Vacuum former 101
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Vacuum former 101
Page: [1]
Login
Vacuum former 101 - 4/1/2002 10:54:46 PM
bkf
Status: offline
Chad: You inspired me to make a vacuum former. Now I can make those servo / linkage covers I always wanted to. Im going to use an 8" electric burner for the heat. Burner was $6.99. I threw this little diag together. Rest of the parts was $10 and there is enough to make two or three. Found some peg board that has holes that are 2/3 smaller then regular.
< Message edited by bkf -- Apr 22 2002 11:46AM >
       Post #: 1
Vacuum former 101 - 4/2/2002 9:21:21 PM
Chad Veich
Status: offline
Looks good, give it a go and let us know how it works. Make sure your burner is capable of heating the entire sheet fairly evenly. If you get a hot spot in the middle it may prove to be a problem (and it may not, just have to try it!). Looking forward to an update on your progress, Chad.
(in reply to bkf)
       Post #: 2
Vacuum former 101 - 4/2/2002 10:03:50 PM
bkf
Status: offline
Chad: Where should I get the plastic. That warm plastic place charges to much for shipping
(in reply to bkf)
       Post #: 3
building one myself... - 4/2/2002 10:23:09 PM
rcav8or
Status: offline
Where'd you find the burner? Any more/better description on it? I like it better than an oven....
As for the plastic, I looked in the phone book, found a plastics place, and they have .030 in stock, as well as lot's of other sizes...even have a bunch of old coroplast 2mm, for my SPAD's...
Yes, keep us posted on your progress...I have a 33% Extra canopy to do!!!
_____________________________
Roger Phillips
AMA #387890
(in reply to bkf)
       Post #: 4
Vacuum former 101 - 4/2/2002 10:32:59 PM
bkf
Status: offline
Toastmaster 750W 120V has temp control. On sale at any kmart, walmart, food store etc.
(in reply to bkf)
       Post #: 5
Vacuum former 101 - 4/2/2002 11:00:37 PM
bkf
Status: offline
Roger: Ill put it together and put the lengths on the Diagram after Toledo. Bkf
(in reply to bkf)
       Post #: 6
Vacuum former 101 - 4/4/2002 10:46:31 AM
mselby
Status: offline
There are a couple of plastic supply houses in Rochester that will sell you what you need. I am originally from there and when visiting family I bought quite a bit. I think they usually specialize in plexiglass and signing making material. I found them in the local yellow pages.
Mike
(in reply to bkf)
       Post #: 7
Vacuum former 101 - 4/11/2002 7:02:24 PM
VFRTEX
Status: offline
For clear applications, try 2 and 3 liter soda bottles, the plastic is tough and really easy to form. and cheap...my favorite part.
(in reply to bkf)
       Post #: 8
Vacuum former 101 - 4/11/2002 7:06:29 PM
bkf
Status: offline
[QUOTE]Originally posted by VFRTEX
For clear applications, try 2 and 3 liter soda bottles, the plastic is tough and really easy to form. and cheap...my favorite part. [/QUOTE]
I will do that Thanks
(in reply to bkf)
       Post #: 9
Vacuum former 101 - 4/11/2002 8:13:08 PM
mlevings
Status: offline
I made a vacuform box a couple of months ago. I have had exellent luck using an oven for heating. I place the frame that holds the plastic in a wire rack that holds it about 5" above the regular oven racks. Set the temp to 350. Once the oven it hot, I place the plastic/frame in the oven for about 3 minutes or until it sags pretty good. I use a dowel rod to prod it and test for softness. Once it is soft, use a oven mit to grab it and set it on the vacuum box. It's ready to be pulled off in about 2 seconds. I will post pictures of my setup later this afternoon.
Mark
(in reply to bkf)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.750RCU5
