scratch built hot wire cutter    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> scratch built hot wire cutter Page: [1] 2   next >   >>
Login
scratch built hot wire cutter - 12/2/2009 12:14 AM
sir crashallot
Score: 105
Last Login: 1/9/2012
Status: offline
right guys and girls. just been reading a website and iv seen somthing done that could very well work for making foam core wings.
Ijust want to run the ideas past you all first before i go and try it.
in the picture is what iv seen, would this work if i built a frame 40inch long with some thin guitar wire or simular in place of the copper wire they have used.
Click to see fullsize image.
Click for fullsize
_____________________________
A true brother does not have to be blood related it can be anyone you choose who you deem fit to be called a brother
Hide Signatures
       Post #: 1
RE: scratch built hot wire cutter - 12/2/2009 12:26 AM
stang
Score: 100
Last Login: 5/3/2013
Status: offline
The problem that I see is that a lot of wire looses its strength when heated and you get a terrible mess. I have used nichrome wire for cutting foam wings and that didn't loose its tension. I used a large bow and made templates of the wing and a buddy and I cut a few in an evening. I am not sure how your red gadget will work. Give it a try and let us know.
Religion- the curse of mankind
Hide Signatures
(in reply to sir crashallot)
       Post #: 2
RE: scratch built hot wire cutter - 12/2/2009 12:39 AM
sir crashallot
Score: 105
Status: offline
well thats not actualy mine, the theory is there though but it needs fine tuning for it to work and i was hopeing someone on here may have an idea towards it. i wont be using such thick wire i want to keep the wire down to a minimum to allow it to not work as a resistor.
Hide Signatures
(in reply to stang)
       Post #: 3
RE: scratch built hot wire cutter - 12/2/2009 2:25 AM
Rhilluk
Score: 100
Last Login: 12/30/2012
Status: offline
search for nichrome wire on ebay, should pick some up really cheaply.
My Hotwire cutter was homemade, it is 36 inches long and has two hinged end pieces. it looks like a long flat H. On one side I have some springs (You could use Bungee) to keep the tension and on the other I have the wire. Works of a car battery charger no probs
Rich
Hide Signatures
       Post #: 4
RE: scratch built hot wire cutter - 12/2/2009 2:29 AM
sir crashallot
Score: 105
Status: offline
thanks pal, have you any pictures of it. nice to hear someone from this side of the pond, especialy when it comes to tools that have to run off 240volt.
Hide Signatures
(in reply to Rhilluk)
       Post #: 5
RE: scratch built hot wire cutter - 12/2/2009 3:01 AM
Laird SS
Score: 100
Last Login: 5/19/2013
Status: offline
The wire needs to act as a resistor to get hot. If it were a good conductor, it wouldn't get hot. That's the way those things work. Nichrome wire is your best bet. It's made to work when it's hot.
Hide Signatures
       Post #: 6
RE: scratch built hot wire cutter - 12/2/2009 5:18 AM
ppljr
Score: 100
Status: offline
A lot of people use stainless steel fishing leader as a cutting wire. It can be bought relatively cheaply and in bulk. Don't ask me the thickness though.
Hide Signatures
(in reply to Laird SS)
       Post #: 7
RE: scratch built hot wire cutter - 12/2/2009 5:28 AM
combatpigg
Score: 376
Last Login: 5/20/2013
Status: offline
.020" Stainless aircraft safety wire works very well, rarely breaks, not too much stretch. Nichrome sucks, it's much smokier and breaks much more easily.
In 25 years of hot wiring foam and dozens of planes all I've ever used is a $7 light dimmer switch. I cut with 115 VAC as the input to the dimmer. I burned out the original switch after about 15 years worth of use, so I'm "on" my 2nd one now.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to ppljr)
       Post #: 8
RE: scratch built hot wire cutter - 12/2/2009 5:36 AM
sir crashallot
Score: 105
Status: offline
thanks for all the ideas guys, im taking every thing in from every one, soon as i get to build it over the weekend il put some pics up and some reports to you all
Hide Signatures
(in reply to combatpigg)
       Post #: 9
RE: scratch built hot wire cutter - 12/2/2009 8:52 AM
pjsorrentino
Score: 100
Last Login: 1/9/2010
Status: offline
I get my nichrome wire for my homemade foam cutter fromm www.pnjresources.com. They are cheap and fast delivery.
