ANT Netherlands SOftware and Windows 7    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> AMT Netherlands >> ANT Netherlands SOftware and Windows 7
Page: [1]
Login
ANT Netherlands SOftware and Windows 7 - 12/12/2009 4:33 PM
pfact
Score: 100
Last Login: 5/19/2013
Status: offline
Anyone out there running AMT Netherlands Software in Windows 7?
I can get the program to run but when I attempt to connect to the ECU for an Olympus I get a lost signal error message (presumably due to loss of signal from the USB-serial port connector that runs through Com3).
I am not very PC savy and don't know how to work through this problem.
Phil
Hide Signatures
       Post #: 1
RE: ANT Netherlands SOftware and Windows 7 - 12/12/2009 7:50 PM
Didier
Score: 100
Last Login: 5/2/2013
Status: offline
Hello.
I had a simulair problem with windows XP but after downloading new drivers for my usb-serial port connector, all was ok.
Hope it helps.
_____________________________
Live is simple, eat, sleep, fly jets!
Hide Signatures
(in reply to pfact)
       Post #: 2
RE: ANT Netherlands SOftware and Windows 7 - 12/13/2009 5:11 PM
pfact
Score: 100
Status: offline
Thanks Didier,
The drivers were the problem - there was a conflict amongst USB-serial adaptor drivers that was easily fixed.
The software works with Windows 7
Phil
Hide Signatures
(in reply to Didier)
       Post #: 3
RE: ANT Netherlands SOftware and Windows 7 - 12/18/2009 4:00 AM
ogm
Score: 100
Last Login: 12/27/2012
Status: offline
I have this problem also. Can you please let me know where I find the newer USB-serial adaptor drivers for XP?
Hide Signatures
       Post #: 4
RE: ANT Netherlands SOftware and Windows 7 - 12/18/2009 4:58 AM
pfact
Score: 100
Status: offline
ogm,
You need to use drivers for the chipset in your particular adaptor, doing so requires that you go to the web site of the manufacturer of your adaptor (in my case it was commfront.com). I first used a Belkin adaptor but it turned out not be compatible with Windows 7.
Too bad Bennie doesn't make software that works on a Mac - this would be easy.
Good luck,
Phil
Hide Signatures
(in reply to ogm)
       Post #: 5
RE: ANT Netherlands SOftware and Windows 7 - 12/18/2009 6:26 AM
ogm
Score: 100
Status: offline
Hi Phil
I connected the 3 Futaba cables to the wrong pins on the serial port. It is working now. Manual do not provide any help on how to setup initial parameters , etc, etc. When I go to the Trust Management tab and change to Pegasus, software do not keep my settings. How you use this software?
< Message edited by ogm -- 12/18/2009 8:21 AM >
Hide Signatures
(in reply to pfact)
       Post #: 6
RE: ANT Netherlands SOftware and Windows 7 - 11/19/2011 3:17 AM
Springbok Flyer
Score: 100
Last Login: 5/21/2013
Status: offline
Hi guys,
Perhaps one of you can tell me what the speed setting is for the comport?
JanR
''''It is always pilot error.''''
Hide Signatures
(in reply to ogm)
       Post #: 7
RE: ANT Netherlands SOftware and Windows 7 - 11/19/2011 5:43 AM
Skycat66
Score: 100
Last Login: 1/13/2013
Status: offline
 Hi,
Baudrate is 2400.
Cheers,
Hide Signatures
(in reply to Springbok Flyer)
       Post #: 8
RE: ANT Netherlands SOftware and Windows 7 - 2/7/2012 7:16 PM
jsouza
Score: 100
Last Login: 1/31/2013
Status: offline
Ray,
I've sent an email for you regarding problems I  am having with an 2.0 ECU.
I would appreciate a lot if you could help me
Jones
Hide Signatures
(in reply to Skycat66)
       Post #: 9
RE: ANT Netherlands SOftware and Windows 7 - 2/10/2012 6:26 AM
Skycat66
Score: 100
Status: offline
Hi Everybody,
New version of TMC application will be available on AMT website next week. It special build for smaller notebooks (10")
Regards,
Ray Struik
AMT Netherlands
Cheers,
Hide Signatures
(in reply to pfact)
       Post #: 10
RE: ANT Netherlands SOftware and Windows 7 - 2/10/2012 6:27 PM
jsouza
Score: 100
Status: offline
Ray,
Did you receive my e-mail? If not, I can send It as a PM.
Jones
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
