, others may have more ideas.
The simplest method is to simply twist the prop against the shaft as you tighten the nut to hold the shaft in place with friction. Once it starts to snug up against the hub the prop should grab and hold. This is always subject to how the spinner backplate tightens against the hub, it works better with a metal backplate spinner.
The other way is simply to file or grind two flat spots on opposite sides of the tip of the shaft and hold the shaft with a small wrench or pliers until the nut starts to tighten.
TF
Hide Signatures
       Post #: 134
RE: Wild Hare Electrics - 12/25/2010 6:35 PM
cap10b
Score: 105
Last Login: 2/25/2013
Status: offline
All,
Try cutting circles out of 240 or 320 sticky back sand paper. You can stick it to the drive washer or the back of the prop.
Twist the prop like Tom says and tighten the nut down. I find you dont have to really torque the nut down with the sandpaper more than just snug it tight.
hope this helps.
jds
< Message edited by cap10b -- 12/26/2010 2:35 AM >
I ran out of Altitude, Airspeed and Ideas !
Hide Signatures
(in reply to rctom)
       Post #: 135
RE: Wild Hare Electrics - 12/26/2010 2:03 AM
peteb
Score: 100
Status: offline
Thanks for the ideas rctom, and cap10b. I will give them a try. Much better than trying to fabricate a custom tool.
peteb
Cleveland, Texas
Hide Signatures
(in reply to cap10b)
       Post #: 136
RE: Wild Hare Electrics - 12/26/2010 3:02 AM
droland
Score: 100
Status: offline
I was test fitting some parts today.
Seems one of my ailerons is warped quite a bit and twisted.
I can't get it flush with the wing. It ends up with a gap on one end or the other.
Anyone know how to go about fixing this?
< Message edited by droland -- 12/26/2010 3:25 AM >
Hide Signatures
(in reply to peteb)
       Post #: 137
RE: Wild Hare Electrics - 12/26/2010 6:19 PM
peteb
Score: 100
Status: offline
Alright!!
A combination of twisting the prop and spinner back plate and a sandpaper disk behind the spinner back plate did the trick. The prop nut is tight.
Thanks guys,
peteb
Cleveland, Texas
Hide Signatures
       Post #: 138
RE: Wild Hare Electrics - 12/26/2010 6:25 PM
rctom
Score: 114
Status: offline
quote:
ORIGINAL: droland
The normal procedure is to report the problem to Wild Hare so we can get a replacement out to you.
TF
Hide Signatures
       Post #: 139
RE: Wild Hare Electrics - 12/26/2010 6:32 PM
droland
Score: 100
Status: offline
Tom, I didn't want to trouble you on Christmas if it was something easy to take care of.
So I assume it is not an easy fix and needs replacing from your post.
Do I need to call or email you now that you know about it?
Hide Signatures
(in reply to rctom)
       Post #: 140
RE: Wild Hare Electrics - 12/27/2010 6:32 AM
jcubby
Score: 100
Last Login: 5/1/2013
Status: offline
I have been to the web site for wild hare. Noticed the sale on the 540 electrics. Read this entire thread and an interested in getting one. I could not find a way to order on the site. How do I order one?
Hide Signatures
       Post #: 141
RE: Wild Hare Electrics - 12/27/2010 2:47 PM
rctom
Score: 114
Status: offline
quote:
ORIGINAL: jcubby
Call. 817-430-0107.
Hide Signatures
(in reply to jcubby)
       Post #: 142
RE: Wild Hare Electrics - 12/29/2010 7:52 PM
peteb
Score: 100
Status: offline
Question for Droland.
I saw the picture you posted of the cooling air exhaust cutouts on the bottom of your plane and was curious as to how they are working. Do you think they are doing the job?
peteb
Cleveland, Texas
Hide Signatures
(in reply to rctom)
       Post #: 143
RE: Wild Hare Electrics - 12/30/2010 6:50 AM
droland
Score: 100
Status: offline
quote:
ORIGINAL: peteb
That picture was copied from one of  CYCLONEMAN55 posts on page 2..
I have since also noticed the louvers in the cowl and sure would like to know how to do that.
Mine is not fying yet.
Got my wings and stabs on.
I must say I like the way it looks since I already have the 88" version.
Hide Signatures
(in reply to peteb)
       Post #: 144
RE: Wild Hare Electrics - 12/30/2010 3:52 PM
peteb
Score: 100
Status: offline
Thanks droland,
I went back and took a look at CYCLONEMAN55 pictures. Can’t tell if those are louvers in the cowl or just slots. Bet that took a lot of time with a dremel tool. Being located on the front portion of the cowl I would think that is a high pressure area and would be taking in air instead of letting the air out. Unless they are true louvers. Just a guess on my part since I am not an aerodynamicist. I had to look that word up in the dictionary.
peteb
Cleveland, Texas
Hide Signatures
       Post #: 145
RE: Wild Hare Electrics - 12/31/2010 8:08 AM
rcpilot_971
Score: 105
Status: offline
Im also looking to buy one of these 540s but would like to know what the price would be for a plane power kit and servos
Tim
Hide Signatures
(in reply to peteb)
       Post #: 146
RE: Wild Hare Electrics - 12/31/2010 1:55 PM
RCNUTKNOY
Score: 100
Status: offline
Tim,
Go to the Wild Hare web site. They are on sale until the 3rd of January, 2011. There is a deal on the power unit as well. A new servo package is in the works as well. I have one of the slicks on order. This will be my 5th Wild Hare. Give Tom a call and he will be happy to tell you all the pricing.
John
Hide Signatures
(in reply to rcpilot_971)
       Post #: 147
RE: Wild Hare Electrics - 12/31/2010 2:06 PM
rctom
Score: 114
Status: offline
With 5 HS-81s the price is $260 with plane, servos and power kit.
There's another servo kit with 4 HS81s and a standard size HD-3001 (or we can substitute several other servos) for $275 total and it includes a pull-pull kit.
Shipping is $20 in lower 48 states if you get the power kit, $15 without the power kit.
TF
Hide Signatures
       Post #: 148
RE: Wild Hare Electrics - 1/2/2011 6:22 PM
rcpilot_971
Score: 105
Status: offline
well I got two of these planes on the way
now I need to order some batteries for them what is everyone using. I was looking at the zippys from hobby king 4cell 3300 - 4000 will thes be ok and what c raitng should I get 25c-30c 40c or is there bettery batteries for a little more money this will be my first electric plane and I dont have any batteries this big
Thanks Tim
Hide Signatures
(in reply to rctom)
       Post #: 149
RE: Wild Hare Electrics - 1/8/2011 6:06 PM
rcpilot_971
Score: 105
Status: offline
I got mine yesterday friday everthing looks good now I just need to order some batteries what is eveyone using 4 cell ? 3300 ? 4000 ? And what C25 ? 30 ?
Thanks Tim
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.484RCU1
