Jazzy
MHawker, The units mentioned in Howardm4's post will work ok for your criteria. I have two Supernovas and it only takes a half hour or so to top off each pack after flying. There are several ways to fully charge your packs without having to buy, and sometimes wait for, a charger/cycler that'll do everything you want it to do. I assume, (gee, I hate to assume), that you have the wall warts that came with your systems. Just plug'em in when you get home and the packs will be ready for the next day. Check out the Battery Clinic for tips about using wall warts. I currently have 6 wall warts, 2 Supernovas, 1 Accucycle, 1 Hobbico Quick Peak, 1 Glowbee Ni-starter charger, and an older Hobbico 6-8 cell adjustable current timed charger. I also have the peak charger that came with my park flyer but, it is basically just a battery toaster. With a little ingenuity, I can use all of my chargers in the vehicle, at the field, and at home. The more time you spend in this hobby the more devices you'll accumulate. I use all of my chargers for different applications. Diversity can be a good thing. Someday the electronics guys will get together with the computer programers and come up with a device with software that'll do everything anyone could want and have an optional kitchen sink.
_____________________________
Aww $#!^.... I left the )@#& transmitter at home!
