RE: T-28 Dave Platt    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: T-28 Dave Platt
Page: <<   < prev  8 9 10 11 12 [13] 14 15 16 17   next >   >>
Login
RE: T-28 Dave Platt - 6/28/2012 1:44 AM
lkahn4
Score: 100
Last Login: 5/5/2013
Status: offline
Thanks guys new I would get an answer. Dean started to take apart a mag light to use for the landing light but I'm having a touch time getting the bulb out. Any hints.
Larry
Hide Signatures
(in reply to maser)
       Post #: 301
RE: T-28 Dave Platt - 6/29/2012 3:53 AM
Dean rcu
Score: 130
Last Login: 5/26/2013
Status: offline
Larry, The bulbs popped right out for the two that I purchased for this project for a buck and a half each at True value. I have had some in previous builds where I ground out the bulbs with a Dremel and a 1/4 inch fine grit ball. Here are some images of what for me is the time consuming part of the project. Getting all the doors fitted and operating properly and cutting the trim tabs.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to lkahn4)
       Post #: 302
RE: T-28 Dave Platt - 6/29/2012 6:14 PM
maser
Score: 115
Last Login: 5/24/2013
Status: offline
Dean,
No flies lighting on you.  What progress.  Looking good.  I like the rudder light.  I need to add one also, but won't be functional.  Are you going to use the same method you used on your earlier T-28 for closing the door thats attached to the center of the wing with a bracket?  Be sure and send some pics of that, because I'm still not sure how to get that one closed.
Boyd.
Hide Signatures
(in reply to Dean rcu)
       Post #: 303
RE: T-28 Dave Platt - 6/30/2012 12:06 PM
lkahn4
Score: 100
Status: offline
Dean,
Really nice work, especially the light on the rudder, I was going through my photo pack and all the photos I got show that nav light behind the cockpit.
I solved the problem with the landing light, forgot we had bought a set of landing lights from RAM lighting for the Avenger build so I am using one of those.. Makes my life that much easier.
Going to try and get the wing mounting blocks in and the flap and aileron servos this weekend..temps high 80's to mid 90's with high humidity, not going to last long at the field.. Asphalt parking lot that we fly off of.
Boyd, I may need you to email me a few pix of the wing lauout for the servos, there is a problem with the site, photos don't show and they don't load either
Larry
Hide Signatures
       Post #: 304
RE: T-28 Dave Platt - 6/30/2012 2:27 PM
butlern
Score: 100
Last Login: 5/25/2013
Status: offline
Boyd, send me your email address again!
Noah
Hide Signatures
       Post #: 305
RE: T-28 Dave Platt - 6/30/2012 2:57 PM
Dean rcu
Score: 130
Status: offline
Boyd, I am looking at the full scale right now and I might try to close them like that with a brass tube and some wire. It's gong to be trial and error as I don't have an enginering degree. . Here are images of the full scale and my first T-28 inner gear doors.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to maser)
       Post #: 306
RE: T-28 Dave Platt - 6/30/2012 3:11 PM
Dean rcu
Score: 130
Status: offline
Thanks Larry! Here are images of the Nav lights on the full scale.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 307
RE: T-28 Dave Platt - 6/30/2012 3:18 PM
lkahn4
Score: 100
Status: offline
Dean,
Thanks for the shots, I wonder if the position of the lights were unique to a given branch of the military, I like your idea better, we'll see when i get to that point.
Noah, how did the move go? Hope it was uneventful.
Larry
Hide Signatures
       Post #: 308
RE: T-28 Dave Platt - 6/30/2012 4:40 PM
lkahn4
Score: 100
Status: offline
Boyd,
Question for you. On post #71 it shows the flap servo, when I go to mount the servo between W6 and w7 I will have to notch out the fwd gear rail to get the plate to fit, by chance did you move the servo between w7 and w8. See 2 photos
Thanks for all your help guys, I'm still pretty new at this
Larry
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to maser)
       Post #: 309
RE: T-28 Dave Platt - 6/30/2012 7:56 PM
butlern
Score: 100
Status: offline
Larry, the move went very well, it's just all the unpacking and reorganization that has us in a state of chaos!
Noah
Hide Signatures
       Post #: 310
RE: T-28 Dave Platt - 7/2/2012 9:56 PM
maser
Score: 115
Status: offline
Larry,
Yes I moved it between W7 & W8
Boyd
Hide Signatures
       Post #: 311
RE: T-28 Dave Platt - 7/3/2012 1:34 AM
lkahn4
Score: 100
Status: offline
Boyd,
Thanks I thought I was missing something. I picked up 1" x 2" maple to redo the wing blocks.
Larry
Hide Signatures
(in reply to butlern)
       Post #: 312
RE: T-28 Dave Platt - 7/4/2012 12:19 PM
lkahn4
Score: 100
Status: offline
Hi Guys
Happy 4th hope you have a great day.
Dean, here is the 1st of 2 pix of a Marine T-28 from Bankas documentation, he doesn't say when or where they were taken but notice the position of the nav light on the fuse behind the canopy.
