How to fix muffler?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Crash & Rebuild >> How to fix muffler?
Page: [1]
Login
How to fix muffler? - 12/13/2009 9:23 AM
Heyrandy
Score: 100
Last Login: 10/31/2011
Status: offline
My Chipmunk had a rough landing and the Bison Pitts muffler took it hard. Can I fix the muffler with a little JB Weld? I heard that JB is not good for vibrating services. Is there something better to use? Thanks.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
I want to die peacefully in my sleep like my Grandpa. Not kicking and screaming like the passengers in his plane.
Hide Signatures
       Post #: 1
RE: How to fix muffler? - 12/13/2009 9:40 AM
Heyrandy
Score: 100
Status: offline
In case you are wondering, here is what my Chip looked like right before I damaged the muffler.
Click for fullsize
Hide Signatures
(in reply to Heyrandy)
       Post #: 2
RE: How to fix muffler? - 12/13/2009 4:05 PM
K-Bob
Score: 169
Last Login: 5/23/2013
Status: offline
Sorry about the Chipmunk. She was a beauty.
I've tried to JB stingers back onto mufflers before with little or no success. They usually last 2 or 3 flights then come loose. Maybe I wasn't doing it correctly.
K-Bob. The K is silent. "The only time you can have too much fuel is if you are on fire"
Hide Signatures
       Post #: 3
RE: How to fix muffler? - 12/13/2009 4:11 PM
outdoorhunting
Score: 351
Status: offline
Same thing happened to my Chippy. Although, luckly, it was an easy repair.. Same damage to the muffler. I found a mixable epoxy called "PC epoxy". It's the putty type that you roll together until it is thoroughly mixed. I cleaned both piecs with a wire brush & wiped down with alcohol. I then just worked the epoxy into & around the pipes making a small bead. I let it set for a couple of days & I've had about ten flights on it, no problems yet. I got it at a "Farmer's Supply" but , I'm sure it's availble elseware . Good Luck !!
Too much horsepower- Just right !!!
Hide Signatures
       Post #: 4
RE: How to fix muffler? - 12/13/2009 8:17 PM
N1EDM
Score: 125
Last Login: 5/26/2013
Status: offline
How about silver solder?
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to outdoorhunting)
       Post #: 5
RE: How to fix muffler? - 12/14/2009 12:47 AM
texastwister
Score: 100
Last Login: 7/28/2012
Status: offline
whats it made of ? if its steel silver solder or brass
take it to a radiator shop they can solder it on in a heartbeat for probably a freebie or a few bucks
nice plane sorry for your loss
The 2 most abundant things in the universe are Hydrogen and stupidity and I don't know which is the more.
Hide Signatures
(in reply to N1EDM)
       Post #: 6
RE: How to fix muffler? - 12/14/2009 2:34 AM
Heyrandy
Score: 100
Status: offline
Thanks for the ideas. I believe that the muffler and stingers are made of aluminum.
How does the silver solder thing work? I have "silver bearing solder" that I've used on plumbing. Is that the same thing. I also have 60/40, etc. Do I just heat the assembly with my propane torch and sweat the solder into the joint? Any flux (ie acid type)?
Thanks.
Hide Signatures
(in reply to texastwister)
       Post #: 7
RE: How to fix muffler? - 12/14/2009 2:53 AM
ohnoucdat
Score: 105
Last Login: 2/18/2013
Status: offline
Oh good Lord, cover her up. If you have a blacks smith shop in your area, stop in show it to them, they usually can tell you what it's made of, and can usually fix it for you. Tig weld whatever it takes.
Hide Signatures
       Post #: 8
RE: How to fix muffler? - 12/14/2009 5:29 AM
N1EDM
Score: 125
Status: offline
Heyrandy,
I take back what I said about Silver Solder. I was talking about Stay Brite Silver Solder available from TH. I've used it for control rods and never had a problem. I've never used it on a muffler though.
I just read the instructions on the bottle and it specifically states that it is NOT recommended for aluminum. I doubt that your muffler is steel (which the solder would work on), but a magnet will tell you that.
