RE: Bob Nelitz 1/3 Scale J-3 Short Kit build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Bob Nelitz 1/3 Scale J-3 Short Kit build
Page: <<   < prev  4 5 6 7 8 9 10 11 [12] 13   next >   >>
Login
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/12/2012 1:47 PM
misterbill
Score: 100
Last Login: 6/16/2013
Status: offline
Claud,
Cut all my wood to size on my Proxxon mini table saw. So I could make it exactly the size I needed. But 5/16" is around 9mm, and 1 1/4" is around 32mm if that helps.
I didn't use spruce for the dowels, couldn't find any, but I just used regular hardware store hardwood dowels. 18mm or so should do you if that size is available where you are.
Mike
_____________________________
1/3 Sopwith Pup, 1/3 Nelitz J3 Cub
1/3 DH82A Tiger Moth (underway), 1/4 Jungmeister (2nd one, underway)
Hide Signatures
(in reply to claudbosc)
       Post #: 276
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/12/2012 6:35 PM
Donairplane
Score: 100
Last Login: 6/9/2013
Status: offline
Hi Bill,
What was the finished weight of your cub?
 Beautiful job on your cub!!
Will finish mine after our move to Arizona.
Don
Hide Signatures
(in reply to misterbill)
       Post #: 277
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/12/2012 6:38 PM
misterbill
Score: 100
Status: offline
Hi Don - don't exactly remember - it was a while back when I weighed the bits for the cg, but it was in the early 30lb range.
Thanks for the kind words.
Mike
Hide Signatures
(in reply to Donairplane)
       Post #: 278
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/13/2012 10:19 AM
claudbosc
Score: 100
Last Login: 2/27/2013
Status: offline
Hello and thanks for the reply.
Since I am only plywood 8 or 10 mm thick.
To get them in wood joinery I should go in and have them cut to size but it would cost too much.
According to you, you can also use the plywood 8 mm?
www.parcodelcormor.com
Hide Signatures
       Post #: 279
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/13/2012 12:26 PM
misterbill
Score: 100
Status: offline
5/16 is actually 7.9mm so 8 mm should be perfect.
Google search for an inch to metric converter - it will help you. Here's one you could try
http://www.easysurf.cc/fracton.htm
Mike
Hide Signatures
       Post #: 280
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/14/2012 9:03 AM
claudbosc
Score: 100
Status: offline
quote:
ORIGINAL: misterbill
Mike
Ok I will use the one from 8 mm.
But the plywood is okay or should I use hardwood?
Hide Signatures
       Post #: 281
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/14/2012 11:04 AM
Tony Hallo
Score: 141
Last Login: 6/20/2013
Status: online
I assume the wood is for the main spar, that being said, plywood is not the best choice.  Spruce or basswood would be the wood of choice.  When you cut a strip of plywood for use on a spar, only half of the fibers are in line with the bending stress, the fibers that are 90 degrees from the bending stress add little to the strength.  I would image popular wood is available in Italy?  I thought that is where our lite ply originated, Italian Bending Plywood?  I would use popular if basswood or spruce is not available.
< Message edited by Tony Hallo -- 11/15/2012 11:08 AM >
Tony Hallo
Hide Signatures
       Post #: 282
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/15/2012 10:44 AM
dadragon
Score: 112
Last Login: 6/8/2013
Status: offline
You can go to your local welding supply store get a card with the convertions on it.it has fractions to metric.
Hide Signatures
(in reply to Tony Hallo)
       Post #: 283
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/22/2012 7:13 PM
claudbosc
Score: 100
Status: offline
I ask for help.
Is there anyone of you who can get me the spars for the wings?
There are 4 pieces of spruce but here in Italy nobody has the time and desire to cut!
I'll pay the labor and shipping ...
Hide Signatures
(in reply to dadragon)
       Post #: 284
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/23/2012 6:48 AM
gordon_mcln
Score: 100
Last Login: 6/19/2013
Status: offline
Claude,
Call Aircraft Spruce or order online....They can supply any size spruce you need. Another option is Wicks Aircraft Supply in Canada.
Gordon
Fleet Brotherhood #18
Hide Signatures
       Post #: 285
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 11/27/2012 3:38 AM
dadragon
Score: 112
Status: offline
I used spruce on a few planes now I go to the local Lowes or HomeDepot and get a couple of 8 or 10' peices poplar,just as sturdy as spruce and alot cheaper as I do ALL myown cutting.
