Mini LST center diff questions.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> Mini LST center diff questions.
Page: [1]
Login
Mini LST center diff questions. - 12/8/2009 5:12 AM
slickcb2000
Score: 100
Last Login: 10/27/2010
Status: offline
Well I got my Brushless mini lst in, within about 10 minutes I shredded the center diff.  Has anyone used this and is it worth the money?
http://cgi.ebay.com/LOSI-LOSB1125-BALL-DIFF-wBB-FOR-LOSB1066-GEARS-MINI-LST_W0QQitemZ290366878650QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item439b36f3ba
_____________________________
Losi 8ight T 2.0, Big block T-Maxx, T-Maxx 2.5, Brushless Losi LST mini, Traxxas Slash
Hide Signatures
       Post #: 1
RE: Mini LST center diff questions. - 12/8/2009 5:16 AM
cool-joe
Score: 100
Last Login: 12/13/2009
Status: offline
Personally I would use the MIP balldiff instead of the Losi one.
Have you bothered reading any of the other MLST threads? They will help you get a better understanding of what you're dealing with.
Hide Signatures
(in reply to slickcb2000)
       Post #: 2
RE: Mini LST center diff questions. - 12/8/2009 6:00 AM
slickcb2000
Score: 100
Status: offline
I have looked for some back dated threads.  Didnt find too much info.  So i'm assuming this is a common problem with them?
Hide Signatures
(in reply to cool-joe)
       Post #: 3
RE: Mini LST center diff questions. - 12/8/2009 7:10 AM
cool-joe
Score: 100
Status: offline
quote:
ORIGINAL: slickcb2000
You might try again, there's lots of good info.
Hide Signatures
       Post #: 4
RE: Mini LST center diff questions. - 12/8/2009 8:17 AM
Go-Zilla
Score: 100
Last Login: 8/18/2012
Status: offline
I have that losi one. Works ok. Make sure your slipper clutch is not too tight also, otherwise that little plastic bevel gear in between the center diff and the shaft gear is going to strip too.
MLST/MLST2/MMB... all have similar design with lots of drive tran problem. Once go BL, strips lots of gears on both front & rear, then center. Make sure you are not putting in too much power. Perhaps 1 in 50 owners you will find doesn't have any problem.
Hide Signatures
       Post #: 5
RE: Mini LST center diff questions. - 12/9/2009 5:21 PM
slickcb2000
Score: 100
Status: offline
Well.... I went to my LHS and just got a set of factory replacement parts.  The literally lasted about 10 seconds.  I jb welded it after I stripped the spider gears out.  Maybe since it's locked now it will hold for a little bit anyways.  It's gonna be up for trade soon anyways.
Hide Signatures
(in reply to Go-Zilla)
       Post #: 6
RE: Mini LST center diff questions. - 12/10/2009 6:54 AM
Go-Zilla
Score: 100
Status: offline
Yup, Welcome to the MLST owner club ! Where we spend endless hours and money trying to make the d-mn thing run without something broken inside.
Hide Signatures
       Post #: 7
RE: Mini LST center diff questions. - 12/10/2009 6:27 PM
cool-joe
Score: 100
Status: offline
Since the truck was never designed, nor intended, to be able to handle brushless power if you motor back, and treat them nicely, and use them as they are intended. They tend not to have nearly as many problems relative to keeping them up and running.
If you want race-worthy-speed truck, buy a race-worthy-rig.
Hide Signatures
       Post #: 8
RE: Mini LST center diff questions. - 12/11/2009 5:40 AM
etc1006
Score: 100
Last Login: 6/4/2011
Status: offline
I got one in a trade. I was pleasantly suprised when I did a tear down to clean/inspect that it had the steel diffs front and rear, and a ball diff in the center. Now for a decent slipper for it.
Hide Signatures
       Post #: 9
RE: Mini LST center diff questions. - 12/11/2009 3:35 PM
Go-Zilla
Score: 100
Status: offline
quote:
ORIGINAL: etc1006
MLST has a plastic diff. MLST2, Limited (MMB), these have the metal diff rings & metal pinion gear. But the 4 spider gears inside the diff are plastic thou. That's the only setback.
Hide Signatures
(in reply to etc1006)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.407RCU1
