RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Page: <<   < prev  19 20 21 [22] 23 24 25 26 27 28   next >   >>
Login
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/10/2011 9:33 PM
Pull Up Now!
Score: 140
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: kochj
I honestly do not know what I am looking at...or for...
could you tell me what you see???
THanks..
that's why I was wondering if there is an organized Zama parts site that has diagrams (exploded views) of their various carbs. Because the picture I DID find was useless....too fuzzy to read anything on there.
Optech: Wouldn't it be nice if one could search WITHIN a thread for something? Or, can it be done easily? Maybe so, and I'm just not aware. Thanks!
Hide Signatures
(in reply to kochj)
       Post #: 526
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/13/2011 10:26 PM
kochj
Score: 143
Last Login: 6/15/2013
Status: offline
The internals.....
Got 2-of them... @15$ per carb, it was worth a try...
The diaphram is 2-or more clear stiff plastic...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to Pull Up Now!)
       Post #: 527
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 5:19 AM
kochj
Score: 143
Status: offline
Do you guys know if the 2nd small brass outlet/inlet is if you wanted to install a primer pump ?? (In the 2nd picture right next to the low needle)
And I will have to crimp this off?
I don't think it is for intake tube to connect to?
I would think the carb would be like the Walbro and you have to have the tube line up on the base of the carb where there is a little hole, for intake pressure tube..
Anyone care to jump in on this one?
Hide Signatures
(in reply to kochj)
       Post #: 528
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 12:43 PM
Pull Up Now!
Score: 140
Status: offline
It's a little hard to follow your questions because when you ask about a little hole, you called it a tube. But when REALLY referring to a tube, you called it an inlet. But I probably suffer from a little Aspergers, so it's my problem, not yours.
Anyway, I think you're correct. Just crimp & solder the straight tube. Or cap it off with one of those little caps. This means to start the engine you'll need to be able to cover the venturi with your finger. Turn off the ignition, go to WOT, and flip the prop until your finger is wet. Then it should start. If you actually use the primer as intended, this procedure MAY not be necessary.
Yes, the little hole in the base is the impulse input. It usually just routes to the crankcase. In 4 stroke applications, it goes to the intake stack.
In picture #2, there is a little hole in the face of the base. This hole lines up with the cross shaft of the throttle plate. Look in this hole as you move the throttle to see if there is a little brass plug moving up and down. If it's there, it means you have an accelerator pump.
Hide Signatures
(in reply to kochj)
       Post #: 529
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 4:40 PM
kochj
Score: 143
Status: offline
In this picture, I have at the tip of this screw driver? what? = A primer tube that I should crimp off? Correct?
Click for fullsize
Hide Signatures
       Post #: 530
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 4:42 PM
kochj
Score: 143
Status: offline
In this picture; I have at the tip of my screw driver....??
The hole that lines up with the intake manifold??
Click for fullsize
Hide Signatures
(in reply to kochj)
       Post #: 531
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 5:20 PM
kochj
Score: 143
Status: offline
The tip of the driver must be where a hole would be drilled and the accelerator pump would be, correct?
So if mine doens't have one, is there a issue with that??
Will there be a issue with tank placement??
What purpose of a accelerator pump?
Fuel delivery? Attomization?
Thanks..
Click for fullsize
Hide Signatures
(in reply to kochj)
       Post #: 532
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 5:42 PM
kochj
Score: 143
Status: offline
I just ordered up 2-WT 456's .....from the the Isanti MN store....
I will try the Zama carbs either way....
Hide Signatures
(in reply to kochj)
       Post #: 533
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/14/2011 5:50 PM
w8ye
Score: 318
Last Login: 6/19/2013
Status: offline
The accelerator pump squirts a little extra fuel into the carb throat when you advance the throttle.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to kochj)
       Post #: 534
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/15/2011 3:20 AM
motorhd
Score: 100
Last Login: 6/18/2013
Status: offline
On a Walbro, if there is a hole that exposes the butterfly shaft on the gasket face of the carb, it is has a accellerator pump. The pump is a spring loaded piston that moves on a flat spot on the shaft. It looks like the Zama might be the same from your picture.
Hide Signatures
(in reply to w8ye)
       Post #: 535
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/15/2011 4:16 AM
Pull Up Now!
Score: 140
Status: offline
quote:
ORIGINAL: kochj
Thanks..
No, that is not correct. As I said earlier, look for a hole on the mounting face of the carb, that lines up with the throttle plate's cross shaft. When I say "lines up", I mean the two holes cross each other. In your picture, I'm pretty sure I see just such a hole. Look for a little brass piston moving up & down when you rotate the throttle lever. Also, usually, you'll feel some spring tension as you rotate the shaft. Most people assume that is the external return torsion spring they're feeling. But if you remove (or unhook) the external throttle return spring, you'll still feel spring tension on the throttle. That is the accelerator pump. There's a compression spring under the little piston that keeps the plug pushing up against the throttle plate shaft.
Hide Signatures
(in reply to kochj)
       Post #: 536
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/15/2011 12:06 PM
Pull Up Now!
Score: 140
Status: offline
quote:
ORIGINAL: kochj
Click for fullsize
Hide Signatures
(in reply to kochj)
       Post #: 537
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/16/2011 2:07 PM
kochj
Score: 143
Status: offline
Okay....It does have a pump.......
I cancelled my order from pats small engine shop in Issanti MN....
The reason... I was told it was on back order for 2-4 weeks...
What they didn't know, is that the carb. is discontinued, and they may never recieve the delivery of that
particular walbro carb.......
The woman I spoke with was very nice, and if I still want to get that walbro carb, I will call them up again...