For anyone who is interested, you can look at Stay Brite at http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFS75&P=ML
Bob
Hide Signatures
       Post #: 9
RE: How to fix muffler? - 12/14/2009 6:18 AM
Sandmann_AU
Score: 7
Last Login: 4/19/2011
Status: offline
I had exactly the same thing happen to exactly the same muffler mounted on a super tigre 60 in a Harmon Rocket 3. I've had excellent results using Permatex Cold Weld Bonding Compound. It mixes up like a two part epoxy and sets in 15 minutes, and once set you can even cut theads in this stuff if you want. I've put several hours of flight time on mine since repairing and it hasn't budged. I did email the guy who owns Bisson and he recommended TIG welding but I didn't know anyone who could/would do it for me. The trick is to make sure it's REALLY clean - shine it up with a wire brush or some fine sandpaper before you glue it.
Matt
Hide Signatures
       Post #: 10
RE: How to fix muffler? - 12/15/2009 4:37 AM
jester_s1
Score: 233
Last Login: 5/25/2013
Status: offline
Just take it to a welding shop. It will be an easy repair for an experienced welder who knows how to fix thin aluminum. It probably would do fine with just some tacks all around and then seal it with the epoxy putty.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to Sandmann_AU)
       Post #: 11
RE: How to fix muffler? - 12/20/2009 9:38 AM
Carpilot
Score: 100
Last Login: 4/1/2010
Status: offline
I use a product called "alumiweld" No flux required and it melts at 730 degrees Fahrenheit. Do a google search on "alumiweld" I have some that I bought at harbor freight tools. and ace hardware sells it also.
It is an awesome product, I welded a busted up crankcase with it once and got another year out of an engine.
Here.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44810
It is a little tricky to use, welding aluminum can be hard because it oxidizes almost instantly, just use a stainless steel brush and keep scratching the surface of your muffler with the rod to keep breaking through the oxidation, then it will flow just like solder. and I prefer to use mapp gas instead of propane it burns hotter.
Harken to ye N00bs! Thee shalt lock thine tail wheel afore attempting to leave thine surly bonds!
Hide Signatures
       Post #: 12
RE: How to fix muffler? - 12/20/2009 10:22 AM
rcflyer4fun
Score: 105
Last Login: 5/10/2013
Status: offline
The Alumiweld from harbor frieght is the only way to fix your muffler. Its extremely easy to use and has like 30000 pounds tensil strength. Staybright and silver solders only work on brass copper and steals. Show us how it turns out when you fix it.
Evan
Hide Signatures
       Post #: 13
RE: How to fix muffler? - 12/31/2009 8:57 AM
Heyrandy
Score: 100
Status: offline
Sounds like it is worth a try. Will let you all know later.
Thanks!
Hide Signatures
(in reply to rcflyer4fun)
       Post #: 14
RE: How to fix muffler? - 12/31/2009 11:50 AM
minicrazy592
Score: 110
Last Login: 10/14/2011
Status: offline
Barbie is a little decapitated. lol
Everyone crashes, its the matter of whose is cooler when it does!
MUS Rebuild: http://tiny.cc/D6vWj
Hide Signatures
       Post #: 15
RE: How to fix muffler? - 1/1/2010 3:29 AM
biam
Score: 110
Status: online
ive had good sucess with J.B. weld joining the muffler halves on a magnum .52 f.s., not pretty but still together!
Bill.
It is always better to be under the gun, than in front of it!
Hide Signatures
(in reply to minicrazy592)
       Post #: 16
RE: How to fix muffler? - 1/8/2010 10:19 AM
Heyrandy
Score: 100
Status: offline
I used the Alumiweld rods from Harbor Frieght and a paint can opener tool to scrape the weld flat. Not exactly professional quality but is airtight and seems good enough. I used MAPP gas but maybe a little too hot as the muffler and stingers deformed a bit. I would probably try just propane first next time.
The Alumiweld is cool stuff and will likely find other uses for it. I would suggest practicing with other things first as initially I had huge globs of it on my muffler. Eventually I figured out how to scrape the excess off.
Thanks for the suggestion!
Click for fullsize
Hide Signatures
(in reply to biam)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.844RCU1