Hide Signatures
(in reply to gordon_mcln)
       Post #: 286
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 12/23/2012 2:16 AM
crashman1432
Score: 100
Last Login: 6/17/2013
Status: offline
Hey guys. Love this thread. I purchase a used Nelitz cub some time ago. (Thought that it was a BUSA Cub). Lovely plane but has seen much wear and abuse. I am trying to rework it some and bring it back to a better state. Can someone post some pictures or details about how the wing secures to the fuselage. Not the strut attachments but the root rib connections. Particularly how are the hardwood spars finished off to be able to connect to the tubular cage. Mine has like a metal cap strip molded around the end of the spar. It is really buggered up and leaves a lot of slop in the fit. The rear connection is a dowel with a brass tube over it that slips inside the metal tubing. A hole is drilled into it and a wire slips through it to secure inside the tubing. Any pictures or help would be greatly appreciated. If I can get her spiffed up a bit I plan to put her on floats and fly her often at our local lake. Thanks for your help.
Hide Signatures
       Post #: 287
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 1/28/2013 11:49 PM
garypace
Score: 100
Status: offline
Hi I just received my cowling from fiberglass s. and started working on it and I noticed it was over a half inch wider on one side so I e mailed them and told them a bout the problem and sent some pictures , and this is what he said. [[ I can't tell what you are referring to. The cowl is what it is, if it's not
good enough for you, then you'll need to get it from someone else ]]
Hide Signatures
(in reply to crashman1432)
       Post #: 288
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 1/28/2013 11:57 PM
Tony Hallo
Score: 141
Status: online
Post a photo of the cowl, I am having trouble understanding your problem.
Tony Hallo
Hide Signatures
(in reply to garypace)
       Post #: 289
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 1/29/2013 12:05 AM
garypace
Score: 100
Status: offline
its over a half inch rounder one one side Itry to post picture for you
Hide Signatures
       Post #: 290
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/1/2013 8:34 PM
bh307
Score: 102
Last Login: 5/4/2013
Status: offline
Rare find in local hobby shop 1/3 scale Bob nelitz cub in pretty good shape , Had to have it now in my garge was not cheap but its my, builder did good job , now much work to get it in the air.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 291
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/1/2013 8:37 PM
bh307
Score: 102
Status: offline
more
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 292
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/1/2013 8:38 PM
bh307
Score: 102
Status: offline
more
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 293
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/1/2013 9:17 PM
Donairplane
Score: 100
Status: offline
bh307,
Is Alex Guzman still cutting short kits for the cub?
Hide Signatures
(in reply to bh307)
       Post #: 294
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/2/2013 1:57 AM
bh307
Score: 102
Status: offline
yes I thank so
Hide Signatures
       Post #: 295
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/5/2013 12:29 AM
garypace
Score: 100
Status: offline
Hi guys I just started working on my cub cowling and just finshed cuting the rivots and would like to do panel lines on it and could use your thoughts on how to do them.
Hide Signatures
(in reply to bh307)
       Post #: 296
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/5/2013 12:52 AM
bh307
Score: 102
Status: offline
more pictures
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 297
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/14/2013 1:10 PM
garypace
Score: 100
Status: offline
HI I'm starting to build a detail dummy engine for my nelitz j3 cub and was wondering if anyone would be interested ?
Hide Signatures
(in reply to bh307)
       Post #: 298
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/14/2013 3:33 PM
warbirdmustang
Score: 100
Status: offline
I'm sure everyone would be interested! Rock on!
Nosen Cessna 310 Club Number 12
Hide Signatures
       Post #: 299
RE: Bob Nelitz 1/3 Scale J-3 Short Kit build - 2/14/2013 7:00 PM
misterbill
Score: 100
Status: offline
Here are some pix of how I did mine if that helps at all - ply laser cut fins etc., bolted onto ali shrouds around the Zenoah, exhausts etc cast by slosh casting resin, valve covers made from resin in urethane molds.
Plugs mix of ali tube & locknuts, wires are shrunk heatshrink. Eyebrows ali sheet.
Mike
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to warbirdmustang)
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