I do believe the zama will work just as good as the walbro....I just have to test it out...
I have a OS 1.60 gemini twin, that already has a C&H ignition, and I have to come up with a way to mount both carbs on it...
If I could have someone machine up a mount for a single carb attachment, it would be quite easy (hint hint)
I have always found one cyl in this engine to be diff than the other....Being I will have gasoline in it, I don't want to
take the chance of a leaned out run or cyl...
1-carb per cyl is the way to go IMHO.... Even though the new saito gas twin, has only 1-carb shared between the two cyl's...
Hide Signatures
       Post #: 538
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/16/2011 2:10 PM
kochj
Score: 143
Status: offline
If I go the twin carb route, I will have to come up with a altered intake pipe...
Has anyone, or does anyone know if SS tubing can be used in a copper pipe flange maker?
Or is there a need for a specialized one??
Or perhaps I could use copper tubbing?
Hide Signatures
(in reply to kochj)
       Post #: 539
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/16/2011 6:40 PM
optech
Score: 105
Status: offline
Way back on page 11 is where Evert1969 talks about the message he got from Zama about the spring.
Mike
Hide Signatures
(in reply to kochj)
       Post #: 540
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/16/2011 6:52 PM
optech
Score: 105
Status: offline
quote:
ORIGINAL: Evert1969
I've read the posts in this forum and results are in this movie: http://www.youtube.com/watch?v=aXXA8ZrBD4Y
Thanks for all the advises.
Here's where he posted a video of his little Saito 80 running with Zama carb.
Mike
Hide Signatures
(in reply to Evert1969)
       Post #: 541
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/17/2011 5:37 AM
kochj
Score: 143
Status: offline
The needles didn't seem to be right yet.... (in the video)
...... Thank you for posting the link!...
Does anyone know where the best place to get the Rxcell ignitions with the 1/32 boot (or is it 1/4)
Hide Signatures
(in reply to optech)
       Post #: 542
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/17/2011 5:42 AM
w8ye
Score: 318
Status: offline
These people have a good track record and excellent service
http://www.valleyviewrc.com/RCEXL%20Ignitions.htm
Original AMA #31261
Hide Signatures
(in reply to kochj)
       Post #: 543
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/17/2011 7:33 PM
kochj
Score: 143
Status: offline
Thanks wayne..
Looks like they supply the regular sizes....
I am looking for the 1/4-32 size set to go...
I found this site....
Agape Racing and Hobby has one already to go....
No need to buy additional parts and hastle...
1/4-32 90 Deg RCEXL Ignition System-Single Cyl.
1/4-32 Mini Spark Plug-Single Cylinder-90 Degree
55$ + shipping...
Hide Signatures
(in reply to w8ye)
       Post #: 544
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/17/2011 9:37 PM
w8ye
Score: 318
Status: offline
Jim Willis at Agape has been a good source for parts
Original AMA #31261
Hide Signatures
(in reply to kochj)
       Post #: 545
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/18/2011 2:08 AM
Pull Up Now!
Score: 140
Status: offline
quote:
ORIGINAL: kochj
Thanks wayne..
55$ + shipping...
You must have called them? All I saw on their site was a bunch of cute dogs and some RC engines.
CAll them back and ask them if they do the soldering of the stainless steel 1/4-32 metal shroud themselves. And if it's the RCEXL kit. And most importantly, ask them if they're willing to put reinforcement strips soldered onto the 45% angles on the metal shrouds (2x 45 =90 degrees overall). If not, there's a danger of the solder joint breaking during flight. That has happened to me twice. When CH Ignition was in business, they used to reinforce mine for a nominal fee, by soldering a double across the solder joint. And that turned out to be worth a fortune in reliability.
If you're not sure what I'm talking about, I can supply a photo, or a drawing.
Hide Signatures
(in reply to kochj)
       Post #: 546
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/18/2011 4:39 AM
w8ye
Score: 318
Status: offline
This happened to me too
Original AMA #31261
Hide Signatures
       Post #: 547
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/30/2011 7:14 PM
CH Ignitions
Score: 420
Last Login: 6/16/2013
Status: offline
< Message edited by i7x58 -- 2/1/2011 9:27 AM >
www.ch-ignitions.com
Hide Signatures
(in reply to kochj)
       Post #: 548
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/30/2011 7:36 PM
w8ye
Score: 318
Status: offline
There is not supposed to be any difference in the crankcase breathers of the FG-20 and the FA-125A. They have the same part number.
There has been a problem with the Saito breather fittings as some have a burr across the hole caused by bad tooling on the bar lathe that makes them.
You can take a scribe and insert into the hole and open it up by removing the flashing that was pushed over the hole
Original AMA #31261
Hide Signatures
(in reply to CH Ignitions)
       Post #: 549
RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION - 1/30/2011 7:59 PM
CH Ignitions
Score: 420
Status: offline
W8ye,
Yes you are right, After you said this...I went and took it out and look at it. I could see the othe end that the hole is smaller, I took a file and got some off and opened the hole. Here is a pic on how it was before. Small hole is FG 20. Now both are the same cca 2mm, before was 1.25mm and I thought that Saito did it for a reason. I was thinking to try the engine after is set and tuned with the bigger hole to see if make any diffrence. In my mind it was to keep in some oil for lubeing the inside since is a gas and fuel does not run as much as Glow. well now I open it ...will see what  happends. You have one of those, yours was big hole from start?
Adrian
Click for fullsize
Hide Signatures
(in reply to w8ye)
       Post #: 550
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Jump to:
Google
SITE MAP!   : :   FORUM RULES
4.239RCU1
