RE: The Hots    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> RE: The Hots
Page: <<   < prev  1 2 [3]
Login
RE: The Hots - 4/3/2010 5:13 PM
DGrant
Score: 140
Last Login: 6/16/2013
Status: offline
Cool John... thanks for the link. I think the design parameters are very wide with the Hots format, and that you'll do fine.. and it will fly regardless of course.
I knew the SuperHots wasn't that large span-wise... I guess I should have measured... at least I had a "close" guess..
Its longer then it is wide... seemingly proportionate though.
I've wondered what a SuperHots, or even a Hots would fly like using a bit of todays structure/design concepts, with the overall finish shape remaining the same. Mine is obvious way overbuilt, and would withstand an earthquake I'm sure, part of the reason its 20+yrs old.. but its a great match for the .91 two-stroke.. and it still floats a bit... and its a permanent part of my fleet.
With laser-cut framing, lightened structure, original shape, and a good performing brushless set-up, I think the original could make a great comeback to mainstream RC.. any thoughts on that guys?
Hide Signatures
(in reply to john josey)
       Post #: 51
RE: The Hots - 4/3/2010 9:32 PM
john josey
Score: 110
Last Login: 6/19/2013
Status: online
quote:
ORIGINAL: dgrant
Hi again,
Are you saying that the super hots at 54"span is a good match for a 91 2st ? if this is the case then my prediction for the one i`m doing is way out !
I would think the last thing you would want is an underpowered hots !!! thanks for the input, i do appreciate it.
        john
Hide Signatures
(in reply to DGrant)
       Post #: 52
RE: The Hots - 4/3/2010 9:53 PM
DGrant
Score: 140
Status: offline
My SuperHots with an ASP .91 two-stroke is a great match really... especially in its day... I think that combo was even ahead of its time really, as it was fully capable of hovering it before hovering was mainstream.
Overall the SuperHots is way overbuilt, especially with the wood contained in the original kit... so as airframes go, in todays world its a real pig... with that said.. its really not even that big of a plane either. But for the violent manuervers that these are also capable of, it won't come apart in any way shape or form.
I would imagine if steps were taken to lighten the structure via lighter materials, or re-engineering somehow a 1.5xHots would do OK with a .91... but I wouldn't bet on it.
The whole reason I installed the .91 was after many years with a .61 on it(it was decent with that, but very middle of the road).. the firewall/cowling bond got weak. So I simply put a new firewall on it, no cowling, glassed the front end up, and bolted on the .91 I had in my cabinet. It did give it a newer, more radical look with a huge open engine, as well as being crazy fast and powerful. I quickly found that combo with a 14x6 prop would sustain a hover virtually as long as I wanted.. with power to pull out vertically..
You might get some performance with a .91 depending on what materials you use.. I just dont know though... and frankly I doubt it.
Hide Signatures
       Post #: 53
RE: The Hots - 4/3/2010 10:25 PM
john josey
Score: 110
Status: online
I`m choosing the wood carefully and i know the finished airframe will be as light as possible, but there is still that big blunt wing to overcome. I`ll speak to the owner and mention our concerns.
Are we better moving this discussion to the build thread i`m doing, i would`nt want to hijack someone elses thread.
Hide Signatures
       Post #: 54
RE: The Hots - 4/4/2010 1:17 AM
john josey
Score: 110
Status: online
quote:
ORIGINAL: flyathome
I am currently building an Ultra Hots. The wing span is 80 inches. If you are wanting to build something that size the
easiest thing to do is to simply build the Ultra Hots. I am building mine from the Model Airplane News plans. They are
not very good plans. My guess is that who ever drew the plans never built a plane from them. There are problems
with the plans that would quickly have come to light if they had built a plane using them. Even though they are more
expensive, if I had it to do over again I would order the plans from the Santich web site. At least I know they have
built the planes. The Hots is a great plane. I have built several of them over the years.
Steve
Hi Steve,
What size of engine do they recommended for the ultra Hots ?
                                                     john
Hide Signatures
(in reply to flyathome)
       Post #: 55
RE: The Hots - 4/4/2010 2:50 AM
flyathome
Score: 100
Last Login: 6/17/2013
Status: offline
John,
Actually this is my second Ultra Hots. I had one some years ago and sold it. I had so much fun with it I decided to build another.
My first Ultra Hots had a G-38 on it. It was more than enough for sport flying. The one I am building now will have a CRRC 40
for power. Again, I am not expecting 3D performance just good solid sport flying. I have other planes to fly when I want to mess
around with the 3D stuff. The Ultra Hots is really a straight forward build, nothing out of the ordinary, but provides a really fun
plane.
I say, "Go for it in whatever size you like."
Steve
_____________________________
I don''''t crash. The planet keeps getting in my way!!!!
Hide Signatures
       Post #: 56
RE: The Hots - 4/4/2010 4:05 AM
john josey
Score: 110
Status: online
quote:
ORIGINAL: flyathome
John,
plane.
Steve
Cheers steve
Hide Signatures
       Post #: 57
RE: The Hots - 4/7/2010 2:57 AM
flyathome
Score: 100
Status: offline
Here is a picture of the progress I have made so far on my Ultra Hots. It is coming along well.
I figure I am about 50% done with about 80% to go
Steve
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 58
RE: The Hots - 4/7/2010 7:30 PM
DGrant
Score: 140
Status: offline
quote:
ORIGINAL: flyathome
Steve
Very nice framing Steve. These planes are just totally unmistakeable. Any schemes in mind yet?
Hide Signatures
       Post #: 59
RE: The Hots - 4/7/2010 9:03 PM
LS1f
Score: 100
Last Login: 6/9/2013
Status: offline
quote:
ORIGINAL: outdoorhunting
Hey guys,let's see more pics of your Hots! ''Older IS better!!!
Here's mine.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to outdoorhunting)
       Post #: 60
RE: The Hots - 4/7/2010 9:17 PM
flyathome
Score: 100
Status: offline
LS1F
What method did you use to attach your wing cover/hatch? I have not decided for sure how I am going to do
mine. I was not at all happy with the way I did it on my first Ultra Hots. I am open to ideas.
Steve
Hide Signatures
(in reply to LS1f)
       Post #: 61
RE: The Hots - 5/12/2010 11:50 PM
magwie
Score: 105
Last Login: 7/30/2010
Status: offline
Hello all,
It's been a while but I'm slowly making progress on my "Hots".
Got all the servo's mounted, The fuel tank and lines, and the landing gear.
I'm gonna mount the control surfaces next...Any recomendations as to what hinges I should use?
P.S. I've been distracted by a new Electristar Select I just got!!
Enjoy the pics and HAPPY FLYING!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.autoinstrumentrepair.com
Hide Signatures
       Post #: 62
RE: The Hots - 5/13/2010 1:14 AM
john josey
Score: 110
Status: online
Looking good, dont you just love these aeroplanes !
As for hinges, i cant see by those CA ones. i was a bit wary at first but i`ve used them on everything including jets without any problems.
Hide Signatures
(in reply to magwie)
       Post #: 63
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
