RE: 90 sized engine recommendation    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> RE: 90 sized engine recommendation
Page: <<   < prev  1 2 3 [4]
Login
RE: 90 sized engine recommendation - 12/14/2009 8:35 PM
Desertlakesflying
Score: 120
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: mike31
SUPER TIGRE!
Couldn't agree more......low cost great motor. Reliable.
_____________________________
Back Roads Outlaws Revver #165
Hide Signatures
(in reply to mike31)
       Post #: 76
RE: 90 sized engine recommendation - 12/14/2009 9:32 PM
hairy46
Score: 183
Last Login: 5/26/2013
Status: offline
Yes 1/8 ply is to thin, Go thicker or epoxy some 1/8 together! But 1/8 is not thick enough forsure to hold landing gear and do use blind nuts epoxy them in also making sure you do not get epoxy in the treads.
Hide Signatures
(in reply to ka9fax)
       Post #: 77
RE: 90 sized engine recommendation - 12/17/2009 8:01 PM
DenverJayhawk
Score: 193
Last Login: 5/23/2013
Status: offline
The OS 95AX has arrived
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Desertlakesflying)
       Post #: 78
RE: 90 sized engine recommendation - 12/17/2009 8:29 PM
ka9fax
Score: 105
Last Login: 3/24/2013
Status: offline
Ok will do, did not get to go to hobby shop yet worked over to late. Im going tomorrow after work. Im starting vacation.
thanks
Tony
Hide Signatures
(in reply to DenverJayhawk)
       Post #: 79
RE: 90 sized engine recommendation - 12/17/2009 10:04 PM
bigdanusa
Score: 127
Last Login: 4/30/2013
Status: offline
quote:
ORIGINAL: DenverJayhawk
Are you sure you'll be able to handle all that power? That 95 will pull (2) 6 1/2 lb. Big Stick 60's!
lol
Hide Signatures
       Post #: 80
RE: 90 sized engine recommendation - 12/17/2009 10:57 PM
DenverJayhawk
Score: 193
Status: offline
My plan is to fly it in the Big Stik for as long as possible then eventually move it to either a Twist 60 or a Revolver 60
Hide Signatures
(in reply to bigdanusa)
       Post #: 81
RE: 90 sized engine recommendation - 12/18/2009 12:05 AM
opjose
Score: 280
Status: offline
It will certainly pull both of them ( AT THE SAME TIME! ).
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 82
RE: 90 sized engine recommendation - 12/18/2009 5:30 AM
Gray Beard
Score: 314
Status: offline
opjose - thanks. With my old SK90 engine, i would have problems with a dead stick, similar to the person that posted the same issue with his Funtana 50. I cut and pasted your reply to my email for quick reference.
Basically, when i would go vertical, the engine would run fine. But when I throttled back from full to say mid throttle while the model was in vertical position, the engine would stall. I checked the tank and did a presure test and it was fine. But just in case, I ordered a new plug and stopper kit for the tank. I'll switch out all the fuel lines too.
Here is a problem I have had with one of my SK .91 in a scratch built plane. As soon as my fuel tank burns off about 1/4 the tank is so far away from the engine it wouldn't draw fuel due to lack of pressure. The tank is 8.5 inches away and mounted too low. Today I tried another engine in the plane, an OS .91FS, same thing. I'm going to try {no room} to get the fuel tank higher but I think I will be getting a fuel pump for my SK and just be done with fooling around. That OS you bought is outstanding!!!!
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 83
RE: 90 sized engine recommendation - 2/3/2010 11:43 PM
MAJSteve
Score: 100
Last Login: 3/2/2011
Status: offline
Your experience with that company must be better than mine. I bought a 50cc gas engine from Tom Johnson at the AMA convention on the 9th. He said it would ship on the 11th. On the 20th I called and they gave me some story about replacing the carb blocks. I've tried calling for the past two weeks and don't even get someone picking up the phone. Same with numerous emails to them.
Frankly, I'm NOT impressed with them and will probably have to take legal action to get my money back.
Hide Signatures
(in reply to opjose)
       Post #: 84
RE: 90 sized engine recommendation - 9/27/2012 11:23 AM
monturek
Score: 100
Status: offline
Hi Guys just about to fit the new 22cc Mintor to a GP 60 size stik. Will probably have to have good throttle management. lol.
Hide Signatures
(in reply to MAJSteve)
       Post #: 85
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