Hide Signatures
       Post #: 10
RE: scratch built hot wire cutter - 12/2/2009 9:57 AM
OzMo
Score: 113
Last Login: 5/18/2013
Status: offline
SS leader wire Bass Pro (on line) had it the cheapest.
the set up in your pic would be sweet for cutting thin sheet foam for little electric planes etc. kind of like a band saw.
Yes dear, I did glue my hand to the airplane to keep from dropping it.
Hide Signatures
(in reply to pjsorrentino)
       Post #: 11
RE: scratch built hot wire cutter - 12/2/2009 2:09 PM
kdc
Score: 115
Last Login: 5/17/2013
Status: offline
You need a lot of tension in the cutting wire, otherwise it lags in the middle of the foam and does not cut the correct profile. that is why the bow needs at least 8 SWG piano / music wire (English size, not US size which is different ) and fairly short length too ( say 10 inches or so ) if you use wire 'legs'. A wooden bow rather like an old fashioned carpenters bow saw tensioned with cord is easier to make. Your gadget would be best left to make cutouts for servos and U/C blocks.
For cutting wire I use wire taken from an old electric fire element, the spiral wound type from 1950's & 60's ( English 240 volt type ) this makes many. many lengths of cutting wire.
Hide Signatures
(in reply to OzMo)
       Post #: 12
RE: scratch built hot wire cutter - 12/2/2009 5:42 PM
sir crashallot
Score: 105
Status: offline
wel kdc the though of using it for cuting out servo hole locations and so forth never actualy ocourd to me. it would indeed if used correctly be perfect for that job. but the thought of being able to me turtle decks and foam veneared wings and tails and rudders and so forth would save time and weight in some cases. and it has its strength factors. i see this as a project that has some very good features that would be of great use to me and i doubt it would be a waste of time money and effort in building one. thanks for the idea kdc of using it for cutting servo holes out and so forth.
Hide Signatures
(in reply to kdc)
       Post #: 13
RE: scratch built hot wire cutter - 12/2/2009 6:46 PM
kdc
Score: 115
Status: offline
If the gadget gets the temperature ( volts ) right for a small cutting wire it will be too cool for a much longer wire unless the longer wire is much thinner. So for a longer wire you need more volts to get sufficient temperature. Also if the tension is not sufficient you wreck the foam and waste money before you realise the wire has lagged in the middle! I suggest building a proper bow for wings & turtle decks, keeping the gadget intact for other jobs.
< Message edited by kdc -- 12/2/2009 7:35 PM >
Hide Signatures
       Post #: 14
RE: scratch built hot wire cutter - 12/2/2009 6:51 PM
sir crashallot
Score: 105
Status: offline
yep i agree, well a friend is sending me some of that wire everyone is talking asbout the nicrome or somthing or other, il be building a bow from pvc tubing and il make a power source as i dont own a car battery charger. i did at one point till it got lent out then magicaly re apeared batterd and broken. i do however own a small hifi thats past its usable date, so il rob its 240volts to 12v powerpack inside and use a dimmer from maplins to control the power. il also put a fuse system in place too.
Hide Signatures
(in reply to kdc)
       Post #: 15
RE: scratch built hot wire cutter - 12/2/2009 7:49 PM
kdc
Score: 115
Status: offline
pvc tube will probably bend under the strain. The temperature can be varied,if necessary by an aligator clip connection moved along the cutting wire, better than a dimmer I think.
Photos of my 'free' cutter are below. Tube is 3/4 inch OD aluminium from old TV aerial ( watch for weakness due to corrosion ), legs from 10SWG piano wire offcuts ( 8 SWG is really needed) with 'eye' bent into the end, cable is thick wires from scrapped washing machine, couple of bolts, washers and wingnuts ( ex TV aerial ) Note wooden plug (from tree which fell down in garden ) to insulate ends. cutting wire is from electric fire element. Power is from transformer from old gas boiler but and old car battery charger wiould suit ( they go wrong at the rectifier but 12 volt AC is OK ) or a car battery itself. Current needed is considerable.
You can see how much the 10 SWG is bent from right angle under the essential strain.