Larry
Click for fullsize
Hide Signatures
       Post #: 313
RE: T-28 Dave Platt - 7/4/2012 12:21 PM
lkahn4
Score: 100
Status: offline
Hey Dean
Pix number 2
Click for fullsize
Hide Signatures
       Post #: 314
RE: T-28 Dave Platt - 7/4/2012 3:43 PM
Dean rcu
Score: 130
Status: offline
Larry, I believe thats called the beacon light the white nav light is on the rudder. I notice that the C model has only one on the rudder where the B and D usually have two. I hope to copy this full scale T-28D. Hope all you guys have a great 4th.
Dean
Click for fullsize
< Message edited by Dean rcu -- 7/4/2012 9:58 PM >
Hide Signatures
       Post #: 315
RE: T-28 Dave Platt - 7/7/2012 12:39 PM
lkahn4
Score: 100
Status: offline
Hey guys,
Happy weekend, finally.
Boyd, I have a question for you, I have the wing all laid up and before I mount the flap servos I wanted to build the flaps so I can get everything lined up.
When I look at the flap leading edge pix (pix from post #70) and the actual leading edge block it is quite a bit short of the top of the ribs, my question is what did you use to build up the top of the LE, I'm having a senior moment.
We are having our club warbird fly in next Saturday, I will post pix next weekend.
Larry
Dean the wife is having me go out to Arizona to check out landscapers, I'm thinking late Aug early September if you think that's a good time for PIMA
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to maser)
       Post #: 316
RE: T-28 Dave Platt - 7/7/2012 11:52 PM
maser
Score: 115
Status: offline
Larry,
I had the same problem.  I'm not sure why the custom cutters made the part that way.  I just built it up.
It's frustrating when the cutouts don't match the plans.
Dean,
Would love to see some more pix's.
Boyd.
Hide Signatures
       Post #: 317
RE: T-28 Dave Platt - 7/8/2012 1:47 AM
lkahn4
Score: 100
Status: offline
I thought i had the wrong piece laid out. I'm really liking Deans lights on the rudder, I posted a pix of the Marine corps version and it only has 1 light on it, you need to look really close to see it but it's there.
As soon as I get the 1st flap made I can get at least the 1st servo mounted. Got an unexpected visit from my daughter so it may be a few days..LOL
Thanks again
Larry
Hide Signatures
(in reply to maser)
       Post #: 318
RE: T-28 Dave Platt - 7/8/2012 5:06 PM
Dean rcu
Score: 130
Status: offline
Larry, The later the better. We will be in our monsoon season until the middle of September and it will still be hot till October.
Boyd, Here are some images of where I am with the cowl and nose gear doors ect.
Dean
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 319
RE: T-28 Dave Platt - 7/9/2012 2:26 AM
lkahn4
Score: 100
Status: offline
Dean,
Great shots, got the engines synced on the p-38 today, first flight hopefully next Saturday. Getting ready to start building the flaps so I can get the servos and linkages setup, need to pick up some balsa to build up the leading edge since the kit cutter decided that he could short the thickness.
Listen to this deal one of the guys in the club got, yellow aircraft f-16, retracts, brakes, ducted fan and a .90 Rossi engine all for..ready..$300.00 what a deal all he needs is a tuned pipe.
I will try and hold off until October but it all depends on the landscapers, if not this trip the next one.
Larry
Hide Signatures
       Post #: 320
RE: T-28 Dave Platt - 7/9/2012 2:58 AM
thailazer
Score: 110
Status: offline
quote:
ORIGINAL: Dean rcu
This is a Platt 1/6th scale I modeled a few years ago. I cut the kit and added the dive brakes. I'm glad to see Sierra has made retracts as Dave's gave me all kinds of headaches.
That is a real beauty. I built one years ago but it certainly did not have that level of scale detail.
_____________________________
Tiger Flyer #49
Hide Signatures
       Post #: 321
RE: T-28 Dave Platt - 7/9/2012 12:54 PM
maser
Score: 115
Status: offline
Larry,
Those destractions "Kids" can be fun though.
Dean,
What power plant are you planning on using.  What's that filler you used on the seam line between the wing and fusalage.
Boyd
Hide Signatures
       Post #: 322
RE: T-28 Dave Platt - 7/9/2012 12:58 PM
maser
Score: 115
Status: offline
thailazer,
It's never to late to start another one.
Boyd.
Hide Signatures
(in reply to thailazer)
       Post #: 323
RE: T-28 Dave Platt - 7/9/2012 1:05 PM
thailazer
Score: 110
Status: offline
quote:
ORIGINAL: maser
thailazer,
Boyd.
Well, once the house and runway are done, its going to be time to check the list and see what I should build. The Trojan has always been one of my favorites, and at Oshkosh I spent a lot of time on T-28 row in the past. I built the Pica and it flew just great on a 60 even carrying those cool, slow Kraft electric retracts that never retracted at the same time.
Tiger Flyer #49
Hide Signatures
(in reply to maser)
       Post #: 324
RE: T-28 Dave Platt - 7/9/2012 3:16 PM
Dean rcu
Score: 130
Status: offline
quote:
ORIGINAL: thailazer
quote:
ORIGINAL: Dean rcu
Thanks thailazer! That was my third T-28 the first two were the 65" designed by Platt and sold to Pica. I try to improve the detail of mt previous builds.
Hide Signatures
       Post #: 325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
