RE: Electric ZN Line Xigris C2 Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Electric ZN Line Xigris C2 Build Thread
Page: <<   < prev  8 9 10 11 12 13 14 15 16 [17]
Login
RE: Electric ZN Line Xigris C2 Build Thread - 12/14/2011 8:34 PM
Panzi
Last Login: 5/13/2013
Status: offline
which material did you use on post #126 to form the wing on the fuselage?
Panzi
Hide Signatures
(in reply to MTK)
       Post #: 401
RE: Electric ZN Line Xigris C2 Build Thread - 12/29/2011 3:41 PM
najary
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Panzi
Panzi
Hi Panzi,
Sorry for the late answer,
It is epoxy mixed with micro balloon.
Best regards,
Isaac Najary
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Panzi)
       Post #: 402
RE: Electric ZN Line Xigris C2 Build Thread - 2/1/2012 5:03 AM
Panzi
Status: offline
Thank you isaac!
No problem, after studying your thread again and again i found the same question already answerd
But could you tell me whish matereial you used to build the Accu holder? in #105
Thank you!
Arnold
Hide Signatures
(in reply to najary)
       Post #: 403
RE: Electric ZN Line Xigris C2 Build Thread - 2/1/2012 4:06 PM
najary
Status: offline
quote:
ORIGINAL: Panzi
Thank you isaac!
Thank you!
Arnold
Hi Arnold,
The materials are:
2.5 mm Balsa covered with thin fiberglass cloth.
6 mm carbon tubes.
0.6 mm carbon plate.
Best regards,
Isaac Najary
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Panzi)
       Post #: 404
RE: Electric ZN Line Xigris C2 Build Thread - 3/24/2012 6:00 PM
J-P
Status: offline
What is your final CG now ?
J-P
Hide Signatures
(in reply to MTK)
       Post #: 405
RE: Electric ZN Line Xigris C2 Build Thread - 3/26/2012 6:27 PM
najary
Status: offline
quote:
ORIGINAL: J-P
J-P
Hello J-P,
The CG is now 7 mm behind the wing tube (19.5 mm behind the center of the wing tube).
Best regards,
Isaac Najary
Hide Signatures
(in reply to J-P)
       Post #: 406
RE: Electric ZN Line Xigris C2 Build Thread - 7/8/2012 2:01 PM
Panzi
Status: offline
Hallo isaac!
When you changed to q80 (#281) you used a cfk 2mm? Material, and plywood for distance. Did you hat any problems only with a front mounting?
Panzi
Hide Signatures
       Post #: 407
RE: Electric ZN Line Xigris C2 Build Thread - 7/8/2012 3:23 PM
najary
Status: offline
quote:
ORIGINAL: Panzi
Hallo isaac!
Panzi
Hi Panzi,
The plane has now 1,100 flights with no problems only with a front mounting.
See post: 289, 294, 300.
Best regards,
Isaac Najary
Hide Signatures
(in reply to Panzi)
       Post #: 408
RE: Electric ZN Line Xigris C2 Build Thread - 2/27/2013 2:52 PM
najary
Status: offline
Saving 34.4 gram – (124.2 – 89.8).
The new parts were made by Mr. Peter Haase from Germany, Thank you Peter!!!
The temperatures measured with the original parts were: Min. 24 degrees Celsius, Max. 63 degrees Celsius, warm-up 39 degrees Celsius.
The temperatures measured with the Peter's parts were: Min. 22 degrees Celsius, Max. 67 degrees Celsius, warm-up 45 degrees Celsius.
Best Regards
Isaac Najary
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 409
RE: Electric ZN Line Xigris C2 Build Thread - 2/27/2013 2:57 PM
najary
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 410
RE: Electric ZN Line Xigris C2 Build Thread - 3/9/2013 6:19 AM
Panzi
Status: offline
Hallo Isaac!
Very impressive reduction of weight in a small part!!
On your q80 did you fliy with you 20x13 or did you try 3blade propeller?
Panzi
Hide Signatures
       Post #: 411
RE: Electric ZN Line Xigris C2 Build Thread - 3/9/2013 7:53 AM
najary
Status: offline
quote:
ORIGINAL: Panzi
Hallo Isaac!
Panzi
Hi Pazi,
Now I use Q80-14XS with APC 21X13, What was 21X14, see http://www.apcprop.com/v/html/tech_support_notice.html#replacement
Best regards,
Isaac Najary
Hide Signatures
(in reply to Panzi)
       Post #: 412
RE: Electric ZN Line Xigris C2 Build Thread - 3/9/2013 4:34 PM
gaRCfield
Status: offline
Is that the same heat sink, that you ground down? Amazing.
_____________________________
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 413
RE: Electric ZN Line Xigris C2 Build Thread - 3/11/2013 8:40 AM
najary
Status: offline
quote:
ORIGINAL: gaRCfield
Hi Joe,
It is not the same heat sink.
Mr. Peter hasse produce those two new replacements parts.
I fink he sales the kit for 25 Euro.
http://www.facebook.com/ComputertechnikHaase/photos#!/ComputertechnikHaase
Best regards,
Isaac Najary
Hide Signatures
(in reply to gaRCfield)
       Post #: 414
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