Better to copy the bow saw style in wood I think. Whether saw or foam cutter the strain has to be considerable to work well, therefore the construction too.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: scratch built hot wire cutter - 12/6/2009 8:20 AM
TripleDeucer
Score: 101
Last Login: 5/11/2013
Status: offline
My bow is just a 3/4" X 3" X 30" straight wood. I used a couple 12" aluminum arrow shafts drilled in at each end at an outward angle. I have been using a guitar E string for wire. Nichrome works well too. My power is an old electric train transformer and I can vary the heat range according to the foam and length of cut. If your wire is nice and tight and it is flexing, your either going too fast for the heat or your heat range is too cold. My transformer works best at the upper end of its range. With my bow setup, the arrow shafts have enough strength and flex to keep the right amount of tension. Mine hasn't failed me in 20 years.
Mark
Revver #48
Hide Signatures
(in reply to kdc)
       Post #: 17
RE: scratch built hot wire cutter - 12/6/2009 9:40 AM
fritzke
Score: 100
Status: offline
Just a few of the many links for these things:
http://members.fortunecity.co.uk/slmohr/rcinterest2.htm
http://www.public.iastate.edu/~orman/air/cutter/hotwire.html
http://www.nsrca.org/technical/tip_tricks/foam_cutter/foam_cutting_power_supply.htm
http://www.monkeytumble.com/dlg/foam.htm
http://www.charlesriverrc.org/articles/foam_vac/mrcss_foamcutter.htm
Hide Signatures
       Post #: 18
RE: scratch built hot wire cutter - 12/6/2009 6:24 PM
speedy72vega
Score: 114
Last Login: 3/17/2013
Status: offline
I recently made one of the soldering gun cutters as shown. I had a cheap Harbor Freight Iron (60 Watt) that I used for the experiment. I took a piece of wire Coat Hanger and bent it to roughly the shape of a servo. It works great for servo cutouts, but the wire is much too thick for anything bigger. What I did for larger cuts is to take two longer pieces of the hanger and bend them with two right angles, so when installed into the Iron, they resemble a football goalpost, just like in the picture. I bent a loop into the ends, and ran 1 strand of copper wire pulled from a 12ga stranded wire section. It cuts great for widths up to about 3 1/2", but not much more than that. The Soldering Iron just doesn't put out enough power for any more than that.
It is perfect though for small cutouts and trim cuts. If anyone's interested, I can post pics.
Hide Signatures
(in reply to fritzke)
       Post #: 19
RE: scratch built hot wire cutter - 12/6/2009 6:29 PM
sir crashallot
Score: 105
Status: offline
right so he soldering iron is a no no if im wanting to cut foam wings. but it is a yes if i need to cut access holes for servos and landing gear blocks. so thats answered my question that it is not powerfull enough to use to cut wings, so now im off to look on the bay for a train controller, thanks guys
Hide Signatures
(in reply to speedy72vega)
       Post #: 20
RE: scratch built hot wire cutter - 12/6/2009 7:12 PM
kdc
Score: 115
Status: offline
There is really no need for a speed/voltage controller. The speed of the cut can be increased if it is hotter, or the lead can be connected along the nichrome wire with a crocodile clip if necessary. ( note someone on e-bay is selling nichrome wire lengths for a pound or two )
Hide Signatures
       Post #: 21
RE: scratch built hot wire cutter - 12/6/2009 7:16 PM
sir crashallot
Score: 105
Status: offline
i have the nichrome wire coming, its just iv managed to win a train controller for a £1, the train contoller is not just going to be used for the wire cutter, i need it for other things but if its usable with the wire cutter then its a great bonus
Hide Signatures
(in reply to kdc)
       Post #: 22
RE: scratch built hot wire cutter - 12/7/2009 12:42 AM
dreadnaut
Score: 110
Status: offline
I get nichrome wire from McMasterCarr. Remember that as one poster mentioned above, the wire acts as a resistor. Keep in mind that the resistance is a function of material, cross section area, and length. That soldering iron may put out adequate power for a short section of wire, but a bow long enough to cut wing cores may need more power.
Cali is a city in Colombia
I''m from California.
Hide Signatures
       Post #: 23
RE: scratch built hot wire cutter - 12/7/2009 6:42 PM
X3n0
Score: 100
Last Login: 7/10/2012
Status: offline
so what gauge ni-chrome wire DO we get then as there are many ?
Hide Signatures
(in reply to dreadnaut)
       Post #: 24
RE: scratch built hot wire cutter - 12/7/2009 7:57 PM
sir crashallot
Score: 105
Status: offline
gd question, maybee someone should do a thread aqimed at the specs needed for a hot wire cutter and make the thread a sticky.
Hide Signatures
(in reply to X3n0)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
